GSP seems not working
I compiled and downloaded GPS sample, I got the following messages:
    Tracking: 0 Using : 0 Unhealthy : 0
Seconds since last fix: 600
Scanning [ _ ]
Over 10 minutes, it has not received any GPS data. Did I miss some thing?
The gps project running on nRF9160 Development Board.
Thank you,
David
  • My pleasure, David!
    I cannot give a definitive answer on which board is better, as that depends on application and other factors.
    The nRF9160 DK is a classic development kit, with lot's of I/O for your use, several buttons and switches for user input, and several leds user feed back. In other words it's a good platform for testing the capabilities of the nRF9160. Furthermore it is easily programmable(as there is a programmer on board), and you have easy access to the BLE capabilities of the on board nRF52840 as well. But, except for the GPS, it lacks any sensors. So you either have to "fake" some data, or connect and interface with external sensors yourself. Furthermore it's quite bulky, and does require some kind of external power.
    The Thingy:91 is as you say a multisensor prototyping kit, so it gives you great possibilities for testing with real data(also GPS) while also being quite portable and handy. It has one button and a RGB led as UI, but it  still lacks some of the versatility of the DK as you have less I/O, while also being a bit more of a hassle when it comes to programming it(though there are good guides on doing this).
    So to be clear, all revisions of Thingy:91 supports GPS out to the box to my knowledge. The same is true for revisions of the DK including 0.8.5 and up. But I would still recommend getting hold of an external antenna as both boards as of now don't have fantastic GPS performance regardless of revision.
    If you want to make sure that you get the right revision of the DK I suggest that you contact your supplier or Nordic staff to make sure that they give you the right one.
    All the best
    Carl Richard
