How to use AWS IoT Just In TIme Provisioning(JITP) on nRF9160?
I'm attempting to use AWS IoT Just In TIme Provisioning(JITP), but no luck. Any help.
I tested JITP on my account, not Nordic one, with local mosuqitto client on Mac and it works out.
I know JITP is available on nRF Cloud, but want to use it on my account.
After I flash a firmware and push reset button. I get this error.
***** Booting Zephyr OS v1.14.99-ncs2 *****
The MQTT simple sample started
Deleting certs sec_tag: 16842753
nrf_inbuilt_key_delete(16842753, 0) => result=105
nrf_inbuilt_key_delete(16842753, 1) => result=105
nrf_inbuilt_key_delete(16842753, 2) => result=105
nrf_inbuilt_key_delete(16842753, 3) => result=105
nrf_inbuilt_key_delete(16842753, 4) => result=105
Write ca certs sec_tag: 16842753
CA_CERTIFICATE err: 105
LTE Link Connecting ...
LTE Link Connected!
ERROR: getaddrinfo failed 12
This line(105, NRF_ENOBUFS) means buffer is not sufficient according to this page.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrfxlib/bsdlib/doc/api.html
How can I solve this? Thanks.
This page explains JITP
https://aws.amazon.com/jp/blogs/iot/setting-up-just-in-time-provisioning-with-aws-iot-core/
<certificates.h>
#define CLIENT_ID "555555"
#define CLIENT_PRIVATE_KEY \
"-----BEGIN RSA PRIVATE KEY-----\n" \
"aaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbvvvvvvvvvvvvvvvvvvvvvvvvv\n" \
"-----END RSA PRIVATE KEY-----\n"
#define CLIENT_PUBLIC_CERTIFICATE \
"-----BEGIN CERTIFICATE-----\n" \
"biR8iAb8xoEkb0TyE/UcGFI2\n" \
"-----END CERTIFICATE-----\n" \
"JqvXo+GfWAvo1Zqj7ZGjpc+uNN4B6Kvib5s12PrtWTWfTZEuIHrBNCYs2DxN\n" \
#define CA_CERTIFICATE \
<prj.conf>
# General config
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_REBOOT=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_LOCK_BANDS=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# BSD library
CONFIG_BSD_LIBRARY=y
# AT Host
CONFIG_AT_HOST_LIBRARY=n
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
# Appliaction
CONFIG_MQTT_PUB_TOPIC="myTopic/publish"
CONFIG_MQTT_SUB_TOPIC="myTopic/subscribe"
CONFIG_MQTT_CLIENT_ID="555555"
CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxxxxxx.amazonaws.com"
CONFIG_MQTT_BROKER_PORT=8883
CONFIG_SEC_TAG=16842753
CONFIG_PROVISION_CERTIFICATES=y
CONFIG_CERTIFICATES_FILE="certificates.h"
# Main thread
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_NO_OPTIMIZATIONS=y
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
CONFIG_NET_UDP=n
CONFIG_NET_TCP=n
CONFIG_NET_RX_STACK_SIZE=256
CONFIG_NET_TX_STACK_SIZE=256
<main.c>
static int provision_certificate(void)
#if defined(CONFIG_PROVISION_CERTIFICATES)
#if defined(CONFIG_BSD_LIBRARY)
		int err;
		/* Delete certificates */
		nrf_sec_tag_t sec_tag = (nrf_sec_tag_t) sec_tag_list[0];
		for (nrf_key_mgnt_cred_type_t type = 0; type < 5; type++) {
			printk("Deleting certs sec_tag: %d\n", sec_tag);
			err = nrf_inbuilt_key_delete(sec_tag, type);
			printk("nrf_inbuilt_key_delete(%u, %d) => result=%d\n",
				sec_tag, type, err);
#if defined(CA_CERTIFICATE)
		/* Provision CA Certificate. */
		printk("Write ca certs sec_tag: %d\n", sec_tag);
		err = nrf_inbuilt_key_write(sec_tag,
			NRF_KEY_MGMT_CRED_TYPE_CA_CHAIN,
			CA_CERTIFICATE,
			strlen(CA_CERTIFICATE));
		if (err) {
			printk("CA_CERTIFICATE err: %d\n", err);
			return err;
#if defined (CLIENT_PRIVATE_KEY)
		/* Provision Private Certificate. */
		printk("Write private cert sec_tag: %d\n", sec_tag);
			sec_tag,
			NRF_KEY_MGMT_CRED_TYPE_PRIVATE_CERT,
			CLIENT_PRIVATE_KEY,
			strlen(CLIENT_PRIVATE_KEY));
		if (err) {
			printk("CLIENT_PRIVATE_KEY err: %d\n", err);
			return err;
#if defined(CLIENT_PUBLIC_CERTIFICATE)
		/* Provision Public Certificate. */
		printk("Write public cert sec_tag: %d\n", sec_tag);
			sec_tag,
			NRF_KEY_MGMT_CRED_TYPE_PUBLIC_CERT,
			CLIENT_PUBLIC_CERTIFICATE,
			strlen(CLIENT_PUBLIC_CERTIFICATE));
		if (err) {
			printk("CLIENT_PUBLIC_CERTIFICATE err: %d\n",
				err);
			return err;
#else
		int err;
		err = tls_credential_add(CONFIG_SEC_TAG,
			TLS_CREDENTIAL_CA_CERTIFICATE,
			NRF_CLOUD_CA_CERTIFICATE,
			sizeof(NRF_CLOUD_CA_CERTIFICATE));
		if (err < 0) {
			printk("Failed to register ca certificate: %d\n",
				err);
			return err;
			TLS_CREDENTIAL_PRIVATE_KEY,
			NRF_CLOUD_CLIENT_PRIVATE_KEY,
			sizeof(NRF_CLOUD_CLIENT_PRIVATE_KEY));
		if (err < 0) {
			printk("Failed to register private key: %d\n",
				err);
			return err;
			TLS_CREDENTIAL_SERVER_CERTIFICATE,
			NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE,
			sizeof(NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE));
		if (err < 0) {
			printk("Failed to register public certificate: %d\n",
				err);
			return err;
#endif /* defined(CONFIG_BSD_LIBRARY) */
#endif /* defined(CONFIG_PROVISION_CERTIFICATES) */
	return 0;
