After power turn off and on. Chip is not working
Hi
I made a custom board. (using nrRF52832)
At frist, I tested my code on 52DK(PCCA10040). It is worked.
And then I tested my code on custom board.
I changed my code in <sdk_config.h>.
Because my custom board haven`t optional 32kHz crystal.
// <h> Clock - SoftDevice clock configuration
// <o> NRF_SDH_CLOCK_LF_SRC - SoftDevice clock source.
#define NRF_SDH_CLOCK_LF_SRC 0
#define NRF_SDH_CLOCK_LF_RC_CTIV 16
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
#define NRF_SDH_CLOCK_LF_XTAL_ACCURACY 7
I used my custom board well.
(mpu6050 sensor(accel,gyro) + BLE)
But, Now my board is not working.
When <Build and Run> click in SES, it is works.
Sending for sensor value to BLE.
After <Build and Run>, I disconnected the j-link. and I connected power supply to 3V.
But It not works. Why?
(When connected to a power supply, the current shows that 0.008A is being applied. But Bluetooth is not advertised.
I found that there were a lot of problems with custom board such as Uart or Log. Therefore, they were all disabled.)
Let me know what part of what I'm missing.
Thank you for reading.
ps.  I used download to 52Dk board.
*Additional information*
I have a another computer(laptop).
and I have saved code in the laptop before problem.
So, I try the download for my custom board. but, problem is the same.
When I Debug or <Build and run>, It is sending the value to BLE.
but, When a custom boards turn off and on, it is not works.(switch on/off)
I think.. maybe sensor has broken?
so, I have 15 custom board. (spare)
I try other.
but, still not working.
Why?
Even....
Custom boards that previously downloaded code work well when powered on.
However, when I put the code back in, it doesn't work the same way.
I don`t know what I wrong ....
please help me.
  • Hi
    I used this power supply.
    I tested 52DK board. (sdk v15.3 ble_app_blink_pca_s132)
    after Debug -> It is works.
    and dk board turn off and connect p21 to power supply. -> it is works.
    but my code .... I tested 52Dk board.
    after Debug -> it is works.
    board turn off and connect p21 to power supply -> it is not working
     I think my code is wrong...
    The last changes code is data structure.
    It doesn't mean much.
    typedef
    int16_t accel_x;
    int16_t accel_y;
    int16_t accel_z;
    int16_t gyro_x;
    int16_t gyro_y;
    int16_t gyro_z;
    }sum_value_t
    -> change
    typedef
    int16_t gyro_z;
    int16_t gyro_y;
    int16_t gyro_x;
    int16_t accel_z;
    int16_t accel_y;
    int16_t accel_x;
    }sum_value_t
    I connected custom board ->
    ps. I disconnected with computer to Dk board for photo.
    Best regard,
    Han
  • Hi
    Okay, so there's definitely your project code that is causing this. Can you upload a snippet of where in your code you do advertising initialization and where you start advertising?
    Simon
  • int main(void)
    bool erase_bonds;
    // Initialize.
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    mpu_setup();
    advertising_start(erase_bonds);
    sum_values_t sum_values;
    // Enter main loop.
    for (;;)
                  power_manage();
                  if(start_accel_update_flag == true)
                          mpu_read_sum(&sum_values);
                          ble_mpu_update(&m_mpu, &sum_values);
                    start_accel_update_flag = false;
    In the middle, there is a part that initializes mpu6050. However, when debugging, it doesn't matter.
     What do you mean that it "doesn't matter"? Does the application skip it, or what. Please clarify. Also, if you could post a snippet showing the advertising initialization that would be great!
    Simon
  • Hi
    First, I'm sorry for using the expression "it doesn`t matter" to exclude the answer to check the connection of the mpu6050 from my custom board.
    The sensor is working. I succeeded in getting data through the line in the sensor of the custom board in Arduino.
    I don`t know how to "Also, if you could post a snippet showing the advertising initialization that would be great!"
    If it is related to "advertising_init" and "advertising_star"
    uint32_t ble_advertising_init(ble_advertising_t * const p_advertising,
    ble_advertising_init_t const * const p_init)
    uint32_t ret;
    if ((p_init == NULL) || (p_advertising == NULL))
            return NRF_ERROR_NULL;
    p_advertising->initialized = true;
    p_advertising->adv_mode_current = BLE_ADV_MODE_IDLE;
    p_advertising->adv_modes_config = p_init->config;
    p_advertising->conn_cfg_tag = BLE_CONN_CFG_TAG_DEFAULT;
    p_advertising->evt_handler = p_init->evt_handler;
    p_advertising->error_handler = p_init->error_handler;
    p_advertising->current_slave_link_conn_handle = BLE_CONN_HANDLE_INVALID;
    memset(&p_advertising->peer_address, 0, sizeof(p_advertising->peer_address));
    memset(&p_advertising->advdata, 0, sizeof(p_advertising->advdata));
    // Copy advertising data.
    p_advertising->advdata.name_type = p_init->advdata.name_type;
    p_advertising->advdata.include_appearance = p_init->advdata.include_appearance;
    p_advertising->advdata.flags = p_init->advdata.flags;
    p_advertising->advdata.short_name_len = p_init->advdata.short_name_len;
    p_advertising->advdata.uuids_complete = p_init->advdata.uuids_complete;
    p_advertising->advdata.uuids_more_available = p_init->advdata.uuids_more_available;
    p_advertising->advdata.uuids_solicited = p_init->advdata.uuids_solicited;
    p_advertising->advdata.include_ble_device_addr = p_init->advdata.include_ble_device_addr;
    if (p_init->advdata.p_manuf_specific_data != NULL)
    p_advertising->advdata.p_manuf_specific_data = &(p_advertising->manuf_specific_data);
    p_advertising->manuf_specific_data.data.p_data = p_advertising->manuf_data_array;
    p_advertising->advdata.p_manuf_specific_data->company_identifier =
    p_init->advdata.p_manuf_specific_data->company_identifier;
    p_advertising->advdata.p_manuf_specific_data->data.size = p_init->advdata.p_manuf_specific_data->data.size;
    for (uint32_t i = 0; i < p_advertising->advdata.p_manuf_specific_data->data.size; i++)
    p_advertising->manuf_data_array[i] = p_init->advdata.p_manuf_specific_data->data.p_data[i];
    if (p_init->advdata.p_service_data_array != NULL)
    p_advertising->service_data.data.p_data = p_advertising->service_data_array;
    p_advertising->advdata.p_service_data_array = &(p_advertising->service_data);
    p_advertising->advdata.p_service_data_array->data.p_data = p_advertising->service_data_array;
    p_advertising->advdata.p_service_data_array->data.size = p_init->advdata.p_service_data_array->data.size;
    p_advertising->advdata.p_service_data_array->service_uuid = p_init->advdata.p_service_data_array->service_uuid;
    for (uint32_t i = 0; i < p_advertising->advdata.p_service_data_array->data.size; i++)
    p_advertising->service_data_array[i] = p_init->advdata.p_service_data_array->data.p_data[i];
    p_advertising->advdata.service_data_count = p_init->advdata.service_data_count;
    if (p_init->advdata.p_slave_conn_int != NULL)
    p_advertising->advdata.p_slave_conn_int = &(p_advertising->slave_conn_int);
    p_advertising->advdata.p_slave_conn_int->max_conn_interval = p_init->advdata.p_slave_conn_int->max_conn_interval;
    p_advertising->advdata.p_slave_conn_int->min_conn_interval = p_init->advdata.p_slave_conn_int->min_conn_interval;
    if (p_init->advdata.p_tx_power_level != NULL)
    p_advertising->advdata.p_tx_power_level = p_init->advdata.p_tx_power_level;
    #if (NRF_SD_BLE_API_VERSION <= 2)
    for (int i = 0; i <BLE_GAP_WHITELIST_ADDR_MAX_COUNT ; i++)
    p_advertising->whitelist.pp_addrs[i] = &p_advertising->whitelist_addrs[i];
    for (int i = 0; i <BLE_GAP_WHITELIST_IRK_MAX_COUNT ; i++)
    p_advertising->whitelist.pp_irks[i] = &p_advertising->whitelist_irks[i];
    ret = ble_advdata_set(&(p_advertising->advdata), &(p_init->srdata));
    return ret;
    uint32_t ble_advertising_start(ble_advertising_t * const p_advertising,
    ble_adv_mode_t advertising_mode)
    uint32_t ret;
    ble_gap_adv_params_t adv_params;
    if (p_advertising->initialized == false)
    p_advertising->adv_mode_current = advertising_mode;
    // Delay starting advertising until the flash operations are complete.
    if (flash_access_in_progress())
    p_advertising->advertising_start_pending = true;
    return NRF_SUCCESS;
    if ( ((p_advertising->adv_modes_config.ble_adv_directed_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED))
    ||((p_advertising->adv_modes_config.ble_adv_directed_slow_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED))
    ||((p_advertising->adv_modes_config.ble_adv_directed_slow_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_SLOW))
    if (p_advertising->evt_handler != NULL)
    p_advertising->peer_addr_reply_expected = true;
    p_advertising->evt_handler(BLE_ADV_EVT_PEER_ADDR_REQUEST);
    p_advertising->peer_addr_reply_expected = false;
    p_advertising->adv_mode_current = adv_mode_next_avail_get(p_advertising, advertising_mode);
    // Fetch the whitelist.
    if ((p_advertising->evt_handler != NULL) &&
    (p_advertising->adv_mode_current == BLE_ADV_MODE_FAST || p_advertising->adv_mode_current == BLE_ADV_MODE_SLOW) &&
    (p_advertising->adv_modes_config.ble_adv_whitelist_enabled) &&
    (!p_advertising->whitelist_temporarily_disabled))
    #if (NRF_SD_BLE_API_VERSION >= 3)
    p_advertising->whitelist_in_use = false;
    p_advertising->whitelist_reply_expected = true;
    p_advertising->evt_handler(BLE_ADV_EVT_WHITELIST_REQUEST);
    p_advertising->whitelist_reply_expected = false;
    // Initialize advertising parameters with default values.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.type = BLE_GAP_ADV_TYPE_ADV_IND;
    adv_params.fp = BLE_GAP_ADV_FP_ANY;
    // Set advertising parameters and events according to selected advertising mode.
    switch (p_advertising->adv_mode_current)
    case BLE_ADV_MODE_DIRECTED:
    ret = set_adv_mode_directed(p_advertising, &adv_params);
    case BLE_ADV_MODE_DIRECTED_SLOW:
    ret = set_adv_mode_directed_slow(p_advertising, &adv_params);
    case BLE_ADV_MODE_FAST:
    ret = set_adv_mode_fast(p_advertising, &adv_params);
    case BLE_ADV_MODE_SLOW:
    ret = set_adv_mode_slow(p_advertising, &adv_params);
    case BLE_ADV_MODE_IDLE:
    p_advertising->adv_evt = BLE_ADV_EVT_IDLE;
    if (p_advertising->adv_mode_current != BLE_ADV_MODE_IDLE)
    ret = sd_ble_gap_adv_start(&adv_params, p_advertising->conn_cfg_tag);
    if (ret != NRF_SUCCESS)
    return ret;
    p_advertising->evt_handler(p_advertising->adv_evt);
    return NRF_SUCCESS;
    OR?
        ret_code_t             err_code;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    static void advertising_start(bool erase_bonds)
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED evetnt
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    I`m right?
    I hope that's the answer you want.
    Today as well, Thank you for reply.
    Han
