nRF52840 REG0 voltage accuracy
I have a couple of questions regarding the nRF52840 internal voltage regulators, specifically REG0. I couldn't find the answers from the datasheet and therefore I hope that the experts at this forum can help me.
We are currently developing a device that is powered from a 3.7V Li-ion battery. The plan is to use REG0 in high-voltage DC/DC mode for generating the 1.8V VDD supply and also to provide power for some external circuits. Now I'm a bit confused, because when I'm reading the electrical specifications it states that "VDD output voltage error (deviation from setting in REGOUT0 on page 46)" is min. -10% and max. +5%. Does this mean that I should use some other setting than the nominal 1.8V as the REGOUT0 register value in order to have some margin on top of the VDD minimum voltage specification (1.7V)? On the other hand the REGOUT0 register has only a few rather coarse options for the voltage setting (the next one is 2.1V), so does this mean that I should use it instead of 1.8V in order to eliminate the risk of having too low supply voltage due to tolerance variations?
Also what confuses me is the similar voltage value (1.8V) for REGOUT0 settings 0 and 7 (default). Does this mean that there is no difference at the output voltage regardless of which one of the settings is used?
