Hello ...
Implementing an app for both nRF51822 and nRF52810 and need a long-term clock with 100 Hz counter frequency to timestamp sensor events. By long-term, I mean at least 5 hours. I'm using TIMER1 and TIMER2 for other timing functions, so that leaves me with RTC0 or RTC1. Need use concurrent with BLE S110 (nRF51) or S112 (nRF52).
I understand RTC0 is used by the SoftDevice and therefore cannot be used. To develop my app I started with the example ble_peripheral/ble_app_uart and have been modifying/trimming. I'm testing on an nRF52 dev kit with nRF52810 emulation. It appears that ble_conn_params.c (Connection Parameters Negotiation library) uses app_timer library (app_timer_create() in ble_conn_params_init(), app_timer_start() in conn_params_negotiation(), and app_timer_stop() in on_disconnect()), which uses RTC1.
A simple solution would be to use RTC1 with prescaler of 327 which would give me 100 Hz resolution and 46+ hours before overflow.
It seems like ble_conn_params.c uses app_timer/RTC1 for connection parameter negotiation and only under erroneous conditions (if (!p_instance->params_ok)). I've found that once a BLE connection has been established, RTC1 is stopped and its counter value is 0, and remains so.
Can I access/control RTC1 directly after BLE connection is established? If yes, then I can set its prescaler to 327 (NRF_RTC1->PRESCALER = 327), start it (NRF_RTC1->TASK_START), and then use NRF_RTC1->COUNTER to read the value to get the number of 10.009574 ms ticks since RTC1 started. After disconnecting BLE, I would stop RTC1 and set its prescaler back to 0. Reasonable? I've implemented this and it appears to work well but I'm concerned about the risk of manipulating RTC1 while ble_conn_params.c is using app_timer/RTC1.
This post suggests it's possible to avoid using the Connection Parameters Negotiation library to avoid the need for/use of app_timer, which would free up RTC1 for exclusive use by my app. I would appreciate any guidance in how to do this. I'm new to Nordic SDK.
I'm also planning to implement RTC synchronization across multiple nRF5 devices using this blog post.
Thanks in advance for any guidance.
Tim
