What is the operating and storage temperature range of nRF52840-DK development kit and USB dongle? We need to use these evaluation boards at a temperature range of -20 to +80 degree, Is this ok?
Thanks. I have already checked BOM, many components supports wide temp range but few like crystals does not support.
Looking at the BOM I haven't found any components that doesn't support the temperature range you require.
Could you please specify which components you found that doesn't support the temperature range?
Joakim
Hi Joakim,
The Crystal part 7M-12.000MAAJ-T supports only -20 to +70, the last 'A' in the part number specifies -20 to +70ºC.
Thanks.
So that answers your question, then?
Well, according to the datasheet the operating temperature range is -40 - +85ºC. So it is physically capable of handling those temperatures.
However, the frequency stability of can only be guaranteed in the temperature range of -20 to +70ºC.
So for the temperature range outside the defined range there could be some unwanted behavior. I think the 16Mhz could cause some abnormal behavior on the USB connection/debuggging capabilites of the DK.
Joakim
