NRF9160 FOTA not switching to secondary after boot_request_upgrade() and sys_reboot()
In our firmware we're writing the entire contents of our UPDATE.BIN file successfully with flash_img_buffered_write's, but after boot_request_upgrade and a sys_reboot, it is still loading the original firmware from FLASH_AREA_IMAGE_PRIMARY rather than secondary. Our updated firmware has an higher hardcoded version string that we printk for verification.
We're using the latest V1.0.0 tag, 1.0.1 modem firmware, etc. CONFIG_BOOTLOADER_MCUBOOT=y is all properly set, etc.
Any pointers?
Thx!
  • Hi GJSea,
    I'm sorry for late response. I have forwarded the case to our MCUBoot team and will get back to you asap.
  • Hi again GJSea,
    When doing our investigation we came across this case : https://github.com/zephyrproject-rtos/zephyr/issues/19438
    It looks quite similar to your issue. But, I don't think t's the same. The case was about booting via the image on QSPI when in your case it's the internal slot .
    But it could be related, we need to have a look at how you erase slot 2 prior to the swap.
    Have you defined CONFIG_IMG_ERASE_PROGRESSIVELY = y (or SELECT it )
    It's selected inside fota_download\Kconfig file in our http applicatoin update example .
    If CONFIG_IMG_ERASE_PROGRESSIVELY  is not selected, you would need to do a boot_erase_img_bank() before flash_img_init()
  • Hi Hung,
    Yes CONFIG_IMG_ERASE_PROGRESSIVELY was defined properly, I also added boot_erase_img_bank for good measure. However after that MCU_BOOT won't even load from the PRIMARY slot:
    bootutil_img_validate() fails in comparing the hash at
    if (memcmp(hash, buf, sizeof(hash))) {
    return -1;
    Segger properly downloads the firmware image to the device as clearly I'm debugging MCUBOOT, can you provide guidance on how to restore booting the PRIMARY slot, so we can continue further in diagnosis?
    Thanks!
    I'm a bit out of idea on what could be wrong. We may need to have your code to reproduce the issue here. The problem is that we may not have the SPI external flash as you have in your setup.
    If you can modify the code to copy from internal flash to slot 2 so we can test on a standalone board it would be great.
    One thing you can do also is to read the hex dump and check if the update.bin image matched with what copied to slot 2. I understand that you have the CRC check but it could be offset. If possible can you send us the hex dump right after the FOTA ?
    Regarding the check inside boot_validate_slot() here is the explanation from the team:
    >   if (boot_check_header_erased(slot) == 0 || (hdr->ih_flags & IMAGE_F_NON_BOOTABLE)) {
    Check if the magic field in image header is erased or non-bootable flag is set – this will be satisfied if for instance header structure is erased (this is my suspicion). Looks like what is written to the image slot is not the same as in update.bin, or with a offset.
  • Hi Hung,
    I figured the problem out, I was using NVS in our firmware app without changing nvs_fs.offset to PM_MCUBOOT_STORAGE_ADDRESS which was somehow corrupting the written secondary firmware. Now it it working nicely.
    Thanks for your help in aiding me narrowing it down.
    Thx!
