Running nRF52811 on nRF52832 Development Kit via Soldering nRF52811 chip onto Development Kit
So I want to run the nRF52811 chip so I removed the nRF52832 chip from its development kit and soldered the nRF52811 chip but I cannot seem to program it. What are the required settings I would be needing to change to make it work, for starters, a simple 'ble_app_beacon' example.
I am using Segger Embedded Studio (SES).
  • Ameer Usman said:
    I am using it on the PCA10040 Development Kit to program the nRF52811, could it be that is the problem?
     No.
    Ameer Usman said:
    That if I programmed it using the PCA10056 board it would work?
    That should also work, but that is not the root cause of the issue.
    Ameer Usman said:
    Also is it sure that programming a custom board of nRF52811 using the PCA10056 development kit as the programmer will work?
     Yes, use P19 or P20 to program the nRF52811, see here, or just use the on-board programmer that is present on the PCA10040.
    Did you follow the steps in the link I provided? Make sure to use PCA10056e as the base, and then modify it according to the steps in the link.
    Are you able to run nrfjprog -e on your custom board?
  • Did you follow the steps in the link I provided? Make sure to use PCA10056e as the base, and then modify it according to the steps in the link.
    I tried using it as the base and doing the modifications on the nRF52811 soldered on the PCA10040 nRF52832 development kit but it gives the below error:
    Gives this error in using PCA10056e:
    As for this:
    I need to make a few modifications to my other board to have the nRF52811 on it.
    But the nrfjrpog -e command is working on the nRF52811 soldered on PCA10040.
    Which error did you get?
  • It gives the error:
    'Failed to download application
    Generic Error
    Please Check J-Link and target Connection'
    Also I tried to run a fresh PCA10056e project on the nRF52840 development kit but it also gave the same Generic Error as mentioned before.
  • Finally, it worked. The issue was that when I opened the PCA10056e project it opened in the Non-commercial license of Segger Embedded Studio and did not even work with the nRF52840 whereas when I opened PCA10056 it showed licensed version of Segger Embedded Studio.
    So I reinstalled Segger Embedded Studio and it started to give licensed version also in the PCA10056e projects in SES.
    So in a nutshell, soldering nRF52811 onto the nRF52832 Development Kit board works with running the PCA10056e project with modifications in:
    If you have developed your application using the emulated project as a starting point, there is only one step you need to perform before you can run it natively on nRF52811: In your IDE, remove the DEVELOP_IN_NRF52840 and NRFX_COREDEP_DELAY_US_LOOP_CYCLES defines from the compile flags.
    Thanks Slight smile
