Loading nrf52840 software on Particle.io Boron, Argon and Xenon hardware
I have 3 Nordic nRF52840 usb dongles but I also have about 30 Particle Mesh devices. I wish to install some of my software that works on the USB the dongles onto the Particle Mesh devices.
All the Particle.io Mesh products (Boron-cellular, Argon-wifi, Xenon-only Mesh) have the nRF52840 SOC on their board. I wish to load some of the Nordic examples on their hardware, but some minor changes in how Particle installs software makes this very difficult. Is anyone at Nordic familiar with their products and have any suggestions for installing Nordic examples?
I don't own a j-tag connector, wondering if things can be done with the USB connection?
The two main issues are:
1. Most Nordic compiled files are in .hex format, Particle however first uses a berkely .elf format that is then converted into a binary .bin format
This code works but not sure if the .bin is correct to be installed.
arm-none-eabi-objcopy output/nrf52840/bin/ot-ncp-ftd -S -O binary output/nrf52840/bin/ot-ncp-ftd.bin
2. The Particle bootloader is not recognised by NRF connect, which Nordic bootloader might work and how would I install it.
particle flash --serial myBootLoader.bin
works for loading a Particle bootloader using the particle-cli software
  • So I think the best thing to do for the Particle Mesh devices is to get them connected to nrf-connect. From there I think most people would be fine programming them. My present plan is to try to merge the soft device s140_nrf52_6.0.0_softdevice.hex with an nrf52840 bootloader using mergehex to combine them and then try to install them on an Argon using nrfutil. Any other suggestions or a link to a bootloader that might work would be very useful.
