Connecting device to AWS IoT Core (aws_fota)
I've been trying to connect my device to AWS IoT for a week, but I'm getting the same error "no matter what" I do (ERROR: mqtt_connect -45), which seemingly is an authorization issue of some kind?
Here are the exact steps I'm doing to connect my device:
  1. Register my thing in AWS IoT Core.
    1. I register a single thing
    2. I create a certificate using one-click certificate creation, I download the public key, private key, the Amazon Root CA 1, and I click activate.
    3. I attach a policy matching the one given in https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nrf9160/aws_fota/README.html
  2. I load the project and configure my device
    1. I load the project from Open nRF Connect SDK Project (using the fw-nrfconnect-nrf v1.0.0)
      1. CMakeLists.txt -> ncs/nrf/samples/nrf9160/aws_fota/CMakeLists.txt
      2. Board directory -> ncs/zephyr/boards/arm/nrf9160_pca10090
      3. Board name -> nrf9160_pca10090ns
      4. Build directory -> ncs/nrf/samples/nrf9160/aws_fota/build_nrf9160_pca10090ns
    2. I put the contents of the certificates in the certificates.h file. CLOUD_CLIENT_PRIVATE_KEY is the private key, CLOUD_CLIENT_PUBLIC_CERTIFICATE is the public key and CLOUD_CA_CERTIFICATE is Amazon Root CA 1.I go to Project -> Configure nRF Connect SDK Project -> menuconfig
      1. I set the AWS IoT MQTT broker hostname to the URL found in things -> <my-thing-name> -> Interact -> HTTPS
      2. I set the AWS IoT MQTT broker port to 8883
      3. I set the Custom MQTT Client Id to <my-thing-name>
      4. I uncheck Use provisioned certificates
  3. I flash the sample onto the board
    1. I go to Build -> Build and Debug
    2. When the debug screen appears I click the green arrow in the top right corner which runs the program.
This process gives the following output:
LTE Link Connecting ...
LTE Link Connected!
IPv4 Address 0x68e7dd12
client_id: <my-thing-name>
Please help me resolve this as I can't identify which step(s) I'm missing.
Thank you in advance.
  • The MQTT broker hostname was already found where you described. I tried adding it once more just to eliminate the possibility of typos, but I'm still getting the same errors. The correct port is 8883, right?
    Also when the thing was added to AWS IoT, a username and password was created, should these pieces of information be added somewhere, maybe?
  • Maybe attach a policy to your certificates which looks like this  https://raw.githubusercontent.com/nRFCloud/device-simulator-v2/saga/data/policy.json could help.
    Also, double-check that Client Id = Thing name and that your certificates are connected to that specific name. It could also be that you have malformed the certificates in the certificates.h file. It's important to not add any additional information to the strings except \n. So you get something which looks like
    #define MY_CERT \
    "-----BEGIN RSA PRIVATE KEY-----\n"\
    "CERT_DATA_BASE64_INFO_IS_HERE/DEADC0DEDEADC0DEDEADC0DE\n"\
    "-----END RSA PRIVATE KEY-----\n"
    If that does not work I would try to debug by testing that the certificates work with the AWS Python SDK https://docs.aws.amazon.com/greengrass/latest/developerguide/IoT-SDK.html if you know python. They also have bindings for JS, Java, and C++ but the python and JS are the simplest ones to get up and running with certificates.
  • Just tried connecting with the DeviceClass example for JS https://github.com/aws/aws-iot-device-sdk-js and it worked like a charm. Both publishing and receiving messages.
    Can't see that I've made any mistakes entering the information from the certificates either, as this would be the only logical point of failure as far as I know. Not sure where to go from here...
    But maybe it's not a certificate error, since the error code changed when I added the correct public certificate, instead of the public key earlier?
  • I'm a bit out of ideas then, if the port, host, clientId, and certificates worked with the IoT SDK, it means that your AWS IoT setup is correct, so that leaves only the setup on the device. So I would make sure the client ID, host, and certificates are correctly setup on the device.
    It could still be a certificate error. Not getting -45 only means that the input is valid, meaning you stored something that looks like a CA in the CA slot in the modem (same goes for the rest). Unfortunately, it can't tell you if what you are given is more than a valid cert. So the ECONNREFUSED 61 could mean that the certificates contain some information that the server did not expect, meaning the one/some of the certificates could have been mangled in the certificates.h file when you wrote them to the modem. I recommend maybe trying to ensure the formating and that no extra characters have been added to it.
