I need to use cJSON to parse the uart data. I found the file in SDK15.3 but how can I use the related function?
I tried to set XXS and XXL to 500 and 300, everything is fine.. I can suppose that you have block sizes not ailgned to 4 (some instructions require word-aligned operands).
I don't know how to display debug traces (disassembly, stack, registers) where hard faults occur.
Keil debugger shows everything if you run program under debug session.
The memory block size needs to be a multiple of 4?
Standard malloc always allocates a word-aligned block. nrf_malloc will allocate a new block starting from next byte, so if your block size is not word-aligned, allocations will be unaligned too.
Byte alignment of memory! ! ! I know this concept until now. It’s true that the memory block size is set to a multiple of 4 and the problem disappears.
So, my understanding is that the byte alignment principle is followed when using malloc or nrf_malloc, and the memory address is aligned in 4 bytes. Is my understanding correct?
