I am using a development board pro nrf52840 mini from Sparkfun.
I'm trying to use the TWI peripheral on nrf52840 to communicate with an external device (another microcontroller). The nrf52840 is supposed to be a slave on TWI and the external device to be the master. I'm using the example 'nRF5_SDK_15.3.0_59ac345\examples\peripheral\twi_master_with_twis_slave\' with SCL on PIN P0.11 and SDA on PIN P0.8 and I have a problem that the slave does not respond.
In this example, I do not know which instance of TWIS is activated and I do not find in the documentation which pins correspond to which TWIS instance.
From the external device, I scan for the TWI address in interval [1,127] and nrf52840 does not respond at any address.
Can you, please, tell me how can I modify this example code so the slave answers or can you provide an example to startup the slave and to receive data?
Thank you.
