Not able to wake the board from deep sleep(System off)
I am very new to Nordic products so please excuse my ignorance.I have been trying to put my nrf52840 board to deep sleep. It seems to go to sleep but when I try to wake it up by pushing the buttons, it doesn't wake up.
This is how  I modified Ble_app_blinky_c, I added sleep_mode_enter(){}, buttons_leds_init(){}, and bsp_event_handler(bsp_event_t event){} from Ble app template . And then I am calling buttons_leds_init  and sleep_mode_enter in Main.c.Basically I want the board to be in deep sleep at all times and wake up only when I push the buttons.
I have included my project below.
What I am doing wrong?
Thank you in advanceble_app_blinky_c.zip
  • Hi David
    Were you able to save the conn_handle and use it for disconnection? Could you post your current main.c file so I can get a better overview of how you're handling the various events?
    I was initially thinking that you post go to sleep when the button_event_handler is done, your device has disconnected successfully and goes back into the main() function, as that would set a definitive end, making the code easier to read. But I'd like to get a look to see if that makes any sense in this case.
    Simon
  • Hi Simon
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE LED Button Service central and client application main file.
     * This file contains the source code for a sample client application using the LED Button service.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_timer.h"
    #include "boards.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_db_discovery.h"
    #include "ble_lbs_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0                     /**< Scanning LED will be on when the device is scanning. */
    #define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1                     /**< Connected LED will be on when the device is connected. */
    #define LEDBUTTON_LED                   BSP_BOARD_LED_2                     /**< LED to indicate a change of state of the the Button characteristic on the peer. */
    #define SCAN_INTERVAL                   0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                     0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION                   0x0000                              /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL         MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY                   0                                   /**< Determines slave latency in terms of connection events. */
    #define SUPERVISION_TIMEOUT             MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Determines supervision time-out in units of 10 milliseconds. */
    #define LEDBUTTON_BUTTON_PIN            BSP_BUTTON_0                        /**< Button that will write to the LED characteristic of the peer */
    #define LEDBUTTON_BUTTON_PIN2           BSP_BUTTON_1
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                 /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define APP_BLE_CONN_CFG_TAG            1                                   /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO           3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    NRF_BLE_SCAN_DEF(m_scan);                                       /**< Scanning module instance. */
    BLE_LBS_C_DEF(m_ble_lbs_c);                                     /**< Main structure used by the LBS client module. */
    NRF_BLE_GATT_DEF(m_gatt);                                       /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                /**< DB discovery module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;
    static char const m_target_periph_name[] = "Nordic_Blinky";     /**< Name of the device we try to connect to. This name is searched in the scan report data*/
    /**@brief Function to handle asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function to start scanning.
    static void scan_start(void)
        ret_code_t err_code;
        err_code = nrf_ble_scan_start(&m_scan);
        bsp_board_led_off(CENTRAL_CONNECTED_LED);
        bsp_board_led_on(CENTRAL_SCANNING_LED);
    /**@brief Handles events coming from the LED Button central module.
    static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
        NRF_LOG_INFO("p_lbs_c_evt->params.peer_db.led_handle2 %d", p_lbs_c_evt->params.peer_db.led_handle2);
        NRF_LOG_INFO("p_lbs_c_evt->params.peer_db.led_handle %d", p_lbs_c_evt->params.peer_db.led_handle);
        NRF_LOG_INFO("p_lbs_c->peer_lbs_db.led_handle2: %d", p_lbs_c->peer_lbs_db.led_handle2);
        NRF_LOG_INFO("p_lbs_c->peer_lbs_db.led_handle: %d", p_lbs_c->peer_lbs_db.led_handle);
        switch (p_lbs_c_evt->evt_type)
            case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c,
                                                    p_lbs_c_evt->conn_handle,
                                                    &p_lbs_c_evt->params.peer_db);
                NRF_LOG_INFO("LED Button service discovered on conn_handle 0x%x.", p_lbs_c_evt->conn_handle);
                err_code = app_button_enable();
                // LED Button service discovered. Enable notification of Button.
                err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
            } break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
            case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
                NRF_LOG_INFO("Button state changed on peer to 0x%x.", p_lbs_c_evt->params.button.button_state);
                if (p_lbs_c_evt->params.button.button_state)
                    bsp_board_led_on(LEDBUTTON_LED);
                    bsp_board_led_off(LEDBUTTON_LED);
            } break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
                // No implementation needed.
        // Prepare wakeup buttons.
        // For readability.
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            // Upon connection, check which peripheral has connected (HR or RSC), initiate DB
            // discovery, update LEDs status and resume scanning if necessary. */
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
                err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
                 m_conn_handle = p_gap_evt->conn_handle;
                // Update LEDs status, and check if we should be looking for more
                // peripherals to connect to.
                bsp_board_led_on(CENTRAL_CONNECTED_LED);
                bsp_board_led_off(CENTRAL_SCANNING_LED);
            } break;
            // Upon disconnection, reset the connection handle of the peer which disconnected, update
            // the LEDs status and start scanning again.
                NRF_LOG_INFO("Disconnected.");
                scan_start();
            } break;
            case BLE_GAP_EVT_TIMEOUT:
                // We have not specified a timeout for scanning, so only connection attemps can timeout.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_DEBUG("Connection request timed out.");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            } break;
            case BLE_GATTS_EVT_TIMEOUT:
            } break;
    /**@brief LED Button client initialization.
    static void lbs_c_init(void)
        ble_lbs_c_init_t lbs_c_init_obj;
        lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
        err_code = ble_lbs_c_init(&m_ble_lbs_c, &lbs_c_init_obj);
     * @details Initializes the SoftDevice and the BLE event interrupts.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                NRF_LOG_INFO("Button 1 is pressed");
                err_code = ble_lbs_led_status_send(&m_ble_lbs_c, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE)
                if (err_code == NRF_SUCCESS)
                    NRF_LOG_INFO("LBS write LED state %d", button_action);
                   //sd_ble_gap_disconnect(m_conn_handle,BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
                    //sleep_mode_enter();
           case LEDBUTTON_BUTTON_PIN2:
                NRF_LOG_INFO("Button 2 is pressed");
                err_code = ble_lbs_led_status_send2(&m_ble_lbs_c, button_action);
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for handling Scaning events.
     * @param[in]   p_scan_evt   Scanning event.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle,
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
    static void buttons_leds_init()
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    //    err_code = bsp_btn_ble_init(NULL, &startup_event);
    //    APP_ERROR_CHECK(err_code);
    //    *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler},
            {LEDBUTTON_BUTTON_PIN2, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                  BUTTON_DETECTION_DELAY);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_lbs_on_db_disc_evt(&m_ble_lbs_c, p_evt);
    /**@brief Database discovery initialization.
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    /**@brief Function for initializing the log.
    static void log_init(void)
    /**@brief Function for initializing the timer.
    static void timer_init(void)
    /**@brief Function for initializing the Power manager. */
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        // Setting filters for scanning.
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
        NRF_LOG_FLUSH();
        nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        leds_init();
        buttons_init();
        //buttons_leds_init(); //Copied this from another example
        power_management_init();
        ble_stack_init();
        scan_init();
        gatt_init();
        db_discovery_init();
        lbs_c_init();
        // Start execution.
        NRF_LOG_INFO("Blinky CENTRAL example started.");
        scan_start();
        // Turn on the LED to signal scanning.
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Yes, I was able to save the conn_handle. I have attached my current main.c below.
  • Hi David
    Seeing as you want the application to go to sleep after a transfer is complete, you should make the central disconnect from the peripheral when the data transfer between them is complete. So after that operation is complete/successful, you should call sd_ble_gap_disconnect in the BLE_GAP_EVT_CONNECTED case in ble_evt_handler(). Then, after you have disconnected successfully, you should go to sleep using the sleep_mode_enter() function, as this function prepares wake-up buttons for you so that the device will wake up if you press any buttons.
    I also suggest that you put in a logger message or similar in order to see that the connection, data transfer, and disconnection events are successful, using a terminal and NRF_LOG_INFO or something similar.
    Simon
  • Hi Simon
    My understanding is BLE_GAP_EVT_CONNECTED case will be only executed the first time when the board is connected to the peer device.After I push the button to send the data, the BLE_GAP_EVT_CONNECTED event won't be triggered again. Correct me if I am wrong or maybe I misunderstood you.In short, that didn't work for me.
  • Hi
    If you go to system OFF mode after disconnecting, you will have to connect to the peripheral device again upon wake up, which should trigger the BLE_GAP_EVT_CONNECTED event. Was it not the intention that you wanted to go to system OFF between data transfers?
    Simon
