Let's say I have 2 nrf52 Centrals in a room , now - I'm adding a peripheral and I'd like it to connect to the central with the better RSSI ( out of the 2 )
My idea involves role switching and seems pretty complicated.
Ran
Ran
Just to complete the picture - the metering data goes up to the cloud. In the installation I've described - the star central is equipped with LTE modem . ( gateway )
So , If I'll be using Mesh , I will have to define a gateway that all nodes "publish" to him ?
Also - I will need to connect to each one of the nodes from a mobile phone and set\get configuration
(probably over NUS ) , will that be a problem ?
(I see that in latest mesh sdk, proxy node was remove from lightning client, available only on server ).
Yes - that is a standard concept in meshes
Not necessarily.
You can provision over the mesh - again, a standard concept in meshes
" I will need to connect to each one of the nodes from a mobile phone and set\get configuration" - this is regardless of Mesh but operational , for example elec. meter S\N and initial reading .
This is per meter configuration and will have to be done using Tech, App running on iOS\Android
So that's your design decision - not a requirement or restriction of using a mesh.
