I need to use cJSON to parse the uart data. I found the file in SDK15.3 but how can I use the related function?
Depends on how you've implemented it. You can allocate a very small buffer, then send your data fragment by fragment at APP_UART_TX_EMPTY event (if you use app_uart_fifo). WIth nrfx_uarte library you don't need any intermediate buffer, transmission is done directly from buffer you've passed to tx function (just make sure not to free it until it transferred completely). nRF52840 can transfer up to 65535 bytes with nrfx_uarte, but if you require compatibility with lower series, you have to split transmission by 255 bytes.
OK. I will try that. But now there is another problem. When I use the cJSON_CreateNumber function, the system will crash. DEBUG found that when this function was called, it crashed in HardFault_Handler.
Further tracking reveals that as soon as I pass the external numeric data into the valuedouble of the cJSON structure, ie executing item->valuedouble=num(cJSON *item) will crash in HardFault_Handler
When I don't call cJSON_CreateNumber everything works fine, as soon as I call it, it will crash
How can I solve this problem?
Another new problem is that if I mask nrf_mem_init and cJSON_Init(). use malloc instead of nrf_malloc. Then cJSON_CreateNumber can be called normally, the item->valuedouble=num; in the function can be executed normally, if you use nrf_malloc, it will crash. (Excludes the extra effects, only calling cJSON_CreateNumber(2) in the main function.)
