Startup Troubles on Dev Kit
I was able one time to power up the nRF9160 dev kit and see it connect to the cellular network and to nRF Cloud. Since then, it will only blink LED3, which indicates that it can't connect. I would like to re-flash the firmware, but I'm totally lost in all the circular links in the documentation. I have used the nRF52832 dev kit extensively so I'm quite familiar with the process, but it appears the nRF9160 dev kti adds several more layers of complexity. I would like to be able to load a simple "hello world" application, and then build on that with my application source code. Please guide me to some concise documentation.
  • 1. The Segger Embedded Studio Nordic Edition zip should contain all the necessary parts, and installing a package should not be necessary. I have never encountered that message before, and from the path mentioned in the pop-up, it does not look like you are using the Nordic Edition of SES. Can you confirm that you are using the correct SES version?
    If I "continue" as you suggest below, I do not get the Nordic version. If I do as I have been doing all along, and re-activate my license every time I open SES, I clearly get the Nordic version as this screenshot shows. Could there be a connection here? Also, note that my legal company name includes a comma, but the activation will not accept a comma in the company name so I must compromise and leave out the comma.
    2. I just tried to set up NCS on two different Linux VMs and encountered your license issue on one of them until I was able to open one of our example projects. For now, you should be able to simply press "continue", while we sort out your other issues.
    See above.
    3. Can you send me a screenshot of the "nRF Connect" tab of SES's options window, as well as the content of the folder, pointed to by the "GNU ARM Embedded Toolchain Directory" setting?
    Note that all locations etc. were guided by the nRF Connect Getting Started Assistant.
  • 1. On my Linux VM, I got the Nordic Edition also when pressing continue. I do not know of any other solution, but what I did was simply to type a single letter into every box (except for email, which must look like an email, e.g., [email protected]), and use an old license. It is obviously not a very good workaround, but that is the best I have at the moment.
    3. The "GNU ARM Embedded Toolchain Directory" is wrong. It should point to the folder where you installed the toolchain, i.e., compiler. The default path I got from the installer was: C:\Program Files (x86)\GNU Tools Arm Embedded\7 2018-q2-update. If you followed the recommendation from the Getting Started Assistant, it would be in C:\gnuarmemb. Regardless, the content of the folder should be:
  • David Martin stepped in to help, but he's traveling today so asked that I come back to this ticket. So here's the update. We went back and started over with the Getting Started Assistant. Step 1 of the 4 steps is complete and appears successful. In step 2 "Clone the nRF Connect SDK", the first 3 subparts are complete. In the 4th part, installing Python modules, the very first install command is
    pip3 install -r zephyr\scripts\requirements.txt
    That results in an error message that David was unable to handle immediately. Here's the screen dump from the command box:
    11:39:42.08 d:\296\FW\ncs> pip3 install -r zephyr\scripts\requirements.txt
    Collecting wheel==0.30.0 (from -r zephyr\scripts\requirements.txt (line 1))
      Using cached https://files.pythonhosted.org/packages/0c/80/16a85b47702a1f47a63c104c91abdd0a6704ee8ae3b4ce4afc49bc39f9d9/wheel-0.30.0-py2.py3-none-any.whl
    Collecting breathe==4.9.1 (from -r zephyr\scripts\requirements.txt (line 2))
      Using cached https://files.pythonhosted.org/packages/2c/a5/040234179dc9140be4a1cb4350af362327d001d0ca7e5bba4d580916ceb4/breathe-4.9.1-py2.py3-none-any.whl
    Collecting sphinx==1.7.5 (from -r zephyr\scripts\requirements.txt (line 3))
      Using cached https://files.pythonhosted.org/packages/1b/9f/98d67201c5a6e1aececed03a44a819d0e32adba81414081e303cfaf8c54c/Sphinx-1.7.5-py2.py3-none-any.whl
    Collecting docutils==0.14 (from -r zephyr\scripts\requirements.txt (line 4))
      Using cached https://files.pythonhosted.org/packages/36/fa/08e9e6e0e3cbd1d362c3bbee8d01d0aedb2155c4ac112b19ef3cae8eed8d/docutils-0.14-py3-none-any.whl
    Collecting sphinx_rtd_theme (from -r zephyr\scripts\requirements.txt (line 5))
      Using cached https://files.pythonhosted.org/packages/60/b4/4df37087a1d36755e3a3bfd2a30263f358d2dea21938240fa02313d45f51/sphinx_rtd_theme-0.4.3-py2.py3-none-an
    y.whl
    Collecting sphinxcontrib-svg2pdfconverter (from -r zephyr\scripts\requirements.txt (line 6))
      Using cached https://files.pythonhosted.org/packages/79/83/d712a25303429570c641caa113d1282c27012bbd4157417d07829947a549/sphinxcontrib_svg2pdfconverter-1.0.1-p
    y3-none-any.whl
    Collecting junit2html (from -r zephyr\scripts\requirements.txt (line 7))
      Using cached https://files.pythonhosted.org/packages/69/93/f2ccef1136dba078dada0513c324bad9ffd2be9236229d09bce71e1338a8/junit2html-022.tar.gz
    Requirement already satisfied: PyYAML>=3.13 in c:\python37\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 8)) (4.2b4)
    Collecting ply==3.10 (from -r zephyr\scripts\requirements.txt (line 9))
      Using cached https://files.pythonhosted.org/packages/ce/3d/1f9ca69192025046f02a02ffc61bfbac2731aab06325a218370fd93e18df/ply-3.10.tar.gz
    Collecting hub==2.0 (from -r zephyr\scripts\requirements.txt (line 10))
      ERROR: Could not find a version that satisfies the requirement hub==2.0 (from -r zephyr\scripts\requirements.txt (line 10)) (from versions: 0.0.1, 0.1.0, 0.1.
    1, 0.1.2, 0.1.3, 0.1.4, 0.1.5, 0.1.6, 0.2, 0.2.0.1, 0.2.0.3, 0.2.0.4)
    ERROR: No matching distribution found for hub==2.0 (from -r zephyr\scripts\requirements.txt (line 10))
    11:40:06.99 d:\296\FW\ncs>
    Your serve...... ;-)
  • That is a known problem and has been fixed on the master branch.
    What has happened is this:
    The hub python module that is used by Zephyr has changed the name to git-spindle. Then, a new module was created with the name hub. If you edit the name of the package in the requirements file to "git-spindle", it should work.
    Sadly, bugfixes like this have not been backported to the v1.0.0 release.
  • Do I need to just go back and start over? Your message above was not very clear, but I replaced "hub" in Requirements.txt in the Zephyr directory and it seems to be a little happier. However, there's still a red error message (boldface below) in the resulting text:
    Requirement already satisfied: asn1crypto>=0.21.0 in c:\python37\lib\site-packages (from cryptography>=1.5->jwcrypto>=0.5.0->github3.py>=0.8.2->git-spindle==2.0
    ->-r zephyr\scripts\requirements.txt (line 10)) (0.24.0)
    Requirement already satisfied: pycparser in c:\python37\lib\site-packages (from cffi!=1.11.3,>=1.8->cryptography>=1.5->jwcrypto>=0.5.0->github3.py>=0.8.2->git-s
    pindle==2.0->-r zephyr\scripts\requirements.txt (line 10)) (2.19)
    ERROR: pyocd 0.19.0 has requirement pyyaml<6.0,>=5.1, but you'll have pyyaml 4.2b4 which is incompatible.
    Installing collected packages: wheel, docutils, sphinxcontrib-websupport, sphinx, breathe, sphinx-rtd-theme, sphinxcontrib-svg2pdfconverter, junit2html, ply, jw
    crypto, uritemplate, github3.py, whelk, git-spindle, arrow, gitlint, pyelftools, websocket-client, sortedcontainers, intervaltree, pyusb, pywinusb, pyocd, windo
    ws-curses, Pillow, more-itertools, zipp, importlib-metadata, pluggy, wcwidth, py, atomicwrites, pytest
      Found existing installation: docutils 0.15.2
        Uninstalling docutils-0.15.2:
          Successfully uninstalled docutils-0.15.2
      Found existing installation: Sphinx 2.2.0
        Uninstalling Sphinx-2.2.0:
          Successfully uninstalled Sphinx-2.2.0
      Running setup.py install for junit2html ... done
      Running setup.py install for ply ... done
      Running setup.py install for whelk ... done
      Running setup.py install for git-spindle ... done
      Running setup.py install for pyelftools ... done
      Running setup.py install for intervaltree ... done
      Running setup.py install for pyusb ... done
      Running setup.py install for pywinusb ... done
      Running setup.py install for pyocd ... done
    Successfully installed Pillow-6.1.0 arrow-0.14.2 atomicwrites-1.3.0 breathe-4.9.1 docutils-0.14 git-spindle-2.0 github3.py-1.3.0 gitlint-0.12.0 importlib-metada
    ta-0.23 intervaltree-3.0.2 junit2html-22 jwcrypto-0.6.0 more-itertools-7.2.0 pluggy-0.13.0 ply-3.10 py-1.8.0 pyelftools-0.24 pyocd-0.19.0 pytest-5.1.3 pyusb-1.0
    .2 pywinusb-0.4.2 sortedcontainers-2.1.0 sphinx-1.7.5 sphinx-rtd-theme-0.4.3 sphinxcontrib-svg2pdfconverter-1.0.1 sphinxcontrib-websupport-1.1.2 uritemplate-3.0
    .0 wcwidth-0.1.7 websocket-client-0.56.0 wheel-0.30.0 whelk-2.7.1 windows-curses-2.0.1 zipp-0.6.0
    10:17:04.11 d:\296\FW\ncs>
