nRF Toolbox - UART App
We are using the Nordic nRF52840 on our current design.   Currently,   I am using nRF Toolbox -UART app on my
mobile phone to send data via 9 buttons available on the App. Everything is working fine as far as "sending"
data from the phone to the nRF52840 chip.
However, as far as I can tell,  the App does not have a "receive" feature built-in, is there anyway to find out
and verify that the phone can receive the data from the target board? perhaps with a different app?
Thanks  in advance
JIMMY
  • Hello Viidar,
    Currently, within the main() function I already have the uart_init() function below, and you meant I would need another uart_init() for the UARTE1?
    void main()
       uart_init();    //for UARTE0
    //need another uart_int() here for UARTE1 ?
    }//end main
    static void uart_init(void)
        uint32_t                     err_code;
            .rx_pin_no    = RX_PIN_NUMBER,            //#define RX_PIN_NUMBER       at file: pca10056.h
            .tx_pin_no    = TX_PIN_NUMBER,            //#define TX_PIN_NUMBER
            .rts_pin_no   = RTS_PIN_NUMBER,           //#define RTS_PIN_NUMBER
            .cts_pin_no   = CTS_PIN_NUMBER,           //#define CTS_PIN_NUMBER
            .use_parity   = false,
    #if defined (UART_PRESENT)
           //  NRF_UART_BAUDRATE_115200
           .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@snippet [UART Initialization] */
  • How the new function for UARTE1 can be distinguished from the UARTE0? I don't see anything mentioned in the uart_int()  to expose itself exclusively for UARTE0? I feel that the documentations provided is way insufficient for the user.  We need your help here.   Thanks    JIMMY
  • If you look at the app_uart_fifo.c::app_uart_init() function you can see that it's using the UART driver which I linked to earlier, and the UART instance ('0') is defined at the top of the same source file.
