Developing Beacon and Scanner using nrf52 dongle & nrf52840 DK respectively
HI as i am new to nrf nordic semiconductor development i have some quetsions regarding application im developing
I am trying to develop Ble application where nRF 52 will be the beacon and nRF 52840 DK will be the scanner module.
1.I have used nRF_SDK_15.3.0_59ac345/examples/ble_pheripheral/ble_app_beacon/pca10056/s140 program form nRF 52 dongle to operate it as a beacon when code is uploaded device gets detected on mobile nrf beacon app..and also by using printf i can varify the data which is being transmitted by beacon..
2.Second thing is i have nRF 52840 DK which i want to use it as a scanner for beacons (nRF52 dongles) .when beacons come in range of scanner it should detect the beacons and advertise      the report accordinly in debug terminal.
   For scanner application i have tried using 3 codes
1.ble_app_multipheripheral_pca10056
2.ble_app_multilinkclient_pca10056
3.ble_app_uart_c_pca10056
I am not sure about which one will work properly.as far as i tried and tested multipheripheral worked ok with nrf blinky clients.
so i want help from your side in making nRf52840 as scanner using some modifications in this codes..and so that it can scan any no of beacons of nRF52 dongles.
  • ok thanks
    can you plz help me in building the below mentioned link code using nrf SDK 15.3 I want to know what changes i need to make in order to that code
    devzone.nordicsemi.com/.../nrf52832-switch-central-mode-to-peripheral-mode
    Can you link to the example itself and specify so I know exactly what you are trying to build? Also, which toolchain/IDE are you building with?
  • IDE im using SEGGER EMbedded Studio for ARM V4.22(64-bit)
    I am trying to build Beacon scanner application.Where nRF 52 dongles will be beacons and nRF 52840 DK as scanner to scan the advertising beacons in a particular range.
    the avobe link was provided to me in above thread only.
    I see. But where is the code you are trying to build, exactly?
     * beacon_scanner
     * Created by Manuel Montenegro, Sep 7, 2018.
     *  This is a Bluetooth 5 scanner. This code reads every advertisement from beacons
     *  and sends its data through serial port.
     *  This code has been developed for Nordic Semiconductor nRF52840 PDK.
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf_sdm.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_db_discovery.h"
    #include "ble_srv_common.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_util.h"
    #include "app_error.h"
    #include "ble_dis_c.h"
    #include "ble_rscs_c.h"
    #include "app_timer.h"
    #include "bsp_btn_ble.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "fds.h"
    #include "nrf_fstorage.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG        1                                   /**< Tag that identifies the BLE configuration of the SoftDevice. */
    #define APP_BLE_OBSERVER_PRIO       3                                   /**< BLE observer priority of the application. There is no need to modify this value. */
    #define APP_SOC_OBSERVER_PRIO       1                                   /**< SoC observer priority of the application. There is no need to modify this value. */
    #define SCAN_INTERVAL               0x0320                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                 0x0320                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION           	0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
    NRF_BLE_SCAN_DEF(m_scan);                                   /**< Scanning Module instance. */
    static bool                  m_memory_access_in_progress;   /**< Flag to keep track of ongoing operations on persistent memory. */
    static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
        .active        = 0x00,
        .interval      = SCAN_INTERVAL,
        .window        = SCAN_WINDOW,
        .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
        .timeout       = SCAN_DURATION,
    //    .scan_phys     = BLE_GAP_PHY_CODED,                                 // Choose only one of the following scan_phys
        .scan_phys     = BLE_GAP_PHY_1MBPS,
    //    .scan_phys     = BLE_GAP_PHY_2MBPS,
        .extended      = 1,
    static void scan_start(void);
            case BLE_GAP_EVT_ADV_REPORT:
                NRF_LOG_RAW_HEXDUMP_INFO (m_scan.scan_buffer.p_data, m_scan.scan_buffer.len);
                NRF_LOG_RAW_INFO ("----------------------------------\r\n");
     * @brief SoftDevice SoC event handler.
     * @param[in] evt_id    SoC event.
     * @param[in] p_context Context.
    static void soc_evt_handler(uint32_t evt_id, void * p_context)
        switch (evt_id)
            case NRF_EVT_FLASH_OPERATION_SUCCESS:
            /* fall through */
            case NRF_EVT_FLASH_OPERATION_ERROR:
                if (m_memory_access_in_progress)
                    m_memory_access_in_progress = false;
                    scan_start();
                // No implementation needed.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
        // Register handlers for BLE and SoC events.
        NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                NRF_LOG_INFO("Scan timed out.");
                scan_start();
            } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = false;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        init_scan.p_scan_param     = &m_scan_param;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    /**@brief Function for starting scanning.
        // If there is any pending write to flash, defer scanning until it completes.
        if (nrf_fstorage_is_busy(NULL))
            m_memory_access_in_progress = true;
            return;
        err_code = nrf_ble_scan_start(&m_scan);
    /**@brief Function for initializing logging. */
    static void log_init(void)
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        power_management_init();
        ble_stack_init();
        scan_init();
        // Start execution.
        NRF_LOG_RAW_INFO(    " ----------------\r\n");
        NRF_LOG_RAW_INFO(	 "| Beacon scanner |");
        NRF_LOG_RAW_INFO("\r\n ----------------\r\n");
        scan_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
