52832 saadc calibration issue
I have issue about calibartion using saadc.
I use 52832, S332, SDK 15.3.0
when calibration is excuting, ANT+ and BLE is also doing.
I use low power mode in saadc.
issue is first calibration is normal
but after that periodly do calibration (like one time for 30min) NRF_DRV_SAADC_EVT_CALIBRATEDONE event is not trigger.
I search about this one in nordic dev. I know PAN-86. but i can't find that. all link was broken..
second calibration process,  nrf_log_info(saadc is wating) <- infinite loop in here.
under blow is my code.
And If don't calibrate periodly, how much error about temperature drift ?  in doc, there is only gain error temperature coefficient (0.02%).
if I measure 25 degree, which temperature range is normal value in error?
Thank you.
void battery_config_value_init()
  memset(&saadc_config, 0 , sizeof(saadc_config));
  saadc_config.resolution         = (nrf_saadc_resolution_t)NRFX_SAADC_CONFIG_RESOLUTION; // 10bit
  saadc_config.oversample         = (nrf_saadc_oversample_t)NRFX_SAADC_CONFIG_OVERSAMPLE; // disable
  saadc_config.interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY;
  saadc_config.low_power_mode     = NRFX_SAADC_CONFIG_LP_MODE;
  memset(&channel_config, 0 , sizeof(channel_config));
  channel_config.resistor_p   = NRF_SAADC_RESISTOR_DISABLED;
  channel_config.resistor_n   = NRF_SAADC_RESISTOR_DISABLED;
  channel_config.gain         = NRF_SAADC_GAIN1_6;
  channel_config.reference    = NRF_SAADC_REFERENCE_INTERNAL;
  channel_config.acq_time     = NRF_SAADC_ACQTIME_10US;
  channel_config.mode         = NRF_SAADC_MODE_SINGLE_ENDED;
  channel_config.burst        = NRF_SAADC_BURST_DISABLED;
  channel_config.pin_p        = (nrf_saadc_input_t)(NRF_SAADC_INPUT_AIN0);
  channel_config.pin_n        = NRF_SAADC_INPUT_DISABLED;
static void user_battery_saadc_handler(nrf_drv_saadc_evt_t const * p_event)
   nrf_saadc_value_t *value =  p_event->data.done.p_buffer; // nrf_saadc_value_t = uint16_t
   switch(p_event->type)
     case NRF_DRV_SAADC_EVT_CALIBRATEDONE :
       CaliState = false;
     case NRF_DRV_SAADC_EVT_DONE :
       Calculate_Voltage(value, &voltage);
static void Calibration_init()
  NRF_LOG_INFO("SAADC Calibration Start");
  CaliState = true;
  nrf_drv_saadc_abort();
  while(nrf_drv_saadc_is_busy()){};
  while( nrf_drv_saadc_calibrate_offset() != NRF_SUCCESS ){
    NRF_LOG_INFO("SAADC is offset");
    NRF_LOG_PROCESS();
   while(CaliState){
     NRF_LOG_INFO("SAADC is waiting");
     NRF_LOG_PROCESS();
