UART usage - I cannot see the light in the SDK
In advance I would like to say I’m sorry for the frustration that this message reflects…Event though I have been using the UART for some time, adding more functionality makes me search documentation for a UART description, and this makes me really frustrated.
I have what I think is a relatively simple need, I want to use UART0 and UART1 on a nRF32840 (both for some RS485 communication).
I do not care if it is NRF_DRV, NRFX or APP layer, anything that can be made to work will do!
Originally, I thought that selecting between NRF or NRFX was simple; documents suggest that NRF is legacy and I should use the "new" NRFX layer.
So selecting NRFX_UART_ENABLE would be logical and then including nrfx_uart.c driver file.....
But nothing is that simple with this SDK.... there always seems to be a mess of dependencies between configuration macros and files you need to include. and absolutely nothing that documents it (except heavy reading of header files of course ;-). I would love to see. “If you want this layer, tick this in SDK config and include ….”)
Well initial suggestion as above for NRFX just creates a bunch of errors…. so what is the combination needed...
It seems I can choose between using:
1 nrf_drv_uart
2 nrfx_uart
3 nrfx_uarte
4 app_uart
Can anyone suggest settings that will make just one of these options work, it would be highly appreciated and hopefully spare me a lot of testing and experimentation.
What I’m looking for what is a combination of what should be in SDK Config for
NRFX_UARTE section
NRFX_UART section
NRF_DRV (UART_ENABLED) section
APP_UART_ENABLED (+APP_FIFO_ENABLED) section
And any other sections that have dependencies!
I want to be able to call ???_init, send one or more bytes and receive bytes one by one
  • I used it with the SDK no problem.  uart interrupt is independent.  It should not interfere with i2c.  Only i2c & spi have shared interrupt.  Just make sure you disable uart in the sdk_config.h
    I looked at the nrf_prs.c, not really useful.  You can just disable it and everything still work fine.  embedded system is not a PC.  We know what are the io map we use.  There no sharing switch between them and the firmware is not an App that you load at runtime neither.  I really don't see the usefulness of that file.
