NRF52832 SAADC not reading ADC Values after pairing with NRFConnect App
Hi all,
My aim is to " read Four ADC Channels data and sent them to nRF Connect bluetooth app".
For doing this i used "saadc " and " ble_app_uart" examples.
Till now I am able to read four adc values before pairing my board(NRF52832) to NRFConnect bluettoth app but after pairing it(NRF52832) with NRFConnect app i am not able to receive ADC
values. Below i attached my program saadc and bluetooth source code.
Please help me to come out of this problem
void saadc_init(void)
ret_code_t err_code;
nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;
nrf_saadc_channel_config_t channel_0_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
channel_0_config.gain = NRF_SAADC_GAIN1_6;
channel_0_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
nrf_saadc_channel_config_t channel_1_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
channel_1_config.gain = NRF_SAADC_GAIN1_6;
channel_1_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
nrf_saadc_channel_config_t channel_2_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
channel_2_config.gain = NRF_SAADC_GAIN1_6;
channel_2_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
nrf_saadc_channel_config_t channel_3_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
channel_3_config.gain = NRF_SAADC_GAIN1_6;
channel_3_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);
void timer_handler(nrf_timer_event_t event_type, void* p_context)
printf("we are in timer_handler \n\r");
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400); //adc value reading every 400ms
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
/* ADC CMOS Bateery --------> AIN0
ADC_1_MCU_12V -----------> AIN1
MCU_F_Motor_Limit_SW1 --->AIN2
MCU_H_Motor_Limit_SW1 --->AIN3 */
// err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER); amarr commented
// APP_ERROR_CHECK(err_code);
int i,neg_buffer;
uint8_t percentage_batt_lvl;
char per = '%';
//printf("ADC event number: %d \n\r", (int)m_adc_evt_counter);
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
neg_buffer = p_event->data.done.p_buffer[i];
if(neg_buffer > 0)
if( i == 0)
ADC_CMOS_Battery = p_event->data.done.p_buffer[i];
printf("ADC_CMOS_Battery Channel[%d] = %d \n\r",i, p_event->data.done.p_buffer[i]);
percentage_batt_lvl_CMOS = battery_level_in_percent(ADC_CMOS_Battery);
// printf("ADC_CMOS_Battery percentage = %d%c\r\n",percentage_batt_lvl_CMOS,per);
else if(i == 1)
ADC_1_MCU_12V = p_event->data.done.p_buffer[i];
printf("ADC_1_MCU_12V Channel[%d] = %d \n\r",i, p_event->data.done.p_buffer[i]);
percentage_batt_lvl_CMOS = battery_level_in_percent(ADC_1_MCU_12V);
//printf("ADC_1_MCU_12V percentage = %d%c\r\n",percentage_batt_lvl_CMOS,per);
else if(i == 2)
MCU_F_Motor_Limit_SW1 = p_event->data.done.p_buffer[i];
printf("MCU_F_Motor_Limit_SW1 Channel[%d] = %d \n\r",i, p_event->data.done.p_buffer[i]);
MCU_H_Motor_Limit_SW1 = p_event->data.done.p_buffer[i];
printf("MCU_H_Motor_Limit_SW1 Channel[%d] = %d \n\r",i, p_event->data.done.p_buffer[i]);
neg_buffer = 0;
printf("ADC channel[%d] = %d \n\r",i,neg_buffer);
m_adc_evt_counter++;
Thank you,
Rgds,
amarr
