USB CCID class with nordic nRF52840
I am developing USB CCID driver class for nordic nRF52840. I used USB CDC-ACM class as reference and tried to implement for USB CCID. I have developed the device descriptor for it.
USB CCID class has 1 interface and 3 endpoints(1 for interrupt, 1 for bulk IN and 1 for bulk OUT). Now the windows is detecting as Microsoft Usbccid smart card reader(WUDF)
In modify the app_usbd_ccid_internal.h, i need to know modification to be done in
1. class instance data (app_usbd_ccid_inst_t)
2. CCID class specific request handled via control endpoint (app_usbd_ccid_req_t)
3.  ccid context (app_usbd_ccid_ctx_t)
I have attached my app_usbd_ccid_internal.h file with tis for refrence.
    Mohammad said:
    <info> usbd_ccid: ccid_event_handler = 5
    <info> usbd_ccid: setup_event_handler
    <info> usbd_ccid: setup_req_std_in
    <info> usbd_ccid: NRF_ERROR_NOT_SUPPORTED
     What is '5' in this case? Is that the p_event->app_evt.type? If yes, then that is the setup APP_USBD_EVT_DRV_SETUP, which should handle class specific requests. I do not have extensive knowledge about CCID, unfortunately, so I cannot state what should be implemented for this specific USB class.
    Mohammad said:
    But i have problem that the program stucks in infinte loop at this part
    while (app_usbd_event_queue_process())
    /* Nothing to do */
     Is it stuck inside there, or just not processing any events? It sounds like there's some CCID specific events that are not implemented?
    Håkon
    Yes, it is  p_event->app_evt.type.
    NRF_LOG_INFO("ccid_event_handler = %d", p_event->app_evt.type);
    Yes, it processes the events.
    Have you checked if the CCID class documentation has specific setup requests? Because it looks like there are unhandled/unimplemented cases in your implementation of the class.
    Håkon
    I have a problem with static ret_code_t setup_req_std_in(app_usbd_class_inst_t const * p_inst,
    app_usbd_setup_evt_t const * p_setup_ev)
      NRF_LOG_INFO("setup_req_std_in ");
      /* Only Get Descriptor standard IN request is supported by CCID class */
      if ((app_usbd_setup_req_rec(p_setup_ev->setup.bmRequestType) == APP_USBD_SETUP_REQREC_DEVICE) &&
    (p_setup_ev->setup.bRequest == APP_USBD_SETUP_STDREQ_GET_DESCRIPTOR))
         NRF_LOG_INFO("Inside setup_req_std_in ");
         size_t dsc_len = 0;
         size_t max_size;
         uint8_t * p_trans_buff = app_usbd_core_setup_transfer_buff_get(&max_size);
         /* Try to find descriptor in class internals*/
         ret_code_t ret = app_usbd_class_descriptor_find(p_inst, p_setup_ev->setup.wValue.hb,
    p_setup_ev->setup.wValue.lb, p_trans_buff, &dsc_len);
          if (ret != NRF_ERROR_NOT_FOUND)
              ASSERT(dsc_len < NRF_DRV_USBD_EPSIZE);
              return app_usbd_core_setup_rsp(&(p_setup_ev->setup), p_trans_buff, dsc_len);
       NRF_LOG_INFO("NRF_ERROR_NOT_SUPPORTED");
       return NRF_ERROR_NOT_SUPPORTED;
    ret_code_t ret = app_usbd_class_descriptor_find(p_inst,p_setup_ev->setup.wValue.hb,p_setup_ev->setup.wValue.lb,p_trans_buff,&dsc_len);
    It returns ret = NRF_ERROR_NOT_FOUND;
    In the above p_setup_ev->setup.wValue.hb = 6; (desc_type)
    p_setup_ev->setup.wValue.lb = 0;
    p_trans_buff = 26 03 48 00 53 00 49 00 44 00 36 (Here I dont now the actual length of p_trans_buff)
    dsc_len = 0;
    I find the above value by debugging the code.
    Inside the app_usbd_class_descriptor_find() function , the value of type as follows,
    4, 33, 5, 5, 5 (4 for interface, 33 for CCID, 5 for endpoint)
    So if(type == desc_type) condition is not satisfied.
    t returns ret = NRF_ERROR_NOT_FOUND; from app_usbd_class_descriptor_find
    Help me to solve this issue
  • That can potentially happen (ie: the request wasn't for this specific descriptor), which is the reason why all class implementations forward that to the app_usbd_core.c::app_usbd_core_setup_rsp().
    It is hard to tell what happens here, as I do not have all the details. What is the expected vs. actual behavior that you're seeing?
    Håkon
