Trying to understand how SPI Slave should be implemented
Greetings!
I'm trying to set up an nRF52 board as an SPI slave so that it would receive chunks of data irregularly from the master device (a Raspberry Pi in this case, if it's important). However, I am not sure if I understand correctly the purpose of the SPIS API and how exactly should I use it. Here is how I'm doing it currently:
#include "nrfx_spis.h"
static nrfx_spis_t m_spis = NRFX_SPIS_INSTANCE(0);
static uint8_t rx_buffer[64];
static uint8_t tx_buffer[] = "HELLO";
static void spis_event_handler(nrfx_spis_evt_t const *p_event, void *p_context)
	nrfx_err_t err_code;
	switch (p_event->evt_type) {
	case NRFX_SPIS_BUFFERS_SET_DONE:
		NRF_LOG_DEBUG("Buffers Set Done");
	case NRFX_SPIS_XFER_DONE:
		NRF_LOG_DEBUG("XFer Done; RX %d / TX %d, Received: ", p_event->rx_amount, p_event->tx_amount);
		for (size_t i = 0; i < p_event->rx_amount; i++) {
			NRF_LOG_DEBUG("%d: %x", i, rx_buffer[i]);
		memset(rx_buffer, 0, 64);
		err_code = nrfx_spis_buffers_set(&m_spis, tx_buffer, 6, rx_buffer, 63);
static void spis_init()
	nrfx_spis_config_t spis_config = {
		.mosi_pin     = 11,
		.miso_pin     = 12,
		.sck_pin      = 13,
		.csn_pin      = 14,
		.mode         = NRF_SPIS_MODE_0,
		.bit_order    = NRF_SPIS_BIT_ORDER_MSB_FIRST,
		.csn_pullup   = NRFX_SPIS_DEFAULT_CSN_PULLUP,
		.miso_drive   = NRFX_SPIS_DEFAULT_MISO_DRIVE,
		.def          = NRFX_SPIS_DEFAULT_DEF,
		.orc          = NRFX_SPIS_DEFAULT_ORC,
		.irq_priority = NRFX_SPIS_DEFAULT_CONFIG_IRQ_PRIORITY,
	err_code = nrfx_spis_init(&m_spis, &spis_config, spis_event_handler, NULL);
int main(void) {
    spis_init();
	for (;;)
		idle_state_handle();
(I understand that I suppose to adjust buffers after transfers, but I don't think it's important for now).
Issue is, I'm not sure I completely understand the nrfx_spis_buffers_set function.
I.e, here is how I understand what I am doing. Please correct me if I misunderstood anything:
1. Init SPI device
2. Tell SPI that I have a RX and TX buffers ready with nrfx_spis_buffers_set
3. When Master initiates transfer, Master and Slave exchange bytes, up to tx_buffer_length bytes sent and rx_buffer_length received
4. After the transfer, event handler is called with NRFX_SPIS_XFER_DONE event type, tx_amount bytes transferred and rx_amount bytes received
5. Within the event handler, I must updates buffers if necessary and call nrfx_spis_buffers_set again with new data to be read/sent
For reference, here is the code for raspberry pi:
#!/usr/bin/env python3
import pigpio
pi = pigpio.pi()
if not pi.connected:
    print("connection failed")
    exit()
# slave 0, speed 50000, mode 0
s = pi.spi_open(0, 50000, 0)
data = bytearray("hello, world", "utf-8")
(count, rx_data) = pi.spi_xfer(s, data)
print("Received %s bytes: %s" % (count, rx_data))
So I'm trying to exchange "hello, world" string from raspberry pi and "HELLO" string from nRF52. However, in the end, I get something messed up:
<debug> app: XFer Done; RX 8 / TX 6, Received:
<debug> app: 0: 68 (h)
<debug> app: 1: 65 (e)
<debug> app: 2: 6C (l)
<debug> app: 3: 6C (l)
<debug> app: 4: 6F (o)
<debug> app: 5: 2C (,)
<debug> app: 6: 20 ( )
<debug> app: 7: 77 (w)
<debug> app: Buffers Set Done
<debug> app: XFer Done; RX 2 / TX 2, Received:
<debug> app: 0: 6F (o)
<debug> app: 1: 72 (r)
And on raspberry pi side:
Received 12 bytes: bytearray(b'HELLO\x00\xff\xff\xffHD\xff')
(I understand that I keep sending HELLO over and over again, but where did that D even came from?)
I was able to get a proper result once (i.e. withtin a single transfer, 12 bytes in one direction, 6 in another, all properly sent), but I was never able to get that again.
I think I should also mention that I tried enabling anomaly 109 workaround, but then I can't even init SPIS because of NRFX_ERROR_INTERNAL.
What am I doing wrong? I have a suspicion that I'm messing up buffers by declaring them like that; But is my understand of the process of SPI transfer correct? What here could cause those incomplete (and sometimes incorrect) transfers? What could be improved in the code?
Thanks in advance.
  • Hello! I borrowed a Logic Analyzer, and tried looking at the transactions. I noticed that any errors were also read by LA, so I decided that it's not the chip's fault, but I also noticed that timings were kinda weird and not matching whatever I set script to. So I went back to other SPI library, set a speed of 500khz (which was then properly measurable at LA), and it went with no errors.
    I am still not sure that I understand how exactly SPI transaction works on this level (one that I can see trough LA), _besides_ the obvious data transfer on clock edge, like what 'clocked-out' means in nRF52 documentation and what is the purpose of DEF and ORC from my perspective, and what is this small spike on MISO right after CS edge... (I still need to read more articles on SPI).
    But I think that this case is solved - I now know how to make a data transfer from RPi and how to receive it properly on nRF52, and maybe even troubleshoot it a bit with logic analyzer
    Thank you again!
    For future generations: here is my SPI code now
    import spidev
    spi = spidev.SpiDev()
    spi.open(0, 0)
    spi.max_speed_hz = 500000
    spi.mode = 0
    recv = spi.xfer2(bytearray("hello, world", "utf-8"))
    print("Recieved %s" % bytearray(recv))
    spi.close()
