SAADC scans only one sample
I am developing a solution that measures values on 2 AIN channels in scan mode with the following setup:
- differential mode
- no oversampling
- no burst mode
- 10 bit precision
- resistors disabled
The channels are configured standard way using nrf_drv_saadc_channel_init() and nrf_drv_saadc_buffer_convert(). I start conversion by calling nrf_drv_saadc_sample() and set low power mode. This I understood to run several scan samples until buffer lasts.
The callback function checks for p_event->type == NRF_DRV_SAADC_EVT_DONE, makes nrf_drv_saadc_buffer_convert() and copies measured values to a separate array for further processing outside of the callback. I am not doing calibration at this stage, as it requires scan to work.
The problem I am facing is that the callback function is called always when only 1 set of samples is done, i.e. 1 sample for each channel. Regardless of what size buffer I set (tried 2x10, 2x20, 2x30 size).
I want to note that nrf_drv_saadc_sample() is triggered from RTC2 timer interrupt handler, setup for 2 kHz frequency of calls.
I would like to know why I am not getting s full scan of those 2 channels through the whole buffer.
I am using nRF 52832, custom design, also DK PCA10040, SDK 14.2 and SD 132, v5.0.0.
What else I forgot to set for running the scan mode / what can block the scan mode to work? Is the scan mode supported under SD? According to the SD documentation open for SAADC.
Any advice is very much appreciated.
Thanx.
peter
