USB Mass Storage Class on external QSPI flash
Hello guys,
We are using SES and SDK15.3.0. Our SoC is from nRF52840 family. We have a custom board with external QSPI flash memory that we want to use as USB MSC device. After some consultations with Nordic technical support (see this thread), we selected  MX66L1G45G (3.0V) memory module for our external memory.
usbd_msc example from SDK 15.3.0 did not work on our custom board - disk initialization failed issue:
Changing the addressing mode to 32-bit (because we are using memory that is >128Mb) did not help. We changed the addressing mode inside sdk_config.h file as follows:
// <o> QSPI_CONFIG_ADDRMODE  - Addressing mode.
// <0=> 24bit
// <1=> 32bit
#ifndef QSPI_CONFIG_ADDRMODE
#define QSPI_CONFIG_ADDRMODE 1
// <o> NRFX_QSPI_CONFIG_ADDRMODE  - Addressing mode.
// <0=> 24bit
// <1=> 32bit
#ifndef NRFX_QSPI_CONFIG_ADDRMODE
#define NRFX_QSPI_CONFIG_ADDRMODE 1
QSPI link between our nRF52840 and external memory is OK because QSPI example is working properly.
Do you have any suggestions on what should we change in order to have usbd_msc example working on our custom board?
Thank you very much for your time and effort! It is really appreciated.
Sincerely,
Bojan.
  • when I include the following piece of the code before fatfs_init() function:
    nrf_drv_qspi_config_t config = NRF_DRV_QSPI_DEFAULT_CONFIG;
    err_code = nrf_drv_qspi_init(&config, qspi_handler, NULL);
    NRF_LOG_INFO("QSPI example started.");
    configure_memory();
    the init() function in the chain of calls:
    fatfs_init() >> disk_initialize(0) >> nrf_blck_dev_init() >> init()
    returns 0x8 error code which should be the code for NRF_ERROR_INVALID_STATE (Invalid state, operation disallowed in this state).
    When I remove the above piece of code before fatfs_init() function, the init() function returns error code 0x6 - NRF_ERROR_NOT_SUPPORTED
  • Try enabling the following in your sdk_config.h
    // <e> NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED
    #define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED 1
    // <o> NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL
    #define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL 4
    And after running once or twice with settings above, please run with the following as well:
    // <e> APP_USBD_MSC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef APP_USBD_MSC_CONFIG_LOG_ENABLED
    #define APP_USBD_MSC_CONFIG_LOG_ENABLED 1
    // <o> APP_USBD_MSC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_USBD_MSC_CONFIG_LOG_LEVEL
    #define APP_USBD_MSC_CONFIG_LOG_LEVEL 4
    This should give more information on what is going on.
    The last suggestion after adding debug information would be to test with the latest SDK v16.0.0.
  • Hello, .
    When I enable QSPI logs with what you suggested, I could basically see the same codes that
     function returns.
    The logs are <error> app: QSPI FLASH not supported (should correspond to return code 0x06) when I don't insert
    configure_memory();
    before fatfs_init().
    When I insert the above code before fatfs_init() function, I get QSPI log <error> app: QSPI init error: 8 which corresponds to return code 0x08 from init() function.
    Moving to SDK v16.0.0 did not help. I get completely the same returns from init() function and completely the same QSPI logs.
    I am starting to despair here!!! Cry
    What I want to do seems to be simple but still so much trouble experienced!
    Sincerely,
    Bojan.
  • We need to test everything. And I have forwarded this to the experts, so an answer will show itself soon. I have not heard back from them yet, will push for an answer. Do you have an nRF52840 DK? If so, could you try the code with that board?
  • Hello .
    Thanks for your efforts! I really appreciate it. Yes, I have nRF52840DK. usbd_msc example is working fine on that board. There is no need to add the code you suggested:
    configure_memory();
    Looking forward to reading from you.
    Sincerely,
    Bojan.
