saadc_event_handler not being called
Hello ...
New to Nordic SDK and trying to implement SAADC to read battery level. Have looked at a bunch of posts. I started with the ble_app_uart example app and tried to add SAADC code from the proximity example. Here's relevant code:
#include "nrfx_saadc.h"
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS  600  //!< Reference voltage (in milli volts) used by ADC while doing conversion.
#define ADC_RES_10BIT                  1024 //!< Maximum digital value for 10-bit ADC conversion.
#define ADC_PRE_SCALING_COMPENSATION   6    //!< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270  //!< Typical forward voltage drop of the diode (Part no: SD103ATW-7-F) that is connected in series with the voltage supply. This is the voltage drop when the forward current is 1mA. Source: Data sheet of 'SURFACE MOUNT SCHOTTKY BARRIER DIODE ARRAY' available at www.diodes.com.
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
        ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
static nrf_saadc_value_t adc_buf[2];
void saadc_event_handler(nrfx_saadc_evt_t const * p_event)
    if (p_event->type == NRFX_SAADC_EVT_DONE)
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
        err_code = nrfx_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
static void adc_configure(void)
    ret_code_t err_code = nrfx_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config =
        NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
    err_code = nrfx_saadc_channel_init(0, &config);
    err_code = nrfx_saadc_buffer_convert(&adc_buf[0], 1);
    err_code = nrfx_saadc_buffer_convert(&adc_buf[1], 1);
void read_battery_voltage(void)
    ret_code_t err_code;
    err_code = nrfx_saadc_sample();
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    adc_configure();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
I've added nrfx_saadc.c to the nRF_Drivers project folder.
I looked at sdk_config.h for the proximity example and set relevant defines accordingly:
// <e> NRFX_SAADC_ENABLED - nrfx_saadc - SAADC peripheral driver
#ifndef NRFX_SAADC_ENABLED
#define NRFX_SAADC_ENABLED 1
// <e> SAADC_ENABLED - nrf_drv_saadc - SAADC peripheral driver - legacy layer
#ifndef SAADC_ENABLED
#define SAADC_ENABLED 1
The app calls read_battery_voltage() in response to a message sent from the connected BLE central (iOS app). saadc_event_handler(...) is never called.
Thank you for any help. -Tim
