USB Mass Storage Class on external QSPI flash
Hello guys,
We are using SES and SDK15.3.0. Our SoC is from nRF52840 family. We have a custom board with external QSPI flash memory that we want to use as USB MSC device. After some consultations with Nordic technical support (see this thread), we selected  MX66L1G45G (3.0V) memory module for our external memory.
usbd_msc example from SDK 15.3.0 did not work on our custom board - disk initialization failed issue:
Changing the addressing mode to 32-bit (because we are using memory that is >128Mb) did not help. We changed the addressing mode inside sdk_config.h file as follows:
// <o> QSPI_CONFIG_ADDRMODE  - Addressing mode.
// <0=> 24bit
// <1=> 32bit
#ifndef QSPI_CONFIG_ADDRMODE
#define QSPI_CONFIG_ADDRMODE 1
// <o> NRFX_QSPI_CONFIG_ADDRMODE  - Addressing mode.
// <0=> 24bit
// <1=> 32bit
#ifndef NRFX_QSPI_CONFIG_ADDRMODE
#define NRFX_QSPI_CONFIG_ADDRMODE 1
QSPI link between our nRF52840 and external memory is OK because QSPI example is working properly.
Do you have any suggestions on what should we change in order to have usbd_msc example working on our custom board?
Thank you very much for your time and effort! It is really appreciated.
Sincerely,
Bojan.
  • , can you please configure the following in sdk.config:
    / <e> NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED
    #define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_ENABLED 1
    // <o> NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL
    #define NRF_BLOCK_DEV_QSPI_CONFIG_LOG_LEVEL 4
    I've been discussing the error you get, and the issue may be due to FatFS. Please note the USB MSC example uses button 3 (#define BTN_MKFS 2)
    to create a fat volume. There might be an issue with disk_initialize in the sample, as this is handled by the fatfs module. Here is an example from the FatFS module
    /* Format default drive and create a file */
    int main (void)
        FATFS fs;           /* Filesystem object */
        FIL fil;            /* File object */
        FRESULT res;        /* API result code */
        UINT bw;            /* Bytes written */
        BYTE work[FF_MAX_SS]; /* Work area (larger is better for processing time) */
        /* Format the default drive with default parameters */
        res = f_mkfs("", 0, work, sizeof work);
        if (res) ...
        /* Gives a work area to the default drive */
        f_mount(&fs, "", 0);
        /* Create a file as new */
        res = f_open(&fil, "hello.txt", FA_CREATE_NEW | FA_WRITE);
        if (res) ...
        /* Write a message */
        f_write(&fil, "Hello, World!\r\n", 15, &bw);
        if (bw != 15) ...
        /* Close the file */
        f_close(&fil);
        /* Unregister work area */
        f_mount(0, "", 0);
    More information about the functions can be found here.
    Øyvind
  • Hey, .
    I changed sdk_config.h file according to your suggestions. I can see the same logs I was able to see before:
    <info> app: Initializing disk 0 (QSPI)...
    <info> app: m_drives[drv].config.wait_func = NULL
    <error> app: QSPI FLASH not supported
    <error> app: Error: nrf_blk_dev_init() function!
    <error> app: err_code: 0x6
    <info> app: Return state
    <error> app: Disk initialization failed.
    fatfs_init()>>disk_initialize(0) function fails. I am aware there is FatFS implementation in the base of usbd_msc example. By pressing a button 3 in usbd_msc example, fatfs_mkfs() function is called. However, this happens inside while(true) loop, and AFTER fatfs_init()>>disk_initialize(0) function calls.
    When I run the same code for my custom board on nRF52840 DK board without pressing ANY button, fatfs_init()>>disk_initialize(0) function passes without any problem!
    Sincerely,
    Bojan.
  • I have to apologize for my last reply, as I realize now that I must have been drunk or something. I see that I already asked you to edit sdk_config in this answer (Nov. 11).
     This is very interesting. What is different? I assume that it uses the default QSPI device on the DK?
    The specialists on QSPI have not returned from their holidays yet, and I expect them to be back on Monday. I will get back to you then.
    Sorry for the inconvenience!
    BR,
    Øyvind
  • Hey, !
    Yes, I am using the same default QSPI interface to communicate with the flash memory on my custom board. The only thing that is different is the flash memory!
    No worries, as soon as you have some feedback from your QSPI guys, please share it with me.
    Happy New 2020! Santa
    Best wishes and a lot of successful projects!
    Bojan.
  • Hello
    My sincerest apologies for the late reply. I have not got any response from our team. Still pushing for an answer!
    Øyvind
