I'm currently unable to build the asset_tracker for Thingy:91 on Segger Embedded Studio - using nrf9160_pca20035ns for the nRF Connect SDK Project
Do anyone have an idea why this occurs?
Br Dag
Br Dag
Yes, I followed the "Getting Started Assistant" when installing NCS -
And yes, the Pyhton scripts I'm refering to are those that seem to deploy the requirements description/files.
cd <sourcecode_root>\ncs
pip3 install -r zephyr\scripts\requirements.txt
pip3 install -r nrf\scripts\requirements.txt
pip3 install -r mcuboot\scripts\requirements.txt
Using Nordic as sourcecode root.
When running
the printouts tell me that most of the requirements are met but I also get a lot of red printouts as well.
Below is a random tiny fragment of the printout from the above command,
containing the Microsoft Visual C++ 14.0, which I find strange unless it is related to SES in some way.
... ... running build_ext generating cffi module 'build\\temp.win-amd64-3.8\\Release\\pygit2._libgit2.c' creating build\temp.win-amd64-3.8 creating build\temp.win-amd64-3.8\Release building '_pygit2' extension error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual C++ Build Tools": https://visualstudio.microsoft.com/downloads/ ---------------------------------------- ERROR: Failed building wheel for pygit2 Running setup.py clean for pygit2 Building wheel for editdistance (setup.py) ... error ERROR: Command errored out with exit status 1: command: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\dagak\\AppDat ... ...
Anyways - I'll look further into this tomorrow.
What Python version do you have?
Some of the dependencies have not yet updated to Python 3.8, so we recommend still using 3.7.
Regarding the specific error you get, the Python library is based on a C library. To build the C library, you need the "Microsoft Visual C++ Build Tools" toolchain.
So there is no need for the full Visual Studio, you just need the C++ toolchain.
Also, can you send me your ncs/zephyr/cmake/app/boilerplate.cmake?
Hi again
I just managed to build the asset_traker in full - on two PCs. Hurry:-)
Lessons learned:
According to your last comment on python38, this might be the reason for the massive red output when installing the stuff based on the nrf requirements, but asset_tracer was regardless built successfully.
Last question: Do you think that I should use Python37 instead og 38 for now?
Thanks for your support.
Br Dag
Btw - is it possible to use the USB connector on the Thingy91 to program/update it?
Great to hear that you got it working!
I would use 3.7, as I know that it works. I do not know how big of an issue it would be to use 3.8, but to be safe I would recommend using 3.7.
You should be able to downgrade using the following commands:
choco uninstall python choco install python --version 3.7.3
Didrik
