I used the example pin_change_int from peripheral examples and commented the OUT pins. In addition I added the sleep commands to the main while loop. This is the code:
#include <stdbool.h> #include "nrf.h" #include "nrf_drv_gpiote.h" #include "app_error.h" #include "boards.h" #ifdef BSP_BUTTON_0 #define PIN_IN BSP_BUTTON_0 #endif #ifndef PIN_IN #error "Please indicate input pin" #endif #ifdef BSP_LED_0 #define PIN_OUT BSP_LED_0 #endif #ifndef PIN_OUT #error "Please indicate output pin" #endif void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) { //nrf_drv_gpiote_out_toggle(PIN_OUT); } /** * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output, * and configures GPIOTE to give an interrupt on pin change. */ static void gpio_init(void) { ret_code_t err_code; err_code = nrf_drv_gpiote_init(); APP_ERROR_CHECK(err_code); //nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false); //err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config); //APP_ERROR_CHECK(err_code); nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true); in_config.pull = NRF_GPIO_PIN_PULLUP; err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler); APP_ERROR_CHECK(err_code); nrf_drv_gpiote_in_event_enable(PIN_IN, true); } /** * @brief Function for application main entry. */ int main(void) { gpio_init(); while (true) { __SEV(); __WFE(); __WFE(); } }
When I power profile it right after turning the device on, I get a nice expected current consumption of 32uA as seen below
However, as soon as I press the button per code, the consumption goes high and stays high. I was expecting it to spike up but then go back to normal. Why is this occurring? I am using the DK board and using the regular board button 0 for this. Why is it using so much current consistently?
