Following nRF Connect Tutorial of nRF9160 and got stuck on "west flash" on "you first Hello World"
I've been following the guide linked here and got to the point where PCA10090 is flashed with Hello World project. However, when executing "west flash" command, an error appears:
c:\Users\username\Documents\nrf_repository\ncs\nrf\samples\nrf9160\hello_world>west flash
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
File "c:\users\username\appdata\local\programs\python\python37\lib\runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "c:\users\username\appdata\local\programs\python\python37\lib\runpy.py", line 85, in _run_code
exec(code, run_globals)
File "C:\Users\username\AppData\Local\Programs\Python\Python37\Scripts\west.exe\__main__.py", line 9, in <module>
File "c:\users\username\appdata\local\programs\python\python37\lib\site-packages\west\main.py", line 583, in main
args.handler(args, unknown)
File "c:\users\username\appdata\local\programs\python\python37\lib\site-packages\west\main.py", line 334, in ext_command_handler
command.run(args, unknown, topdir, manifest=manifest)
File "c:\users\username\appdata\local\programs\python\python37\lib\site-packages\west\commands\__init__.py", line 118, in run
self.do_run(args, unknown)
File "c:\users\username\documents\nrf_repository\ncs\zephyr\scripts\west_commands\flash.py", line 32, in do_run
'ZEPHYR_BOARD_FLASH_RUNNER')
File "c:\Users\username\Documents\nrf_repository\ncs\zephyr\scripts/west_commands\run_common.py", line 288, in do_run_common
runner = runner_cls.create(cfg, parsed_args)
File "c:\Users\username\Documents\nrf_repository\ncs\zephyr\scripts/west_commands\runners\nrfjprog.py", line 50, in create
ret.ensure_snr()
File "c:\Users\username\Documents\nrf_repository\ncs\zephyr\scripts/west_commands\runners\nrfjprog.py", line 55, in ensure_snr
self.snr = self.get_board_snr_from_user()
File "c:\Users\username\Documents\nrf_repository\ncs\zephyr\scripts/west_commands\runners\nrfjprog.py", line 58, in get_board_snr_from_user
snrs = self.check_output(['nrfjprog', '--ids'])
File "c:\Users\username\Documents\nrf_repository\ncs\zephyr\scripts/west_commands\runners\core.py", line 531, in check_output
return subprocess.check_output(cmd)
File "c:\users\username\appdata\local\programs\python\python37\lib\subprocess.py", line 395, in check_output
**kwargs).stdout
File "c:\users\username\appdata\local\programs\python\python37\lib\subprocess.py", line 472, in run
with Popen(*popenargs, **kwargs) as process:
File "c:\users\username\appdata\local\programs\python\python37\lib\subprocess.py", line 775, in __init__
restore_signals, start_new_session)
File "c:\users\username\appdata\local\programs\python\python37\lib\subprocess.py", line 1178, in _execute_child
startupinfo)
FileNotFoundError: [WinError 2] The system cannot find the file specified
I have version v1.0.0 of Nordic Connect SDK and followed "Getting Started Assistant" for installing tools.
Could you provide assistant on why this error is appearing?
Thanks in Advance.
