FDS - missing swap page
One of our devices is bricked due to the fds_init returning FDS_ERR_NO_PAGES. After flash analysis, I have discovered that all pages are marked as FDS_PAGE_DATA (no FDS_PAGE_SWAP). One of these pages is erased (just FDS_PAGE_TAG_MAGIC and FDS_PAGE_DATA header).
In our application, FDS is heavily used. During testing, we perform many power cycles. I do not have any clear reproduction path due to the fact that we found it just once (more than 200 devices online for a few months).
We are using SDK 14.2.0 with nRF52832 (custom board designs).
FDS flash dump can be found here: https://drive.google.com/drive/folders/1y_KOyIhVw9d-ZAAIc8SSa8k9vUOobDVz?usp=sharing
  • I have also experienced this issue with SDK 17.0.2. On one device calls to fds_init during boot returned the NO_SWAP error. Looking at the memory contents all the FDS pages were tagged as DATA.
  • Is there a reliable way of reproducing this?
    BR,
    Edvin
  • I am having the same issue.  I have not been able to reliably reproduce it, however, in my case at least one of the DATA  pages is empty.  This is a recoverable state as a blank data page can be erased and tagged as a SWAP page.
    I suggest adding a new enum value of PAGE_DATA_EMPTY
    enum
        PAGE_ERASED     = 0x1,  // One or more erased pages found.
        PAGE_DATA       = 0x2,  // One or more data pages found.
        PAGE_SWAP_CLEAN = 0x4,  // A clean (empty) swap page was found.
        PAGE_SWAP_DIRTY = 0x8,  // A dirty (non-empty) swap page was found.
        PAGE_DATA_EMPTY = 0x10, // One or more empty data pages found.
    and a new enum to fds_init_opts_t
        // The filesystem only contains data pages, but at least one data page is empty.
        // It is likely that the device powered off during GC. It is safe to discard (erase)
        // a empty data page, since there is nothing stored there.
        DISCARD_EMPTY_DATA             = (PAGE_DATA | PAGE_DATA_EMPTY),
    Handling this in a similar manner as DISCARD_SWAP (erase empty data page then init that page as a swap), will produce the same result.
  • Hi Rick N,
    I'm experiencing the same problem with the FDS and I really like your take on solving this problem.
    Do you perhaps have a more worked-out example of your solution?
    Thanks in advance.
    Remco Poelstra
  • My workaround was to check the flash pages prior to calling `fds_init`.  If there were no swap pages (`FDS_PAGE_SWAP`) and no blank pages (`FDS_PAGE_ERASED` or `FDS_PAGE_UNDEFINED`) I would perform a recovery.  Recovery would either erase a single data page, if a data page was blank (just header), or it would erase all flash storage pages (last resort, data is lost, but the MCU will recovery).  Also, if a page is `FDS_PAGE_UNDEFINED`, then I would erase that page because it is unknown what is on that page and it cannot be trusted.
    `fds_init` takes care of the rest.
