My code bluetooth module hangs if I use flash storage functions inside the ble_evt_handler. I am using the functions from the fstorage example in peripheral folder.
I turned on debug, connected to module, updated the value and then it hangs and no matter what I do it does not return to normal, but the debug says that its still running. From the looks it does not even enter the ble_evt_handler (I know this from the Log command).
The code is below:
static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) //This function here handles any event that comes, just add the event name and fill in what you want to do when the event occurs. { ret_code_t err_code = NRF_SUCCESS; NRF_LOG_INFO("Got an Event!"); //To check if it comes here switch (p_ble_evt->header.evt_id) { case BLE_GATTS_EVT_WRITE: { nrf_fstorage_api_t * p_fs_api; p_fs_api = &nrf_fstorage_sd; #ifdef SOFTDEVICE_PRESENT NRF_LOG_INFO("SoftDevice is present."); NRF_LOG_INFO("Initializing nrf_fstorage_sd implementation..."); /* Initialize an fstorage instance using the nrf_fstorage_sd backend. * nrf_fstorage_sd uses the SoftDevice to write to flash. This implementation can safely be * used whenever there is a SoftDevice, regardless of its status (enabled/disabled). */ p_fs_api = &nrf_fstorage_sd; #else NRF_LOG_INFO("SoftDevice not present."); NRF_LOG_INFO("Initializing nrf_fstorage_nvmc implementation..."); /* Initialize an fstorage instance using the nrf_fstorage_nvmc backend. * nrf_fstorage_nvmc uses the NVMC peripheral. This implementation can be used when the * SoftDevice is disabled or not present. * * Using this implementation when the SoftDevice is enabled results in a hardfault. */ p_fs_api = &nrf_fstorage_nvmc; #endif err_code = nrf_fstorage_init(&fstorage, p_fs_api, NULL); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Initializing nrf_fstorage_sd implementation..."); /* Let's write to flash. */ NRF_LOG_INFO("Writing \"%x\" to flash.", p_data); err_code = nrf_fstorage_write(&fstorage, 0x3e100, &p_data, length, NULL); APP_ERROR_CHECK(err_code); //Waiting for operation to complete wait_for_flash_ready(&fstorage); NRF_LOG_INFO("Done."); //-----------------Testing - Reading---------------------- char m_hello_world[] = "hello world"; err_code = nrf_fstorage_read(&fstorage, 0x3e100, m_hello_world, length); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Reading \"%x\" to flash.", m_hello_world); wait_for_flash_ready(&fstorage); //-------------------------------------------------------- } }If I comment out the flash storage function (write and read) it works as it should.
Any leads would greatly be appreciated. (Do lemme know if additional information is required)
Edit 1: If I run this program in the main before the while loop, it works fine but I require it in the run time.
This works fine:
int main(void) { bool erase_bonds; log_init(); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); ble_stack_init(); //Here the BLE stack is initialized adc_configure(); //ADC for checking the battery gap_params_init(); gatt_init(); advertising_init(); //Making the iBeacon packet and the Data (major minor UUID etc) into a structure and passing it db_discovery_init(); //Commented this AUAK services_init(); //Initializing the services conn_params_init(); peer_manager_init(); //-------------Flash!----------------------------- Flash_Test(); //----------------------------------------- // Start execution. NRF_LOG_INFO("Beacon Start!."); advertising_start(erase_bonds); tx_power_set(); // Enter main loop. for (;;) { idle_state_handle(); } }
But does not work if I am using it in run-time (also tried to do it via raising a flag and executing the commands in timer but that did not work either.
