Nordic provide a BLE USB dongle for applications running on a PC?
Does Nordic provide a BLE functionality with a USB dongle that a PC application can use? I do NOT want to use the Windows 10 BLE as it is buggy and does not provide the low level control I need. I am writing an extensive health device BLE test suite for centrals and I do not want to download HEX files onto a chip for each test. What is needed is to call the BLE APIs from the PC application and get signaled of BLE events in the PC application. I am thinking Visual Studio 19 using C or C++. I am forced to select things in the product and I will pick something at random. I have no idea which one will do. Pretty stupid requirement on Nordic's part.
  • I have the dongles and have got the segger installed and the dongle recognized. nRF connect tool is installed. Looked at  this tutorial but do not see how to install the pre-compiled HEX files I downloaded. All I get is the option to install a cental/client app on the dongle.
    Is it SoftDevice I am trying to install? One of these files
    connectivity_4.1.1_usb_with_s140_6.1.1.hex
    perhaps? (There are 4 hex files each in four directories. They are the only HEX files I could find. How do I get the nRF Connect tool to install these HEX files onto the dongle (assuming they are what I want). Of the selection is large; there are 12 to choose from.
  • "connectivity_4.1.1_usb_with_s140_6.1.1.hex" should be the correct hex file. You can also choose one for an older softdevice API (v3, v5), but these will not provide all the available features that the latest softdevice does.
    I'm not sure what you mean by "cental/client app". You installed nRF Connect for Desktop, installed and launched the "Programmer app" inside nRF Connect, pressed the side-button on the Dongle (the LED should be pulsating in red color), selected the dongle from the drop-down list in the upper left corner? When you have done this, you should be able to browse to the hex-file location by pressing "Add HEX file", and then click "Write" to write the application to the dongle.
  • My dongle has no side button but it does have a white button next to the MCU on the opposite side of the MCU of the flashing red LED. I assume that's the button you mean.
    No I did not do those steps. I did not find those in a way I understood them to apply to my use case (I was scared of doing damage.). BUt I just did it and it worked. The LED flashed in funny ways as the write was being done and a green LED flashed in a different location (I am assuming it means success) and now the dongle is back to flashing red. I am saving this set of steps. If this actually allows me to code and run C-based BLE apps on my PC, this was incredibly easy!
    By the way, nfrConnect got installed in my AppData/Local/ Programs directory. I'm not sure how. Can I just move that entire nrfconnect directory somewhere else or must I uninstall and reinstall and keep close track of where I can make the move to install it in a location of my choice.
    I just found out that the reset button is the little tiny thing next to SW1 (the white button). I pushed the white button and not the reset button, Yet it seemed to work. Don't know if it is all messed up or what. Perhaps I should re-do?
    These are the steps I finally took (except I did not press the reset button - I pressed SW1)
    Configure the nRF52840 dongle to access its BLE functionality from a PC application
    • Download the driver from here: github.com/.../v4.1.1 Its just a zip file. Just unzip it. No installation needed.
    • Download the nRF Connect for Desktop application here: www.nordicsemi.com/.../nRF-Connect-for-desktop This will download a setup executable nrfconnectsetup320ia32.exe. Even though it says '32' its for both 32 and 64 bit machines.
    •  Run the nrfconnectsetup320ia32 setup program.
    •  Download Segger Jlink software here: www.segger.com/.../. It will look like this: JLink_Windows_V652a.exe. Run the installer.
    • Plug in the dongle - a red LED should flash.
    • Open nRF Connect for Desktop. You will see 'APPS' and 'SETTINGS' in the title bar. Be sure 'APPS' is selected
    • Scroll down to 'Programmer'. In my case it was second in the list of choices so I didn't have to scroll.
    • Click the 'Install' button (it will then be 'Open' when re-visited). A new window will popup.
    • On the dongle press the reset button to put it into programmable mode (DFU mode) - I think DFU means Device Firmware Update but I am not sure. Note that the reset button is the tiny button on the side of the 'reset' unit next to the big white SW1 button. You can see the reset unit pictured here: infocenter.nordicsemi.com/index.jsp - Note the button is very tiny and not so obvious!
    • In the nRF Connect Desktop program's new popup window select the device from the drop down window in the title bar.
    • Click on 'Add Hex file' in the selections on the right hand side.
    • Navigate to the appopriate HEX file where the driver was unzipped and select it. In my case located here: nrf-ble-driver-4.1.1-win_x86_64\share\nrf-ble-driver\hex\sd_api_v6\connectivity_4.1.1_usb_with_s140_6.1.1.hex
    • Now select the 'Write' option from the list on the right hand side. The LEDs should flash and eventually the green LED will flash. At the bottom of the Desktop app will be a display of the progress. When all done the last row should say 'DFU for SoftDevice completed successfully!'
  • The developers tell me that the install location for nRF Connect is hardcoded and cannot be modified during install. Trying to move the application will probably break some paths used by the application.
  • I would have to agree; I tried the above process on a 'clean' system and could not stop it from installing in AppData. I suppose I could try to just move it and see if it still works ....
    At this point I have gotten as far as trying to build the heart rate monitor sample app in Visual Studio. However, I get 16 unresolved symbol errors ... all ble related like the project cannot find the library or I am missing a library that is not included in the  downloadable releases.
