I'm using SDK 15.2. The bluetooth disconnects when I enable notifications on nrfConnect. This happens only if I increase the number of bytes to be sent. I'm writing a code for custom gatt. The references I used were -
https://github.com/maidenone/custom_ble_service_example
My code files -
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
#include "sdk_common.h"
#include "ble_srv_common.h"
#include "ble_cus.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_log.h"
/**@brief Function for handling the Connect event.
* @param[in] p_cus Custom Service structure.
* @param[in] p_ble_evt Event received from the BLE stack. */
static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
ble_cus_evt_t evt;
evt.evt_type = BLE_CUS_EVT_CONNECTED;
p_cus->evt_handler(p_cus, &evt);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
#include "sdk_common.h" #include "ble_srv_common.h" #include "ble_cus.h" #include <string.h> #include "nrf_gpio.h" #include "boards.h" #include "nrf_log.h" /**@brief Function for handling the Connect event. * @param[in] p_cus Custom Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt) { p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle; ble_cus_evt_t evt; evt.evt_type = BLE_CUS_EVT_CONNECTED; p_cus->evt_handler(p_cus, &evt); } /**@brief Function for handling the Disconnect event. * @param[in] p_cus Custom Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt) { UNUSED_PARAMETER(p_ble_evt); p_cus->conn_handle = BLE_CONN_HANDLE_INVALID; ble_cus_evt_t evt; evt.evt_type = BLE_CUS_EVT_DISCONNECTED; p_cus->evt_handler(p_cus, &evt); } /**@brief Function for handling the Write event. * @param[in] p_cus Custom Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt) { ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write; // Custom Value Characteristic Written to. if (p_evt_write->handle == p_cus->custom_value_handles.value_handle) { nrf_gpio_pin_toggle(LED_4); NRF_LOG_INFO("GOT WRITE ON: %d",*p_evt_write->data); if(*p_evt_write->data == 0x01) { nrf_gpio_pin_clear(LED_3); } else if(*p_evt_write->data == 0x02) { nrf_gpio_pin_set(LED_3); } else { //Do nothing } } // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes. if ((p_evt_write->handle == p_cus->custom_value_handles.cccd_handle) && (p_evt_write->len == 2)) { // CCCD written, call application event handler if (p_cus->evt_handler != NULL) { ble_cus_evt_t evt; if (ble_srv_is_notification_enabled(p_evt_write->data)) { evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED; } else { evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED; } // Call the application event handler. p_cus->evt_handler(p_cus, &evt); } } } void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context) { ble_cus_t * p_cus = (ble_cus_t *) p_context; NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id); if (p_cus == NULL || p_ble_evt == NULL) { return; } switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: on_connect(p_cus, p_ble_evt); break; case BLE_GAP_EVT_DISCONNECTED: on_disconnect(p_cus, p_ble_evt); break; case BLE_GATTS_EVT_WRITE: on_write(p_cus, p_ble_evt); break; /* Handling this event is not necessary case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST: NRF_LOG_INFO("EXCHANGE_MTU_REQUEST event received.\r\n"); break;*/ default: // No implementation needed. break; } } /**@brief Function for adding the Custom Value characteristic. * @param[in] p_cus Custom Service structure. * @param[in] p_cus_init Information needed to initialize the service. * @return NRF_SUCCESS on success, otherwise an error code. */ static uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init) { uint32_t err_code; ble_gatts_char_md_t char_md; ble_gatts_attr_md_t cccd_md; ble_gatts_attr_t attr_char_value; ble_uuid_t ble_uuid; ble_gatts_attr_md_t attr_md; // Add Custom Value characteristic memset(&cccd_md, 0, sizeof(cccd_md)); // Read operation on cccd should be possible without authentication. BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm; cccd_md.vloc = BLE_GATTS_VLOC_STACK; memset(&char_md, 0, sizeof(char_md)); char_md.char_props.read = 1; char_md.char_props.write = 1; char_md.char_props.notify = 1; char_md.p_char_user_desc = NULL; char_md.p_char_pf = NULL; char_md.p_user_desc_md = NULL; char_md.p_cccd_md = &cccd_md; char_md.p_sccd_md = NULL; ble_uuid.type = p_cus->uuid_type; ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID; memset(&attr_md, 0, sizeof(attr_md)); attr_md.read_perm = p_cus_init->custom_value_char_attr_md.read_perm; attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm; attr_md.vloc = BLE_GATTS_VLOC_STACK; attr_md.rd_auth = 0; attr_md.wr_auth = 0; attr_md.vlen = 0; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &ble_uuid; attr_char_value.p_attr_md = &attr_md; attr_char_value.init_len = sizeof(uint8_t); attr_char_value.init_offs = 0; attr_char_value.max_len = sizeof(uint8_t); err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md, &attr_char_value, &p_cus->custom_value_handles); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init) { if (p_cus == NULL || p_cus_init == NULL) { return NRF_ERROR_NULL; } uint32_t err_code; ble_uuid_t ble_uuid; // Initialize service structure p_cus->evt_handler = p_cus_init->evt_handler; p_cus->conn_handle = BLE_CONN_HANDLE_INVALID; // Add Custom Service UUID ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE}; err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type); VERIFY_SUCCESS(err_code); ble_uuid.type = p_cus->uuid_type; ble_uuid.uuid = CUSTOM_SERVICE_UUID; // Add the Custom Service err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle); if (err_code != NRF_SUCCESS) { return err_code; } // Add Custom Value characteristic return custom_value_char_add(p_cus, p_cus_init); } uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value[20]) /*NEW CHANGE*/ { NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n"); if (p_cus == NULL) { return NRF_ERROR_NULL; } uint32_t err_code = NRF_SUCCESS; ble_gatts_value_t gatts_value; // Initialize value struct. memset(&gatts_value, 0, sizeof(gatts_value)); gatts_value.len = 20*sizeof(uint8_t); /*NEW CHANGE*/ gatts_value.offset = 0; gatts_value.p_value = &custom_value[0]; // Update database. err_code = sd_ble_gatts_value_set(p_cus->conn_handle, p_cus->custom_value_handles.value_handle, &gatts_value); if (err_code != NRF_SUCCESS) { return err_code; } // Send value if connected and notifying. if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID)) { ble_gatts_hvx_params_t hvx_params; memset(&hvx_params, 0, sizeof(hvx_params)); hvx_params.handle = p_cus->custom_value_handles.value_handle; hvx_params.type = BLE_GATT_HVX_NOTIFICATION; hvx_params.offset = gatts_value.offset; hvx_params.p_len = &gatts_value.len; hvx_params.p_data = gatts_value.p_value; err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params); NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code); } else { err_code = NRF_ERROR_INVALID_STATE; NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n"); } return err_code; }
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
/** * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** @file * * @defgroup ble_sdk_app_template_main main.c * @{ * @ingroup ble_sdk_app_template * @brief Template project main file. * * This file contains a template for creating a new application. It has the code necessary to wakeup * from button, advertise, get a connection restart advertising on disconnect and if no new * connection created go back to system-off mode. * It can easily be used as a starting point for creating a new application, the comments identified * with 'YOUR_JOB' indicates where and how you can customize. */ #include <stdbool.h> #include <stdint.h> #include <string.h> #include "nordic_common.h" #include "nrf.h" #include "app_error.h" #include "ble.h" #include "ble_hci.h" #include "ble_srv_common.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" #include "nrf_sdh.h" #include "nrf_sdh_soc.h" #include "nrf_sdh_ble.h" #include "app_timer.h" #include "fds.h" #include "peer_manager.h" #include "peer_manager_handler.h" #include "bsp_btn_ble.h" #include "sensorsim.h" #include "ble_conn_state.h" #include "nrf_ble_gatt.h" #include "nrf_ble_qwr.h" #include "nrf_pwr_mgmt.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" /*new*/ #include "ble_cus.h" #define DEVICE_NAME "Forte" /**< Name of device. Will be included in the advertising data. */ #define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */ #define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */ #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */ #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */ #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */ #define SLAVE_LATENCY 0 /**< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ /*new*/ #define NOTIFICATION_INTERVAL APP_TIMER_TICKS(100) #define SEC_PARAM_BOND 1 /**< Perform bonding. */ #define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */ #define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */ #define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */ #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */ #define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */ #define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */ #define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/ BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */ /*new*/ BLE_CUS_DEF(m_cus); APP_TIMER_DEF(m_notification_timer_id); /*new*/ static uint8_t m_custom_value = 0; static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ /* YOUR_JOB: Declare all services structure your application is using * BLE_XYZ_DEF(m_xyz); */ // YOUR_JOB: Use UUIDs for service(s) used in your application. /*static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */ /*{ {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE} };*/ /*new*/ ble_uuid_t m_adv_uuids[] = {{CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN }}; /**< Universally unique service identifiers. */ static void advertising_start(bool erase_bonds); /**@brief Callback function for asserts in the SoftDevice. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); } /**@brief Function for handling Peer Manager events. * * @param[in] p_evt Peer Manager event. */ static void pm_evt_handler(pm_evt_t const * p_evt) { ret_code_t err_code; //pm_handler_on_pm_evt(p_evt); //pm_handler_flash_clean(p_evt); switch (p_evt->evt_id) { case PM_EVT_BONDED_PEER_CONNECTED: { NRF_LOG_INFO("Connected to a previously bonded device."); } break; case PM_EVT_CONN_SEC_SUCCEEDED: { NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.", ble_conn_state_role(p_evt->conn_handle), p_evt->conn_handle, p_evt->params.conn_sec_succeeded.procedure); } break; case PM_EVT_CONN_SEC_FAILED: { /* Often, when securing fails, it shouldn't be restarted, for security reasons. Other times, it can be restarted directly. * Sometimes it can be restarted, but only after changing some Security Parameters. Sometimes, it cannot be restarted until the link is disconnected and reconnected. * Sometimes it is impossible, to secure the link, or the peer device does not support it. How to handle this error is highly application dependent. */ } break; case PM_EVT_CONN_SEC_CONFIG_REQ: { // Reject pairing request from an already bonded peer. pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false}; pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config); } break; case PM_EVT_STORAGE_FULL: { // Run garbage collection on the flash. err_code = fds_gc(); if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES) { // Retry. } else { APP_ERROR_CHECK(err_code); } } break; case PM_EVT_PEERS_DELETE_SUCCEEDED: advertising_start(false); break; case PM_EVT_PEER_DATA_UPDATE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error); } break; case PM_EVT_PEER_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error); } break; case PM_EVT_PEERS_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error); } break; case PM_EVT_ERROR_UNEXPECTED: { // Assert. APP_ERROR_CHECK(p_evt->params.error_unexpected.error); } break; case PM_EVT_CONN_SEC_START: case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: case PM_EVT_PEER_DELETE_SUCCEEDED: case PM_EVT_LOCAL_DB_CACHE_APPLIED: case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED: // This can happen when the local DB has changed. case PM_EVT_SERVICE_CHANGED_IND_SENT: case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED: default: break; } } /**@brief Function for handling the Battery measurement timer timeout. * @details This function will be called each time the battery level measurement timer expires. * @param[in] p_context Pointer used for passing some arbitrary information (context) from the app_start_timer() call to the timeout handler. */ static void notification_timeout_handler(void * p_context) { UNUSED_PARAMETER(p_context); ret_code_t err_code; // Increment the value of m_custom_value before nortifing it. m_custom_value++; err_code = ble_cus_custom_value_update(&m_cus, m_custom_value); APP_ERROR_CHECK(err_code); } /**@brief Function for the Timer initialization. * * @details Initializes the timer module. This creates and starts application timers. */ static void timers_init(void) { // Initialize timer module. ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); // Create timers. err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler); APP_ERROR_CHECK(err_code); /* YOUR_JOB: Create any timers to be used by the application. Below is an example of how to create a timer. For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by one. ret_code_t err_code; err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler); APP_ERROR_CHECK(err_code); */ } /**@brief Function for the GAP initialization. * * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the * device including the device name, appearance, and the preferred connection parameters. */ static void gap_params_init(void) { ret_code_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); /* YOUR_JOB: Use an appearance value matching the application's use case. err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_); APP_ERROR_CHECK(err_code);*/ memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the GATT module. */ static void gatt_init(void) { ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL); APP_ERROR_CHECK(err_code); } /**@brief Function for handling Queued Write Module errors. * * @details A pointer to this function will be passed to each service which may need to inform the * application about an error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for handling the YYY Service events. * YOUR_JOB implement a service handler function depending on the event the service you are using can generate * * @details This function will be called for all YY Service events which are passed to * the application. * * @param[in] p_yy_service YY Service structure. * @param[in] p_evt Event received from the YY Service. * * static void on_yys_evt(ble_yy_service_t * p_yy_service, ble_yy_service_evt_t * p_evt) { switch (p_evt->evt_type) { case BLE_YY_NAME_EVT_WRITE: APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str); break; default: // No implementation needed. break; } }*/ /**@brief Function for handling the Custom Service Service events. * @details This function will be called for all Custom Service events which are passed to the application. * @param[in] p_cus_service Custom Service structure. * @param[in] p_evt Event received from the Custom Service. */ static void on_cus_evt(ble_cus_t * p_cus_service, ble_cus_evt_t * p_evt) { ret_code_t err_code; switch(p_evt->evt_type) { case BLE_CUS_EVT_NOTIFICATION_ENABLED: err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL); APP_ERROR_CHECK(err_code); break; case BLE_CUS_EVT_NOTIFICATION_DISABLED: err_code = app_timer_stop(m_notification_timer_id); APP_ERROR_CHECK(err_code); break; case BLE_CUS_EVT_CONNECTED: break; case BLE_CUS_EVT_DISCONNECTED: break; default: // No implementation needed. break; } } /**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { ret_code_t err_code; nrf_ble_qwr_init_t qwr_init = {0}; ble_cus_init_t cus_init = {0};/*new*/ // Initialize Queued Write Module. qwr_init.error_handler = nrf_qwr_error_handler; err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); APP_ERROR_CHECK(err_code); // Initialize CUS Service init structure to zero. cus_init.evt_handler = on_cus_evt; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm); err_code = ble_cus_init(&m_cus, &cus_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module which * are passed to the application. * @note All this function does is to disconnect. This could have been done by simply * setting the disconnect_on_fail config parameter, but instead we use the event * handler mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { ret_code_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } } /**@brief Function for handling a Connection Parameters error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { ret_code_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = on_conn_params_evt; cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for starting timers. */ static void application_timers_start(void) { /* YOUR_JOB: Start your timers. below is an example of how to start a timer. ret_code_t err_code; err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL); APP_ERROR_CHECK(err_code); */ } /**@brief Function for putting the chip into sleep mode. * * @note This function will not return. */ static void sleep_mode_enter(void) { ret_code_t err_code; err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Prepare wakeup buttons. err_code = bsp_btn_ble_sleep_mode_prepare(); APP_ERROR_CHECK(err_code); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling advertising events. * * @details This function will be called for advertising events which are passed to the application. * * @param[in] ble_adv_evt Advertising event. */ static void on_adv_evt(ble_adv_evt_t ble_adv_evt) { ret_code_t err_code; switch (ble_adv_evt) { case BLE_ADV_EVT_FAST: NRF_LOG_INFO("Fast advertising."); err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); APP_ERROR_CHECK(err_code); break; case BLE_ADV_EVT_IDLE: sleep_mode_enter(); break; default: break; } } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { ret_code_t err_code = NRF_SUCCESS; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected."); // LED indication will be changed when advertising starts. break; case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected."); err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("GATT Client Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("GATT Server Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; default: // No implementation needed. break; } } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { ret_code_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } /**@brief Function for the Peer Manager initialization. */ static void peer_manager_init(void) { ble_gap_sec_params_t sec_param; ret_code_t err_code; err_code = pm_init(); APP_ERROR_CHECK(err_code); memset(&sec_param, 0, sizeof(ble_gap_sec_params_t)); // Security parameters to be used for all security procedures. sec_param.bond = SEC_PARAM_BOND; sec_param.mitm = SEC_PARAM_MITM; sec_param.lesc = SEC_PARAM_LESC; sec_param.keypress = SEC_PARAM_KEYPRESS; sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES; sec_param.oob = SEC_PARAM_OOB; sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE; sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE; sec_param.kdist_own.enc = 1; sec_param.kdist_own.id = 1; sec_param.kdist_peer.enc = 1; sec_param.kdist_peer.id = 1; err_code = pm_sec_params_set(&sec_param); APP_ERROR_CHECK(err_code); err_code = pm_register(pm_evt_handler); APP_ERROR_CHECK(err_code); } /**@brief Clear bond information from persistent storage. */ static void delete_bonds(void) { ret_code_t err_code; NRF_LOG_INFO("Erase bonds!"); err_code = pm_peers_delete(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling events from the BSP module. * * @param[in] event Event generated when button is pressed. */ static void bsp_event_handler(bsp_event_t event) { ret_code_t err_code; switch (event) { case BSP_EVENT_SLEEP: sleep_mode_enter(); break; // BSP_EVENT_SLEEP case BSP_EVENT_DISCONNECT: err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } break; // BSP_EVENT_DISCONNECT case BSP_EVENT_WHITELIST_OFF: if (m_conn_handle == BLE_CONN_HANDLE_INVALID) { err_code = ble_advertising_restart_without_whitelist(&m_advertising); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } } break; // BSP_EVENT_KEY_0 default: break; } } /**@brief Function for initializing the Advertising functionality. */ static void advertising_init(void) { ret_code_t err_code; ble_advertising_init_t init; memset(&init, 0, sizeof(init)); init.advdata.name_type = BLE_ADVDATA_FULL_NAME; init.advdata.include_appearance = true; init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); init.advdata.uuids_complete.p_uuids = m_adv_uuids; init.config.ble_adv_fast_enabled = true; init.config.ble_adv_fast_interval = APP_ADV_INTERVAL; init.config.ble_adv_fast_timeout = APP_ADV_DURATION; init.evt_handler = on_adv_evt; err_code = ble_advertising_init(&m_advertising, &init); APP_ERROR_CHECK(err_code); ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG); } /**@brief Function for initializing buttons and leds. * * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up. */ static void buttons_leds_init(bool * p_erase_bonds) { ret_code_t err_code; bsp_event_t startup_event; err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler); APP_ERROR_CHECK(err_code); err_code = bsp_btn_ble_init(NULL, &startup_event); APP_ERROR_CHECK(err_code); *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA); } /**@brief Function for initializing the nrf log module. */ static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing power management. */ static void power_management_init(void) { ret_code_t err_code; err_code = nrf_pwr_mgmt_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the idle state (main loop). * * @details If there is no pending log operation, then sleep until next the next event occurs. */ static void idle_state_handle(void) { if (NRF_LOG_PROCESS() == false) { nrf_pwr_mgmt_run(); } } /**@brief Function for starting advertising. */ static void advertising_start(bool erase_bonds) { if (erase_bonds == true) { delete_bonds(); // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event } else { ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); } } /**@brief Function for application main entry. */ int main(void) { bool erase_bonds; // Initialize. log_init(); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); ble_stack_init(); gap_params_init(); gatt_init(); services_init(); /*new*/ advertising_init(); //services_init(); conn_params_init(); peer_manager_init(); // Start execution. NRF_LOG_INFO("Template example started."); application_timers_start(); advertising_start(erase_bonds); // Enter main loop. for (;;) { idle_state_handle(); } } /** * @} */
