Understanding channel select on radio test example
Hello Nordic team,
I am trying to get my product read for FCC/CE compliance testing. I came across the radio_test example and other examples posted on DevZone. I have the following queries.
1) The Test lab wants me to test the product in 2402MHz, 2442MHz , 2480MHz. They want me to transmit in these frequencies separately. In the example channel is set to sweep from 0 to 80. Is it safe to assume that 0 is LOW; 40 is MED and 80 is HIGH? I am planning on doing a single channel sweep using
radio_tx_carrier(txpower_, mode_, channel);
radio_tx_sweep_start(txpower_, mode_, channel, channel, delayms_);
txpower_ and mode_ are the default values.
2) I do not have a spectrum analyzer, the infocenter piece explains that we can use a another board with the same example. Would this be in  rx_sweep mode? i am not very familiar with RF just yet so the more information provided would help me greatly.
Appreciate your time,
Tandon
  • Yes, either radio_modulated_tx_carrier or radio_unmodulated_tx_carrier, depending on if you want modulated carrier or not. The channel is determined when you call the function, as an example:
    void radio_modulated_tx_carrier(RADIO_TXPOWER_TXPOWER_Pos4dBm, RADIO_MODE_MODE_Ble_1Mbit, 40)
    will start the radio on channel 40, in BLE 1Mbps mode at 4 dBm. Changing the frequency by pushing a button takes some work, you need to add that to the GPIOTE button event handler.
    Andreas
