Unable to create bootloader for nRF52832
I am creating a wearable PCB with the Raytac MDBT4Q-P BLE module, which uses the nRF52832. I need this device to have OTA firmware capability, but I'm finding it nearly impossible to create a simple bootloader. I'm following this guide for creating the bootloader. Unfortunately, I've been having all sorts of issues trying to set this up on Mac, Windows, or Linux operating systems. Before I do a deep dive into troubleshooting my issues, I need to ask; is there just a standard bootloader .hex file that I can download somewhere and flash to the board? The process for creating a simple bootloader is extremely convoluted and requires that multiple 3rd-party tools work perfectly.
Thank you,
Nick
  • No, the bootloader will write its start address to the MBR on boot and then following code line
    #define BOOTLOADER_ADDRESS      ((*(uint32_t *)MBR_BOOTLOADER_ADDR) == 0xFFFFFFFF ? *MBR_UICR_BOOTLOADER_ADDR : *(uint32_t *)MBR_BOOTLOADER_ADDR) /**< The currently configured start address of the bootloader. If 0xFFFFFFFF, no bootloader start address is configured. */
    will retrieve the bootloader address by de-referencing the pointer to the memory address where the bootloader address is stored.
    Best regards
    Bjørn
  • So you flash the precompiled bootloader hex and then you're not able to flash the buttonless DFU application from our SDK? Are you using Segger Embedded Studio?
  • Yes. I am using SES. SES says that the download is successful, but I don't see anything on the RTT logger. However, when I use J-Flash Lite to first erase the board before flashing the buttonless DFU example, then I see output on the logger.
  • I have had some issues with getting the RTT log to show up in SES when running a debug session. I am not quite sure what the cause for this is, but I have registered a support ticket with Segger on this.
    Are you using the Jlink RTT viewer when flashing the buttonless DFU example with J-Flash Lite? So you do not see any log output from the bootloader when flashing the precompiled bootloader hex?
    It could be that the bootloader is compiled with UART as the logger backend and not RTT.
  • I used J-Flash Lite to flash the bootloader to the board. I then used SES to flash the Buttonless DFU example directly from SES. When I did this after flashing the bootloader, I didn't see anything when connected to RTT viewer. However, if I erased the board using J-Flash Lite, then again flashing the buttonless DFU example with SES, I was able to see the error output on the RTT viewer application. The error was something like "bootloader not found...fatal error". This makes sense since the device was erased.
    I'm sure that the RTT logger backend was enabled. The UART was disabled in the sdk_config.h file.
