SPIS of nrf52 could not read the data accuracy
I am working with SPIS example ( sdk version 15.3). SPI master send data regulaly. For example, it sent 5ms cs low, but there are only two bytes transferred, the first byte at begin of 5ms, other one at the end. SPIS of nrf52  not read the second one, what can I do with it?
  • Hi, Edvin,
    I found something wrong using the logic analyzer.
    The problem was cause by the second cs signal, it's stay on high just take 3.5us which was too small than the others(34us).
    Is there any thing i can changed to solve the problem?
    BR,
    Xin
    According to the datasheet the minimum high of the CS/SS is 300ns, so 3.5us should really be fine.
    Are you using the following function to check whether the data is received?
    NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf);
    can you try the following:
            NRF_LOG_RAW_INFO("received string len %d, data: 0x", sizeof(m_rx_buf));
            for (uint8_t i=0; i<sizeof(m_rx_buf); i++)
                NRF_LOG_RAW_INFO("%02x:", m_rx_buf[i]);
            NRF_LOG_RAW_INFO("\n");
    I am sorry I can't give a concrete answer, but I don't have any HW capable of simulating your device. Please test this with the unmodified spis example, except for the printing of the string. I don't understand exactly how you handle the SPI events in the main file that you sent.
    BR,
    Edvin
  • I had tried unmodified spis again, only add the instructions you give to me, no any more changed, the second bytes was lost, and many bytes not printed in log info, but only the first was printed with server 0x00. i think maybe print log info take so much time, so some bytes was lost.
    I tried to store all data to a big buffer like the amount reached to 200 without printing any log info, i tried setup the break point when the 200 data had stored to the buffer, then to find the second bytes, result tell me i was fail again.
    So i can sure, your minimum high of the CS 300ns is wrong, because i can get the second byte with logic analyzer but the 52832 could not. Could you give me any advice?
  • Is it possible to save the file that this screenshot is from?
    I would like to measure some timings. It may be that the nRF doesn't have time to start the clocks. Can you try to enable the HCLK and keep it running? Does that change the behavior?
    BR,
    Edvin
  • Time[s], CS, MOSI, CLK
    0.000000000, 1, 0, 0
    0.035279500, 0, 0, 0
    0.035283320, 0, 0, 1
    0.035299280, 0, 1, 1
    0.035315260, 0, 0, 1
    0.035315280, 0, 0, 0
    0.035331240, 0, 1, 0
    0.035347220, 0, 0, 0
    0.035363200, 0, 1, 0
    0.035379160, 0, 0, 0
    0.035395140, 0, 1, 0
    0.035411140, 0, 0, 0
    0.035427100, 0, 1, 0
    0.035443080, 0, 0, 0
    0.035459060, 0, 1, 0
    0.035475040, 0, 0, 0
    0.035491020, 0, 1, 0
    0.035507000, 0, 0, 0
    0.035522980, 0, 1, 0
    0.035538960, 0, 0, 0
    0.039152900, 1, 0, 0
    0.039156380, 0, 0, 0
    0.039198400, 0, 1, 0
    0.039214380, 0, 0, 0
    0.039230360, 0, 1, 0
    0.039246340, 0, 0, 0
    0.039246360, 0, 0, 1
    0.039262320, 0, 1, 1
    0.039278300, 0, 0, 1
    0.039278320, 0, 0, 0
    0.039294280, 0, 1, 0
    0.039310260, 0, 0, 0
    0.039326240, 0, 1, 0
    0.039342200, 0, 0, 0
    0.039358200, 0, 1, 0
    0.039374180, 0, 0, 0
    0.039390160, 0, 1, 0
    0.039406140, 0, 0, 0
    0.039422120, 0, 1, 0
    0.039438100, 0, 0, 0
    0.039553360, 1, 0, 0
    0.039587580, 0, 0, 0
    0.039613860, 0, 1, 0
    0.039629840, 0, 0, 0
    0.039645820, 0, 1, 0
    0.039661800, 0, 0, 0
    0.039661820, 0, 0, 1
    0.039677780, 0, 1, 1
    0.039693760, 0, 0, 1
    0.039709740, 0, 1, 1
    0.039725720, 0, 0, 0
    0.039741680, 0, 1, 0
    0.039757660, 0, 0, 0
    0.039773660, 0, 1, 0
    0.039789640, 0, 0, 0
    0.039805620, 0, 1, 0
    0.039821600, 0, 0, 0
    0.039837580, 0, 1, 0
    0.039853560, 0, 0, 0
    0.040044480, 1, 0, 0
    0.040078680, 0, 0, 0
    0.040125180, 0, 1, 0
    0.040141160, 0, 0, 0
    0.040157140, 0, 1, 0
    0.040173120, 0, 0, 1
    0.040189100, 0, 1, 1
    0.040205080, 0, 0, 0
    0.040221060, 0, 1, 0
    0.040237040, 0, 0, 1
    0.040253020, 0, 1, 1
    0.040268980, 0, 0, 1
    0.040284960, 0, 1, 1
    0.040300940, 0, 0, 1
    0.040316920, 0, 1, 1
    0.040332900, 0, 0, 0
    0.040348880, 0, 1, 0
    0.040364840, 0, 0, 0
    0.040535520, 1, 0, 0
    0.040569720, 0, 0, 0
    0.040604500, 0, 1, 0
    0.040620480, 0, 0, 0
    0.040636460, 0, 1, 0
    0.040652440, 0, 0, 0
    0.040652460, 0, 0, 1
    0.040668420, 0, 1, 1
    0.040684400, 0, 0, 1
    0.040700380, 0, 1, 1
    0.040716360, 0, 0, 0
    0.040732320, 0, 1, 0
    0.040748300, 0, 0, 0
    0.040764280, 0, 1, 0
    0.040780260, 0, 0, 0
    0.040796260, 0, 1, 0
    0.040812240, 0, 0, 0
    0.040828220, 0, 1, 0
    0.040844200, 0, 0, 0
    0.041026620, 1, 0, 0
    0.041060820, 0, 0, 0
    0.041083860, 0, 1, 0
    0.041099820, 0, 0, 0
    0.041115800, 0, 1, 0
    0.041131760, 0, 0, 0
    0.041131780, 0, 0, 1
    0.041147740, 0, 1, 1
    0.041163720, 0, 0, 1
    0.041163740, 0, 0, 0
    0.041179700, 0, 1, 0
    0.041195680, 0, 0, 0
    0.041211660, 0, 1, 0
    0.041227620, 0, 0, 0
    0.041243600, 0, 1, 0
    0.041259580, 0, 0, 0
    0.041275560, 0, 1, 0
    0.041291540, 0, 0, 0
    0.041307520, 0, 1, 0
    0.041323480, 0, 0, 0
    0.041517600, 1, 0, 0
    0.041551780, 0, 0, 0
    0.041595020, 0, 1, 0
    0.041611000, 0, 0, 0
    0.041611020, 0, 0, 1
    0.041626980, 0, 1, 1
    0.041642940, 0, 0, 1
    0.041658920, 0, 1, 1
    0.041674900, 0, 0, 0
    0.041690860, 0, 1, 0
    0.041706840, 0, 0, 1
    0.041722800, 0, 1, 1
    0.041738780, 0, 0, 1
    0.041754760, 0, 1, 1
    0.041770740, 0, 0, 0
    0.041786700, 0, 1, 0
    0.041802680, 0, 0, 0
    0.041802700, 0, 0, 1
    0.041818660, 0, 1, 1
    0.041834640, 0, 0, 1
    0.042009760, 1, 0, 1
    0.042043940, 0, 0, 1
    0.042058240, 0, 0, 0
    0.042074200, 0, 1, 0
    0.042090180, 0, 0, 1
    0.042106140, 0, 1, 1
    0.042122100, 0, 0, 1
    0.042138080, 0, 1, 1
    0.042154060, 0, 0, 0
    0.042170020, 0, 1, 0
    0.042186000, 0, 0, 0
    0.042186020, 0, 0, 1
    0.042201980, 0, 1, 1
    0.042217960, 0, 0, 1
    0.042233920, 0, 1, 1
    0.042249900, 0, 0, 1
    0.042249920, 0, 0, 0
    0.042265880, 0, 1, 0
    0.042281860, 0, 0, 1
    0.042297820, 0, 1, 1
    0.042313780, 0, 0, 1
    0.042500640, 1, 0, 1
    0.042534820, 0, 0, 1
    0.042569340, 0, 0, 0
    0.042585320, 0, 1, 0
    0.042601300, 0, 0, 0
    0.042617280, 0, 1, 0
    0.042633240, 0, 0, 0
    0.042649220, 0, 1, 0
    0.042665200, 0, 0, 0
    0.042681160, 0, 1, 0
    0.042697140, 0, 0, 0
    0.042713100, 0, 1, 0
    0.042729080, 0, 0, 1
    0.042745060, 0, 1, 1
    0.042761040, 0, 0, 0
    0.042777020, 0, 1, 0
    0.042793000, 0, 0, 0
    0.042808960, 0, 1, 0
    0.042824940, 0, 0, 0
    0.042991600, 1, 0, 0
    0.043025800, 0, 0, 0
    0.043064560, 0, 1, 0
    0.043080540, 0, 0, 0
    0.043096500, 0, 1, 0
    0.043112460, 0, 0, 0
    0.043112480, 0, 0, 1
    0.043128440, 0, 1, 1
    0.043144420, 0, 0, 0
    0.043160400, 0, 1, 0
    0.043176360, 0, 0, 0
    0.043192340, 0, 1, 0
    0.043208320, 0, 0, 0
    0.043224300, 0, 1, 0
    0.043240280, 0, 0, 0
    0.043256260, 0, 1, 0
    0.043272220, 0, 0, 0
    0.043288200, 0, 1, 0
    0.043304180, 0, 0, 0
    0.043482600, 1, 0, 0
    0.043516800, 0, 0, 0
    0.043543840, 0, 1, 0
    0.043559820, 0, 0, 0
    0.043575800, 0, 1, 0
    0.043591780, 0, 0, 0
    0.043591800, 0, 0, 1
    0.043607760, 0, 1, 1
    0.043623740, 0, 0, 1
    0.043623760, 0, 0, 0
    0.043639720, 0, 1, 0
    0.043655700, 0, 0, 0
    0.043671680, 0, 1, 0
    0.043687660, 0, 0, 0
    0.043703640, 0, 1, 0
    0.043719620, 0, 0, 0
    0.043735600, 0, 1, 0
    0.043751580, 0, 0, 0
    0.043767560, 0, 1, 0
    0.043783540, 0, 0, 0
    0.043973720, 1, 0, 0
    0.044007920, 0, 0, 0
    0.044055160, 0, 1, 0
    0.044071140, 0, 0, 0
    0.044087120, 0, 1, 0
    0.044103080, 0, 0, 0
    0.044103100, 0, 0, 1
    0.044119060, 0, 1, 1
    0.044135040, 0, 0, 0
    0.044151020, 0, 1, 0
    0.044167000, 0, 0, 0
    0.044182980, 0, 1, 0
    0.044198960, 0, 0, 0
    0.044214940, 0, 1, 0
    0.044230920, 0, 0, 0
    0.044246900, 0, 1, 0
    0.044262860, 0, 0, 0
    0.044278840, 0, 1, 0
    0.044294800, 0, 0, 0
    0.044466240, 1, 0, 0
    0.044500440, 0, 0, 0
    0.044534460, 0, 1, 0
    0.044550440, 0, 0, 0
    0.044566420, 0, 1, 0
    0.044582400, 0, 0, 0
    0.044598380, 0, 1, 0
    0.044614360, 0, 0, 0
    0.044630340, 0, 1, 0
    0.044646300, 0, 0, 0
    0.044662300, 0, 1, 0
    0.044678280, 0, 0, 0
    0.044694240, 0, 1, 0
    0.044710220, 0, 0, 0
    0.044726200, 0, 1, 0
    0.044742180, 0, 0, 0
    0.044758160, 0, 1, 0
    0.044774140, 0, 0, 0
    0.044783560, 0, 0, 1
    0.044957320, 1, 0, 1
    0.044991520, 0, 0, 1
    0.044997900, 0, 0, 0
    0.044997920, 0, 0, 1
    0.044997940, 0, 0, 0
    0.045013800, 0, 1, 0
    0.045029780, 0, 0, 0
    0.045045760, 0, 1, 0
    0.045061740, 0, 0, 0
    0.045062100, 0, 0, 1
    0.045077700, 0, 1, 1
    0.045093680, 0, 0, 0
    0.045094040, 0, 0, 1
    0.045109660, 0, 1, 1
    0.045125640, 0, 0, 0
    0.045141620, 0, 1, 0
    0.045157600, 0, 0, 0
    0.045173580, 0, 1, 0
    0.045189540, 0, 0, 0
    0.045205520, 0, 1, 0
    0.045221520, 0, 0, 1
    0.045237480, 0, 1, 1
    0.045253460, 0, 0, 0
    0.045253820, 0, 0, 1
    0.045448700, 1, 0, 1
    0.045482920, 0, 0, 1
    0.045509200, 0, 0, 0
    0.045525180, 0, 1, 0
    0.045541160, 0, 0, 0
    0.045557140, 0, 1, 0
    0.045573120, 0, 0, 0
    0.045573140, 0, 0, 1
    0.045589120, 0, 1, 1
    0.045605100, 0, 0, 0
    0.045621080, 0, 1, 0
    0.045637060, 0, 0, 0
    0.045653040, 0, 1, 0
    0.045669020, 0, 0, 1
    0.045684980, 0, 1, 1
    0.045700960, 0, 0, 1
    0.045716940, 0, 1, 1
    0.045732920, 0, 0, 1
    0.045732940, 0, 0, 0
    0.045748920, 0, 1, 0
    0.045764900, 0, 0, 0
    0.045940100, 1, 0, 0
    0.045974300, 0, 0, 0
    0.046004600, 0, 1, 0
    0.046020580, 0, 0, 0
    0.046036560, 0, 1, 0
    0.046052540, 0, 0, 0
    0.046053260, 0, 0, 1
    0.046068520, 0, 1, 1
    0.046084480, 0, 0, 0
    0.046084760, 0, 0, 1
    0.046100460, 0, 1, 1
    0.046116440, 0, 0, 0
    0.046132420, 0, 1, 0
    0.046148400, 0, 0, 0
    0.046164380, 0, 1, 0
    0.046180360, 0, 0, 0
    0.046180740, 0, 0, 1
    0.046196340, 0, 1, 1
    0.046212320, 0, 0, 1
    0.046228300, 0, 1, 1
    0.046244280, 0, 0, 1
    0.046431480, 1, 0, 1
    0.046465680, 0, 0, 1
    0.046499960, 0, 0, 0
    0.046515920, 0, 1, 0
    0.046531900, 0, 0, 0
    0.046531920, 0, 0, 1
    0.046531940, 0, 0, 0
    0.046532120, 0, 0, 1
    0.046534740, 0, 0, 0
    0.046535580, 0, 0, 1
    0.046547880, 0, 1, 1
    0.046563880, 0, 0, 0
    0.046579860, 0, 1, 0
    0.046595820, 0, 0, 0
    0.046595880, 0, 0, 1
    0.046611820, 0, 1, 1
    0.046627780, 0, 0, 1
    0.046627800, 0, 0, 0
    0.046643760, 0, 1, 0
    0.046659740, 0, 0, 0
    0.046675720, 0, 1, 0
    0.046691680, 0, 0, 0
    0.046693360, 0, 0, 1
    0.046707660, 0, 1, 1
    0.046723640, 0, 0, 0
    0.046739640, 0, 1, 0
    0.046755620, 0, 0, 0
    0.046922820, 1, 0, 0
    0.056855940, 0, 0, 0
    0.056886240, 0, 0, 1
    0.056902200, 0, 1, 1
    0.056918180, 0, 0, 1
    0.056918200, 0, 0, 0
    0.056934160, 0, 1, 0
    0.056950140, 0, 0, 0
    0.056966120, 0, 1, 0
    0.056982100, 0, 0, 0
    0.056982120, 0, 0, 1
    0.056998080, 0, 1, 1
    0.057014040, 0, 0, 1
    0.057014060, 0, 0, 0
    0.057030020, 0, 1, 0
    0.057046000, 0, 0, 0
    0.057061980, 0, 1, 0
    0.057077960, 0, 0, 0
    0.057093940, 0, 1, 0
    0.057109920, 0, 0, 0
    0.057125920, 0, 1, 0
    0.057141900, 0, 0, 0
    0.060771080, 1, 0, 0
    0.060774560, 0, 0, 0
    0.060800580, 0, 1, 0
    0.060816560, 0, 0, 0
    0.060832540, 0, 1, 0
    0.060848520, 0, 0, 1
    0.060864500, 0, 1, 1
    0.060880480, 0, 0, 0
    0.060896440, 0, 1, 0
    0.060912420, 0, 0, 0
    0.060928400, 0, 1, 0
    0.060944380, 0, 0, 0
    0.060960360, 0, 1, 0
    0.060976320, 0, 0, 0
    0.060992300, 0, 1, 0
    0.061008260, 0, 0, 0
    0.061024240, 0, 1, 0
    0.061040220, 0, 0, 0
    0.061171460, 1, 0, 0
    0.061205640, 0, 0, 0
    0.061247900, 0, 1, 0
    0.061263880, 0, 0, 0
    0.061279860, 0, 1, 0
    0.061295840, 0, 0, 1
    0.061311800, 0, 1, 1
    0.061327780, 0, 0, 1
    0.061343760, 0, 1, 1
    0.061359740, 0, 0, 0
    0.061375700, 0, 1, 0
    0.061391660, 0, 0, 0
    0.061407640, 0, 1, 0
    0.061423620, 0, 0, 0
    0.061439600, 0, 1, 0
    0.061455580, 0, 0, 0
    0.061471540, 0, 1, 0
    0.061487520, 0, 0, 0
    0.061662440, 1, 0, 0
    0.061696640, 0, 0, 0
    0.061727160, 0, 1, 0
    0.061743140, 0, 0, 0
    0.061759120, 0, 1, 0
    0.061775080, 0, 0, 1
    0.061791060, 0, 1, 1
    0.061807020, 0, 0, 1
    0.061807040, 0, 0, 0
    0.061823000, 0, 1, 0
    0.061838980, 0, 0, 0
    0.061839000, 0, 0, 1
    0.061854960, 0, 1, 1
    0.061870940, 0, 0, 1
    0.061886920, 0, 1, 1
    0.061902900, 0, 0, 1
    0.061918880, 0, 1, 1
    0.061934860, 0, 0, 0
    0.061950840, 0, 1, 0
    0.061966800, 0, 0, 0
    0.062153440, 1, 0, 0
    0.062187620, 0, 0, 0
    0.062238360, 0, 1, 0
    0.062254340, 0, 0, 0
    0.062270300, 0, 1, 0
    0.062286280, 0, 0, 1
    0.062302260, 0, 1, 1
    0.062318220, 0, 0, 1
    0.062334200, 0, 1, 1
    0.062350180, 0, 0, 0
    0.062366140, 0, 1, 0
    0.062382100, 0, 0, 0
    0.062398080, 0, 1, 0
    0.062414060, 0, 0, 0
    0.062430020, 0, 1, 0
    0.062446000, 0, 0, 0
    0.062461980, 0, 1, 0
    0.062477940, 0, 0, 0
    0.062644360, 1, 0, 0
    0.062678560, 0, 0, 0
    0.062717560, 0, 1, 0
    0.062733540, 0, 0, 0
    0.062749520, 0, 1, 0
    0.062765500, 0, 0, 1
    0.062781460, 0, 1, 1
    0.062797440, 0, 0, 1
    0.062813420, 0, 1, 1
    0.062829400, 0, 0, 0
    0.062845380, 0, 1, 0
    0.062861340, 0, 0, 0
    0.062877320, 0, 1, 0
    0.062893300, 0, 0, 0
    0.062909280, 0, 1, 0
    0.062925240, 0, 0, 0
    0.062941220, 0, 1, 0
    0.062957200, 0, 0, 0
    0.063135340, 1, 0, 0
    0.063169520, 0, 0, 0
    0.063196800, 0, 1, 0
    0.063212780, 0, 0, 1
    0.063228760, 0, 1, 1
    0.063244720, 0, 0, 1
    0.063260700, 0, 1, 1
    0.063276680, 0, 0, 1
    0.063276700, 0, 0, 0
    0.063292660, 0, 1, 0
    0.063308640, 0, 0, 0
    0.063324620, 0, 1, 0
    0.063340600, 0, 0, 1
    0.063356580, 0, 1, 1
    0.063372540, 0, 0, 1
    0.063388520, 0, 1, 1
    0.063404500, 0, 0, 1
    0.063420480, 0, 1, 1
    0.063436460, 0, 0, 1
    0.063627620, 1, 0, 1
    0.063661840, 0, 0, 1
    0.063692120, 0, 0, 0
    0.063708080, 0, 1, 0
    0.063724060, 0, 0, 0
    0.063724080, 0, 0, 1
    0.063740040, 0, 1, 1
    0.063756020, 0, 0, 0
    0.063772000, 0, 1, 0
    0.063787980, 0, 0, 0
    0.063803960, 0, 1, 0
    0.063819920, 0, 0, 0
    0.063835900, 0, 1, 0
    0.063851880, 0, 0, 0
    0.063851900, 0, 0, 1
    0.063867860, 0, 1, 1
    0.063883840, 0, 0, 0
    0.063899820, 0, 1, 0
    0.063915800, 0, 0, 1
    0.063931780, 0, 1, 1
    0.063947760, 0, 0, 1
    0.064118720, 1, 0, 1
    0.064152900, 0, 0, 1
    0.064171460, 0, 0, 0
    0.064187420, 0, 1, 0
    0.064203400, 0, 0, 0
    0.064219380, 0, 1, 0
    0.064235360, 0, 0, 0
    0.064251340, 0, 1, 0
    0.064267320, 0, 0, 0
    0.064283300, 0, 1, 0
    0.064299280, 0, 0, 0
    0.064315260, 0, 1, 0
    0.064331240, 0, 0, 0
    0.064347220, 0, 1, 0
    0.064363180, 0, 0, 0
    0.064379160, 0, 1, 0
    0.064395140, 0, 0, 0
    0.064411120, 0, 1, 0
    0.064427100, 0, 0, 0
    0.064609820, 1, 0, 0
    0.064644040, 0, 0, 0
    0.064666820, 0, 1, 0
    0.064682800, 0, 0, 0
    0.064698780, 0, 1, 0
    0.064714760, 0, 0, 0
    0.064714780, 0, 0, 1
    0.064730740, 0, 1, 1
    0.064746740, 0, 0, 0
    0.064762700, 0, 1, 0
    0.064778680, 0, 0, 0
    0.064794660, 0, 1, 0
    0.064810640, 0, 0, 0
    0.064826620, 0, 1, 0
    0.064842620, 0, 0, 0
    0.064858600, 0, 1, 0
    0.064874580, 0, 0, 0
    0.064890560, 0, 1, 0
    0.064906540, 0, 0, 0
    0.065101000, 1, 0, 0
    0.065135220, 0, 0, 0
    0.065178220, 0, 1, 0
    0.065194200, 0, 0, 0
    0.065210200, 0, 1, 0
    0.065226180, 0, 0, 1
    0.065242160, 0, 1, 1
    0.065258140, 0, 0, 1
    0.065258160, 0, 0, 0
    0.065274120, 0, 1, 0
    0.065290120, 0, 0, 0
    0.065306100, 0, 1, 0
    0.065322080, 0, 0, 0
    0.065338060, 0, 1, 0
    0.065354040, 0, 0, 0
    0.065370020, 0, 1, 0
    0.065386000, 0, 0, 0
    0.065401980, 0, 1, 0
    0.065417960, 0, 0, 0
    0.065592180, 1, 0, 0
    0.065626400, 0, 0, 0
    0.065657680, 0, 1, 0
    0.065673660, 0, 0, 0
    0.065689640, 0, 1, 0
    0.065705620, 0, 0, 0
    0.065705640, 0, 0, 1
    0.065721600, 0, 1, 1
    0.065737580, 0, 0, 1
    0.065737600, 0, 0, 0
    0.065753560, 0, 1, 0
    0.065769520, 0, 0, 0
    0.065785520, 0, 1, 0
    0.065801500, 0, 0, 0
    0.065817480, 0, 1, 0
    0.065833460, 0, 0, 0
    0.065849440, 0, 1, 0
    0.065865420, 0, 0, 0
    0.065881400, 0, 1, 0
    0.065897380, 0, 0, 0
    0.066084580, 1, 0, 0
    0.066118780, 0, 0, 0
    0.066169020, 0, 1, 0
    0.066185000, 0, 0, 0
    0.066185020, 0, 0, 1
    0.066201000, 0, 1, 1
    0.066216980, 0, 0, 0
    0.066232960, 0, 1, 0
    0.066248940, 0, 0, 0
    0.066264920, 0, 1, 0
    0.066280900, 0, 0, 0
    0.066296880, 0, 1, 0
    0.066312860, 0, 0, 0
    0.066328840, 0, 1, 0
    0.066344800, 0, 0, 0
    0.066344820, 0, 0, 1
    0.066360780, 0, 1, 1
    0.066376760, 0, 0, 1
    0.066392740, 0, 1, 1
    0.066408720, 0, 0, 1
    0.066575700, 1, 0, 1
    0.066609900, 0, 0, 1
    0.066632440, 0, 0, 0
    0.066648420, 0, 1, 0
    0.066664400, 0, 0, 1
    0.066680380, 0, 1, 1
    0.066696360, 0, 0, 0
    0.066712340, 0, 1, 0
    0.066728320, 0, 0, 0
    0.066744280, 0, 1, 0
    0.066760260, 0, 0, 1
    0.066776240, 0, 1, 1
    0.066792220, 0, 0, 1
    0.066808200, 0, 1, 1
    0.066824180, 0, 0, 1
    0.066824200, 0, 0, 0
    0.066840180, 0, 1, 0
    0.066856160, 0, 0, 0
    0.066872120, 0, 1, 0
    0.066888100, 0, 0, 0
    0.067066840, 1, 0, 0
    0.067101040, 0, 0, 0
    0.067127820, 0, 1, 0
    0.067143780, 0, 0, 0
    0.067159760, 0, 1, 0
    0.067175740, 0, 0, 0
    0.067175760, 0, 0, 1
    0.067191720, 0, 1, 1
    0.067207700, 0, 0, 1
    0.067223680, 0, 1, 1
    0.067239660, 0, 0, 1
    0.067239680, 0, 0, 0
    0.067255660, 0, 1, 0
    0.067271640, 0, 0, 0
    0.067287620, 0, 1, 0
    0.067303580, 0, 0, 0
    0.067303600, 0, 0, 1
    0.067319560, 0, 1, 1
    0.067335540, 0, 0, 0
    0.067351500, 0, 1, 0
    0.067367500, 0, 0, 0
    0.067557920, 1, 0, 0
    0.067592120, 0, 0, 0
    0.067639120, 0, 1, 0
    0.067655100, 0, 0, 0
    0.067671080, 0, 1, 0
    0.067687060, 0, 0, 1
    0.067703040, 0, 1, 1
    0.067719020, 0, 0, 0
    0.067734980, 0, 1, 0
    0.067750960, 0, 0, 0
    0.067766940, 0, 1, 0
    0.067782900, 0, 0, 0
    0.067798900, 0, 1, 0
    0.067814860, 0, 0, 0
    0.067830860, 0, 1, 0
    0.067846820, 0, 0, 0
    0.067862820, 0, 1, 0
    0.067878800, 0, 0, 0
    0.068049020, 1, 0, 0
    0.068083220, 0, 0, 0
    0.068118500, 0, 1, 0
    0.068134460, 0, 0, 0
    0.068150440, 0, 1, 0
    0.068166420, 0, 0, 0
    0.068166440, 0, 0, 1
    0.068182400, 0, 1, 1
    0.068198380, 0, 0, 1
    0.068198400, 0, 0, 0
    0.068214360, 0, 1, 0
    0.068230340, 0, 0, 0
    0.068246320, 0, 1, 0
    0.068262300, 0, 0, 0
    0.068278280, 0, 1, 0
    0.068294280, 0, 0, 0
    0.068310260, 0, 1, 0
    0.068326240, 0, 0, 0
    0.068342200, 0, 1, 0
    0.068358180, 0, 0, 0
    0.068541380, 1, 0, 0
    0.085760620, 0, 0, 0
    0.085774180, 0, 0, 1
    0.085790160, 0, 1, 1
    0.085806140, 0, 0, 0
    0.085822100, 0, 1, 0
    0.085838080, 0, 0, 1
    0.085854060, 0, 1, 1
    0.085870040, 0, 0, 1
    0.085870060, 0, 0, 0
    0.085886020, 0, 1, 0
    0.085902020, 0, 0, 0
    0.085918000, 0, 1, 0
    0.085933960, 0, 0, 0
    0.085949940, 0, 1, 0
    0.085965920, 0, 0, 0
    0.085981900, 0, 1, 0
    0.085997880, 0, 0, 0
    0.086013860, 0, 1, 0
    0.086029820, 0, 0, 0
    0.089758480, 1, 0, 0
    0.089761980, 0, 0, 0
    0.089784760, 0, 1, 0
    0.089800740, 0, 0, 0
    0.089816720, 0, 1, 0
    0.089832680, 0, 0, 0
    0.089832700, 0, 0, 1
    0.089848660, 0, 1, 1
    0.089864640, 0, 0, 1
    0.089864660, 0, 0, 0
    0.089880640, 0, 1, 0
    0.089896620, 0, 0, 0
    0.089912600, 0, 1, 0
    0.089928580, 0, 0, 0
    0.089944560, 0, 1, 0
    0.089960520, 0, 0, 0
    0.089976500, 0, 1, 0
    0.089992480, 0, 0, 0
    0.090008460, 0, 1, 0
    0.090024440, 0, 0, 0
    0.090158940, 1, 0, 0
    0.090193140, 0, 0, 0
    0.090232160, 0, 1, 0
    0.090248140, 0, 0, 0
    0.090264120, 0, 1, 0
    0.090280100, 0, 0, 1
    0.090296060, 0, 1, 1
    0.090312040, 0, 0, 1
    0.090328020, 0, 1, 1
    0.090344000, 0, 0, 1
    0.090344020, 0, 0, 0
    0.090359980, 0, 1, 0
    0.090375960, 0, 0, 0
    0.090391940, 0, 1, 0
    0.090407900, 0, 0, 0
    0.090407920, 0, 0, 1
    0.090423880, 0, 1, 1
    0.090439860, 0, 0, 1
    0.090439880, 0, 0, 0
    0.090455840, 0, 1, 0
    0.090471820, 0, 0, 0
    0.090650000, 1, 0, 0
    0.090684200, 0, 0, 0
    0.090711480, 0, 1, 0
    0.090727460, 0, 0, 0
    0.090743440, 0, 1, 0
    0.090759420, 0, 0, 1
    0.090775400, 0, 1, 1
    0.090791360, 0, 0, 1
    0.090807320, 0, 1, 1
    0.090823300, 0, 0, 1
    0.090823320, 0, 0, 0
    0.090839280, 0, 1, 0
    0.090855260, 0, 0, 0
    0.090855280, 0, 0, 1
    0.090871240, 0, 1, 1
    0.090887220, 0, 0, 1
    0.090903200, 0, 1, 1
    0.090919180, 0, 0, 0
    0.090935160, 0, 1, 0
    0.090951140, 0, 0, 0
    0.091142280, 1, 0, 0
    0.091176480, 0, 0, 0
    0.091222720, 0, 1, 0
    0.091238700, 0, 0, 0
    0.091254680, 0, 1, 0
    0.091270660, 0, 0, 1
    0.091286640, 0, 1, 1
    0.091302620, 0, 0, 0
    0.091318600, 0, 1, 0
    0.091334580, 0, 0, 1
    0.091350540, 0, 1, 1
    0.091366520, 0, 0, 1
    0.091382500, 0, 1, 1
    0.091398460, 0, 0, 1
    0.091414440, 0, 1, 1
    0.091430420, 0, 0, 1
    0.091430440, 0, 0, 0
    0.091446400, 0, 1, 0
    0.091462380, 0, 0, 0
    0.091633320, 1, 0, 0
    0.091667520, 0, 0, 0
    0.091702020, 0, 1, 0
    0.091718000, 0, 0, 0
    0.091733980, 0, 1, 0
    0.091749960, 0, 0, 0
    0.091749980, 0, 0, 1
    0.091765940, 0, 1, 1
    0.091781900, 0, 0, 1
    0.091797880, 0, 1, 1
    0.091813840, 0, 0, 1
    0.091813860, 0, 0, 0
    0.091829820, 0, 1, 0
    0.091845800, 0, 0, 0
    0.091845820, 0, 0, 1
    0.091861780, 0, 1, 1
    0.091877760, 0, 0, 1
    0.091893740, 0, 1, 1
    0.091909720, 0, 0, 1
    0.091925700, 0, 1, 1
    0.091941680, 0, 0, 1
    0.092124340, 1, 0, 1
    0.092158540, 0, 0, 1
    0.092181320, 0, 1, 1
    0.092197300, 0, 0, 1
    0.092213280, 0, 1, 1
    0.092229260, 0, 0, 0
    0.092245240, 0, 1, 0
    0.092261220, 0, 0, 1
    0.092277200, 0, 1, 1
    0.092293180, 0, 0, 1
    0.092309160, 0, 1, 1
    0.092325140, 0, 0, 1
    0.092341120, 0, 1, 1
    0.092357100, 0, 0, 1
    0.092373060, 0, 1, 1
    0.092389040, 0, 0, 1
    0.092405020, 0, 1, 1
    0.092420980, 0, 0, 1
    0.092615400, 1, 0, 1
    0.092649600, 0, 0, 1
    0.092676640, 0, 0, 0
    0.092692600, 0, 1, 0
    0.092708580, 0, 0, 0
    0.092708600, 0, 0, 1
    0.092724560, 0, 1, 1
    0.092740540, 0, 0, 1
    0.092740560, 0, 0, 0
    0.092756520, 0, 1, 0
    0.092772500, 0, 0, 0
    0.092788460, 0, 1, 0
    0.092804440, 0, 0, 0
    0.092820440, 0, 1, 0
    0.092836400, 0, 0, 0
    0.092852380, 0, 1, 0
    0.092868360, 0, 0, 0
    0.092868380, 0, 0, 1
    0.092884360, 0, 1, 1
    0.092900320, 0, 0, 1
    0.092916320, 0, 1, 1
    0.092932300, 0, 0, 1
    0.093106500, 1, 0, 1
    0.093140700, 0, 0, 1
    0.093156000, 0, 0, 0
    0.093171960, 0, 1, 0
    0.093187940, 0, 0, 0
    0.093203920, 0, 1, 0
    0.093219900, 0, 0, 0
    0.093219920, 0, 0, 1
    0.093235880, 0, 1, 1
    0.093251860, 0, 0, 0
    0.093267840, 0, 1, 0
    0.093283820, 0, 0, 0
    0.093299800, 0, 1, 0
    0.093315780, 0, 0, 0
    0.093331760, 0, 1, 0
    0.093347740, 0, 0, 0
    0.093363720, 0, 1, 0
    0.093379700, 0, 0, 0
    0.093395680, 0, 1, 0
    0.093411660, 0, 0, 0
    0.093598820, 1, 0, 0
    0.093633040, 0, 0, 0
    0.093683300, 0, 1, 0
    0.093699280, 0, 0, 1
    0.093715260, 0, 1, 1
    0.093731240, 0, 0, 0
    0.093747220, 0, 1, 0
    0.093763180, 0, 0, 1
    0.093779140, 0, 1, 1
    0.093795140, 0, 0, 0
    0.093811120, 0, 1, 0
    0.093827100, 0, 0, 0
    0.093843080, 0, 1, 0
    0.093859060, 0, 0, 0
    0.093859080, 0, 0, 1
    0.093875040, 0, 1, 1
    0.093891020, 0, 0, 0
    0.093907000, 0, 1, 0
    0.093922980, 0, 0, 0
    0.094089980, 1, 0, 0
    0.094124200, 0, 0, 0
    0.094162700, 0, 1, 0
    0.094178680, 0, 0, 0
    0.094178700, 0, 0, 1
    0.094194660, 0, 1, 1
    0.094210640, 0, 0, 1
    0.094210660, 0, 0, 0
    0.094226620, 0, 1, 0
    0.094242600, 0, 0, 0
    0.094242620, 0, 0, 1
    0.094258600, 0, 1, 1
    0.094274560, 0, 0, 1
    0.094274580, 0, 0, 0
    0.094290540, 0, 1, 0
    0.094306520, 0, 0, 0
    0.094306540, 0, 0, 1
    0.094322500, 0, 1, 1
    0.094338480, 0, 0, 1
    0.094338500, 0, 0, 0
    0.094354460, 0, 1, 0
    0.094370440, 0, 0, 1
    0.094386400, 0, 1, 1
    0.094402380, 0, 0, 1
    0.094581080, 1, 0, 1
    0.094615300, 0, 0, 1
    0.094626120, 0, 0, 0
    0.094642080, 0, 1, 0
    0.094658080, 0, 0, 1
    0.094674060, 0, 1, 1
    0.094690040, 0, 0, 0
    0.094706020, 0, 1, 0
    0.094722000, 0, 0, 0
    0.094737980, 0, 1, 0
    0.094753940, 0, 0, 0
    0.094753960, 0, 0, 1
    0.094769920, 0, 1, 1
    0.094785900, 0, 0, 1
    0.094801880, 0, 1, 1
    0.094817860, 0, 0, 1
    0.094833840, 0, 1, 1
    0.094849820, 0, 0, 0
    0.094865800, 0, 1, 0
    0.094881780, 0, 0, 0
    0.095072200, 1, 0, 0
    0.095106400, 0, 0, 0
    0.095153400, 0, 1, 0
    0.095169380, 0, 0, 0
    0.095185360, 0, 1, 0
    0.095201340, 0, 0, 1
    0.095217320, 0, 1, 1
    0.095233300, 0, 0, 1
    0.095233320, 0, 0, 0
    0.095249280, 0, 1, 0
    0.095265260, 0, 0, 0
    0.095281240, 0, 1, 0
    0.095297220, 0, 0, 0
    0.095313200, 0, 1, 0
    0.095329180, 0, 0, 0
    0.095345160, 0, 1, 0
    0.095361120, 0, 0, 0
    0.095377100, 0, 1, 0
    0.095393080, 0, 0, 0
    0.095563260, 1, 0, 0
    0.095597460, 0, 0, 0
    0.095632740, 0, 1, 0
    0.095648720, 0, 0, 0
    0.095664700, 0, 1, 0
    0.095680660, 0, 0, 0
    0.095696640, 0, 1, 0
    0.095712640, 0, 0, 0
    0.095728620, 0, 1, 0
    0.095744580, 0, 0, 0
    0.095760560, 0, 1, 0
    0.095776540, 0, 0, 0
    0.095792520, 0, 1, 0
    0.095808500, 0, 0, 1
    0.095824480, 0, 1, 1
    0.095840460, 0, 0, 1
    0.095856440, 0, 1, 1
    0.095872420, 0, 0, 1
    0.096055600, 1, 0, 1
    0.096089800, 0, 0, 1
    0.096096100, 0, 0, 0
    0.096112080, 0, 1, 0
    0.096128060, 0, 0, 0
    0.096144020, 0, 1, 0
    0.096160000, 0, 0, 0
    0.096175980, 0, 1, 0
    0.096191940, 0, 0, 0
    0.096207940, 0, 1, 0
    0.096223920, 0, 0, 0
    0.096239900, 0, 1, 0
    0.096255880, 0, 0, 0
    0.096271860, 0, 1, 0
    0.096287820, 0, 0, 0
    0.096303800, 0, 1, 0
    0.096319780, 0, 0, 0
    0.096319800, 0, 0, 1
    0.096335760, 0, 1, 1
    0.096351740, 0, 0, 1
    0.096546640, 1, 0, 1
    0.096580840, 0, 0, 1
    0.096607380, 0, 0, 0
    0.096623360, 0, 1, 0
    0.096639340, 0, 0, 0
    0.096655320, 0, 1, 0
    0.096671300, 0, 0, 0
    0.096687280, 0, 1, 0
    0.096703260, 0, 0, 0
    0.096719220, 0, 1, 0
    0.096735200, 0, 0, 0
    0.096751160, 0, 1, 0
    0.096767140, 0, 0, 0
    0.096783120, 0, 1, 0
    0.096799100, 0, 0, 0
    0.096815080, 0, 1, 0
    0.096831060, 0, 0, 0
    0.096831080, 0, 0, 1
    0.096847040, 0, 1, 1
    0.096863020, 0, 0, 1
    0.097037720, 1, 0, 1
    0.097071940, 0, 0, 1
    0.097086740, 0, 0, 0
    0.097102700, 0, 1, 0
    0.097118680, 0, 0, 0
    0.097134660, 0, 1, 0
    0.097150620, 0, 0, 0
    0.097166600, 0, 1, 0
    0.097182580, 0, 0, 0
    0.097198560, 0, 1, 0
    0.097214560, 0, 0, 0
    0.097230540, 0, 1, 0
    0.097246520, 0, 0, 0
    0.097262500, 0, 1, 0
    0.097278480, 0, 0, 0
    0.097294460, 0, 1, 0
    0.097310440, 0, 0, 1
    0.097326420, 0, 1, 1
    0.097342380, 0, 0, 1
    0.097528840, 1, 0, 1
    2019-10-15_17-32-50.csv
    Hope the detail information could help you to solve the problem.
