Why don't I get a BLE_GATTS_EVT_SYS_ATTR_MISSING event?
This discussion got mixed up with a discussion about what Nordic means by a 'system attribute' (which is still not clear). In any case, in that discussion I was trying to save pairing/bonding information so I could restore it on a reconnect. The pairing keys worked. I grabbed the keys on the pairing complete event, saved them to a file, read them from that file, and gave them to the peer when asked on a reconnect in the BLE_GAP_EVT_SEC_INFO_REQUEST event.
But the CCCD information doesn't work that way. I can't restore the CCCD state using the same approach, because I cannot initialize the CCCD myself from the application (even prior to a connection). Instead I was told I need to get the 'system attributes' by calling this method sd_ble_gatts_sys_attr_get(), save them to a file, and restore them by calling this method sd_ble_gatts_sys_attr_set() when I get a BLE_GATTS_EVT_SYS_ATTR_MISSING event.
Fantastic! Sounds easy enough. However, I never get a BLE_GATTS_EVT_SYS_ATTR_MISSING event. I get this event BLE_GAP_EVT_SEC_INFO_REQUEST to restore the keys, so that works. What is missing?
    In the post you referred to I was referring to misbehavior from DevZone, and not to anything related to ble_gatts_evt_sys_attr_missing.
    What are the remaining issues that you see with ble_gatts_evt_sys_attr_missing?
    Terje
  • It still does not work. I cannot invoke a service changed and I cannot indicate/notify a peer on a reconnect UNLESS the peer rewrites the CCCDs.
    In order to figure out what is actually going on here, we would need a sniffer trace. For instance you can use the nRF Sniffer, which uses an nRF Dongle or DK.
    Terje
  • Microsoft Windows [Version 10.0.17763.973]
    (c) 2018 Microsoft Corporation. All rights reserved.
    E:\projects\BleTester\BtleTester\exe>BtleTester.exe
    Serial port used: COM9
    Baud rate used: 1000000
    Waiting on MQTT
    Message with token value 61 delivery confirmed
    Message arrived
       topic: pcha/message/WAN/Gyannea/CODE
       message: Payload: {"id":2,"Command":"config","common":{"deviceName":"BloodPressureOne","btaddress":"C00000001001","dis":{"trapRead":false,"useDefaultRegCert":true,"systemId":"FEEDABEEDEAD1001",
    "manufacturer":"LNI, Inc.","model":"BP_0001","serial":"snBp0001","firmware":"fw0.2.1"},"cts":{"currentTimeChar":{"trapRead":true,"allowWrite":true,"adjustReason":"None"}},"invokeServiceChanged":fa
    lse},"bp":{"trapMsmtCharRead":false,"bpFeatureChar":{"trapRead":false,"bodyMovement":true,"cuffFit":true,"irregularPulse":true,"pulseRange":true,"msmtPosition":true},"msmts":[{"hasTimeStamp":true,
    "units":"mmHg","hasUserId":false,"systolic":"110","diastolic":"62","mean":"80","pulseRate":"49","delay":1000},{"hasTimeStamp":true,"units":"kPa","hasUserId":false,"systolic":"14.66","diastolic":"8
    .25","mean":"10.64","pulseRate":"52","delay":1000},{"hasTimeStamp":true,"units":"mmHg","hasUserId":false,"systolic":"112.5","diastolic":"63.8","mean":"79.5","pulseRate":"44","delay":1000},{"hasTim
    eStamp":true,"units":"kPa","hasUserId":false,"systolic":"15.00","diastolic":"8.50","mean":"10.60","pulseRate":"67","delay":1000}]}}
    MQTT Signaled
    Mqtt queue entry signaled
    jsonString read from MQTT queue
    0x01 10 ad de ee ab ed fe
    0x01 10 00 00 00 c0
    Sending payload {"rspId":2,"success":true,"body":"Config command received for specialization Blood Pressure Monitor"}
    Waiting on MQTT
    Message with token value 62 delivery confirmed
    Message arrived
       message: Payload: {"id":3,"Command": "startAdvertising"}
    MQTT Signaled
    Waiting on MQTT
    Run signaled
    //================================================= Here the Nordic BP specialization is started.
    Creating or opening file BloodPressureOne for reading.
    File not found. It will be created when the specialization exits
    Info: Successfully opened COM9. Baud rate: 1000000. Flow control: none. Parity: none.
    Status: 6, message: Target Reset performed
    Status: 7, message: Connection active
    Service initiated
    Characteristic 0x2A23 initiated
    Characteristic 0x2A29 initiated
    Characteristic 0x2A24 initiated
    Characteristic 0x2A25 initiated
    Characteristic 0x2A26 initiated
    Characteristic 0x2A2A initiated
    Service initiated
    Characteristic 0x2A2B initiated
    Advertising data set
    Service initiated
    Characteristic 0x2A35 initiated
    Characteristic 0x2A49 initiated
    //========================================== Advertising started
    Started advertising at time 0
    Sending payload {"rspId":3,"success":true,"body":"Advertisement has started"}
    Message with token value 63 delivery confirmed
    //========================================== Connected to Android Client (the time is elapsed milliseconds from BP peripheral start)
    Connected at time 3281, connection handle 0x0001
    Connection parameters update at time 4110: min: 6 max: 6 supervision timeout: 2000 slave latency: 0
    //========================================== Android enabling service changed characteristic
    Client Enabling CCCD of characteristic handle 13 with value 2 at time 4297
    Connection parameters update at time 4719: min: 39 max: 39 supervision timeout: 2000 slave latency: 0
    //========================================== Android reading current time
    Characteristic 2A2B read at time 5078
    Read update reply response 0
    //========================================== Android requesting pairing because it tried to enable the BP Meausurement Characterisitic - secured
    //                                           so it Got 'insufficient authentication' error
    Peer requesting pairing at time 5469; Peer parameters:
        bonding: 1
        io_caps: 4
        max key size: 16
        min key size: 0
        MITM supported: 1
        Out of band supported: 0
        secure connections (LESC) supported: 1
        enable generation of keypress supported: 0
        peer keys distributed: LTK 1  IRK 1  LNK from LTK 1  SIGN 1
        own keys requested: LTK 1  IRK 1  LNK from LTK 1  SIGN 1
    Responding with own parameters at time 5469; Own parameters:
        bonding: 1
        io_caps: 3
        max key size: 16
        min key size: 8
        MITM supported: 0
        secure connections (LESC) supported: 0
        peer keys requested: LTK 1  IRK 1  LNK from LTK 0  SIGN 0
        own keys distributed: LTK 1  IRK 1  LNK from LTK 0  SIGN 0
    Result of sending security params 0
    Connection parameters update at time 5813: min: 6 max: 6 supervision timeout: 2000 slave latency: 0
    Security settings reported at time 5906:
        security level: 2
        security mode: 1
        key length: 16
    Result of pairing 0 at time 5953:
        bonded: 1
        peer keys: LTK 1  IRK 1  LNK from LTK 0  SIGN 0
        own keys: LTK 1  IRK 1  LNK from LTK 0  SIGN 0
    Keys:
        peer LTK 66, 54, 4A, DC, 5E, FC, 20, 41, AB, 15, 21, 6B, FF, FE, 0E, 28
        peer IRK 91, AC, 7A, 40, 9C, 78, 73, 42, 67, 51, 78, 3E, F3, A8, BB, 77
        peer Addrress D0, F0, C4, A6, B4, 88
        own LTK  E7, 5D, 8C, D7, B7, BE, 00, B0, 53, 28, 86, 7B, 90, 7B, 46, 7A
        own IRK D6, 31, FE, 19, F1, AE, 18, E8, E2, 76, 97, F7, F0, E9, 55, E6
    //========================================== Android Re-enabling BP measurement characteristic after pairing
    Enabling CCCD with 2 at time 6453
    //========================================== Nordic BP device sends measurements
    Send systolic 110 diastolic 62 mean 80
    Confirmation of indication on handle 33 received at time 6485
    Connection parameters update at time 6938: min: 39 max: 39 supervision timeout: 2000 slave latency: 0
    Send systolic 14.66 diastolic 8.25 mean 10.64
    Confirmation of indication on handle 33 received at time 7516
    Send systolic 112.5 diastolic 63.8 mean 79.5
    Confirmation of indication on handle 33 received at time 8594
    Send systolic 15.00 diastolic 8.50 mean 10.60
    Confirmation of indication on handle 33 received at time 9563
    End of primary pre-configured send
    Sending payload {"evtId":1,"event":"Pre-configured measurements sent."}
    //========================================== Now the controller will send a command to the BP device to disconnect
    Waiting on Run
    Message with token value 64 delivery confirmed
    Message arrived
       message: Payload: {"id":4,"Command": "stop"}
    MQTT Signaled
    //========================================== Disconnected - save pairing keys and CCCDs
    Disconnected at time 10781
    Disconnect completed
    Saving data to file at time 10797
    Saving file BloodPressureOne.
    saveDataLength: 20 saveDataBuffer 0D 00 02 00 02 00 1E 00 02 00 00 00 22 00 02 00 02 00 F7 CE
    Info: serial port COM9 closed.
    Closed at time 10797
    Cleaned up shut down specialization
    Sending payload {"evtId":2,"event":"Specialization Disconnected."}
    Message with token value 65 delivery confirmed
    Sending payload {"rspId":4,"success":true,"body":"Specialization stopped"}
    Waiting on MQTT
    Message with token value 66 delivery confirmed
    Message arrived
       message: Payload: {"id":6,"Command":"config","common":{"deviceName":"BloodPressureOne","btaddress":"C00000001001","dis":{"trapRead":false,"useDefaultRegCert":true,"systemId":"FEEDABEEDEAD1001",
    .25","mean":"10.64","delay":1000},{"hasTimeStamp":true,"units":"mmHg","hasUserId":false,"systolic":"112.5","diastolic":"63.8","mean":"79.5","pulseRate":"44","delay":1000},{"hasTimeStamp":true,"uni
    ts":"kPa","hasUserId":false,"systolic":"15.00","diastolic":"8.50","mean":"10.60","delay":1000}]}}
    MQTT Signaled
    0x01 10 00 00 00 c0
    Sending payload {"rspId":6,"success":true,"body":"Config command received for specialization Blood Pressure Monitor"}
    Waiting on MQTT
    Message with token value 67 delivery confirmed
    //========================================== Restart Nordic BP peripheral
    Message arrived
       message: Payload: {"id":7,"Command": "startAdvertising"}
    MQTT Signaled
    Waiting on MQTT
    Run signaled
    saveDataLength: 20
    Service initiated
    Service initiated
    Service initiated
    Sending payload {"rspId":7,"success":true,"body":"Advertisement has started"}
    Message with token value 68 delivery confirmed
    Connected at time 500, connection handle 0x0001
    Calling sd_ble_gatts_sys_attr_set with CCCD info
    Result of sending encryption params 0
    Security settings reported at time 1031:
        security level: 2
        security mode: 1
        key length: 16
    Client Enabling CCCD of characteristic handle 13 with value 2 at time 2390
    Characteristic 2A2B read at time 2484
    Message arrived
       message: Payload: {"id":8,"Command": "stop"}CODE
    MQTT Signaled
    Disconnected at time 60359
    Saving data to file at time 60359
    Sending payload {"evtId":1,"event":"Specialization disconnected unexpectedly."}
    Waiting on Run
    Message with token value 69 delivery confirmed
    Closed at time 60375
    Sending payload {"rspId":8,"success":true,"body":"Specialization stopped"}
    Waiting on MQTT
    Message with token value 70 delivery confirmed
    Message with token value 71 delivery confirmed
    BPNordicNoCCCD.cfaBPNordicNoCCCD.fscBPNordicNoCCCD.frmI have the Frontline BPA 600. Right now I am trying to stop the client from re-enabling when paired.
    Uploaded Frontline sniffs and a text file showing the output
    As far as I can tell the buffer with the CCCD info is correct
    I see the service changed set, the current time not set, and the BP measurement set.
    Still does not work. The client does not re-enable the measurement IF it has already done it and is paired.
  • Well, I have a sniff using the Frontline sniffer and it reveals nothing. I have a client that does not re-write the CCCDs after bonding and I get no data transfer. The first time when it DOES write the CCCD, the data is transferred. The next connection, no data is transferred because the CCCD is not re-written. I knew this would not reveal anything, but the sniff is attached. This has become critical now because I have a production client that cannot work with this dongle because the CCCDs cannot be reset on a reconnect. Its a pretty important part of the BTLE standard.
    The data from the get and set calls 0D 00 02 00 02 00 1E 00 02 00 02 00 F1 D1 looks correct so I have no idea what is going on. CCCDsDontWork.frmCCCDsDontWork.cfaCCCDsDontWork.fsc
