hi...
i want to read the external accelerometer sensor using i2c in nRF52832 ..how to do ?
hi...
Hi... Amanda
i tried .. but i am getting constantly 0 as a value . see the code
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Common addresses definition for temperature sensor. */
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
uint32_t device_addr =0x4C ;
uint32_t register_addr= 0x00;
uint8_t *p_data;
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
if (NRF_SUCCESS == err_code)
nrf_drv_twi_enable(&m_twi);
NRF_LOG_INFO("TWI init success...");
static void read_register()
nrf_drv_twi_t twi_instance;
uint8_t *p_data; uint8_t bytes;
bool no_stop;
err_code = nrf_drv_twi_tx(&twi_instance, device_addr, ®ister_addr, 1, no_stop);
if(err_code != NRF_SUCCESS) {
return err_code;
err_code = nrf_drv_twi_rx(&twi_instance, device_addr, p_data, bytes);
return err_code;
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_init();
read_register();
while (1)
nrf_delay_ms(500);
NRF_LOG_INFO("\r\nTWI .");
printf("p_data:%d",p_data);
NRF_LOG_INFO("P_data:%d",p_data);
NRF_LOG_FLUSH();
