Numerous errors compiling nrf_log_frontend.c
I wasn't receiving any log messages while debugging the ble_app_uart_c example using SES so I enabled appropriate logging functions and set them to level 4 in config.h.  Still didn't get any log messages so I added NRF_LOG_INFO() after the #defines section in main.c.
Compiler is flagging many, many errors such as:
                #define LOG_INTERNAL_X(N, ...) CONCAT_2(LOG_INTERNAL_, N), (__VA_ARGS__)       'LOG_INTERNAL_0' undeclared (first use in this function); did you mean 'LOG_INTERNAL_2'?
and:
                #define LOG_INTERNAL_X(N, ...) CONCAT_2(LOG_INTERNAL_, N), (__VA_ARGS__)       expected expression before ')' token
I've been able to eliminate some errors simply by retyping the code but others keep popping up with each successive run.
Please advise.
