Device not connecting in boot loader mode
Hello ,
I am using nRF52832 controller in peripheral role. I have integrated Secure boot loader code. I am facing issue of mobile device is not getting connected to the DFU service in boot-loader.
When device is in Application  it is connected and operation is fine,but after entering DFU by triggering command from DFU service to enter boot-loader mobile does not get connected but device remains in boot-loader mode. SDK used is 15.2.0 . Secure bootloader example code from DFU section is used.
I am using Custom board with ready module integrated  of nrf52832 from RAYTAC (MDBT42Q-512KV2). Board has Power supply regulator on board. Input supply voltage 10 v to 30 v with 500 mA current rating. When i use supply input of 5 volt it works perfectly. But for 12 volts it gives me above error behavior. This issue is been faced after flashing secure boot-loader code. Without boot-loader code simple application works totally fine.
Thanks in advance.
  • Have you enabled bonding in the bootloader project? Maybe the device doesn't do service discovery because it thinks it already knows the services? If you require bonding in the bootloader then it will not increment the BLE address. The address is usually incremented to trigger a service discovery.
    ssc said:
    <info> app: No firmware to activate.
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: No valid app to boot.
     These lines indicates that there is no valid application in the memory. Is the application programmed to the nRF? If so, how was it programmed? Via DFU or via programmer? If programmer, did you also program the correct signed bootloader settings?
    No. for disabling bond i have done:
    // <h> BLE DFU security
    // <q> NRF_DFU_BLE_REQUIRES_BONDS - Require bond with peer.
    #ifndef NRF_DFU_BLE_REQUIRES_BONDS
    #define NRF_DFU_BLE_REQUIRES_BONDS 0
    Yes these logs are right there is no application firmware as i have erased whole flash and only flashed boot loader code.  I am not able to connect to the device in boot loader mode only.
    This issue occurred when Regulator used was DCDC converter for 5 volt input to LDO (3.3V) and then to controller. So i tested with replacing DCDC to LDO (12 to 5 V) converter for 5 volt input to LDO (3.3V) and then to controller. Then also issue remained same.
    Then i tested for LM7805  regulator IC and then tested for the Output and then probability of getting failure was reduced. But issue is still there. My total PCB Load current takes 50 mA. and ripples checked at capacitor of LDO is 15mV. Is there any noise or any current related requirements which are failed here for Controller? Or any functionality which i am missing
  • Can you send me the logs from when it is working and when it isn't?
     This LDO is external, right?
     That is including external components? Not the nRF?
    11:17 19-11-2019
    Plain DFU bootloader code Debug logs with 24 V SMPS supply:
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Settings OK
    <debug> app: Enter nrf_bootloader_fw_activate
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x200057D4)
    <debug> app: timer_activate (0x200057D4)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: No advertising name found
    <debug> nrf_dfu_ble: Using default advertising name
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: BLE DFU transport initialized.
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    <debug> app: Enter main loop
    <debug> nrf_dfu_ble: Connected
    <debug> app: timer_fire (0x200057D4)
    <info> app: Inactivity timeout.
    <debug> app: Resetting bootloader.
    <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    12:14 19-11-2019
    These are Debug logs for perfectly working DFU_BLE_SECURE_BOOTLOADER EXAN+MPLE CODE:(3.3VSupply given from developement KIT )
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A1E8, pending 2
    <debug> nrf_dfu_ble: Freeing buffer 0x20008100
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A2DC, pending 1
    <debug> nrf_dfu_ble: Freeing buffer 0x200081F4
    <debug> nrf_dfu_ble: Buffer 0x200081F4 acquired, len 244 (244)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A3D0, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A3D0, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A4C4, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A4C4, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A5B8, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_ble: Buffer 0x20008100 acquired, len 244 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A6AC, src=0x20008100, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A5B8, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A6AC, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A7A0, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A7A0, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A894, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A894, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002A988, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002A988, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AA7C, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AA7C, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AB70, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AB70, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AC64, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AC64, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AD58, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AD58, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AE4C, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_ble: Buffer 0x200081F4 acquired, len 192 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002AF40, src=0x200081F4, len=192 bytes), queue usage: 2
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:20480, CRC:0xB9D1AF44
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AE4C, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002AF40, pending 1
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002B000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00005000, CRC: 0xB9D1AF44
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B000, src=0x200081F4, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002B000, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B0F4, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B0F4, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B1E8, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B1E8, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B2DC, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B3D0, src=0x20008100, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B2DC, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B3D0, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B4C4, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B4C4, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B5B8, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B6AC, src=0x200081F4, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B5B8, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B6AC, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B7A0, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B7A0, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B894, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B894, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002B988, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002B988, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BA7C, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BA7C, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BB70, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BB70, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BC64, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BC64, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BD58, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BD58, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BE4C, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_ble: Buffer 0x20008100 acquired, len 192 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002BF40, src=0x20008100, len=192 bytes), queue usage: 2
    <debug> nrf_dfu_req_handler: Offset:24576, CRC:0x06A6029F
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BE4C, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002BF40, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002C000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00006000, CRC: 0x06A6029F
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002C000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C000, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C0F4, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C1E8, src=0x200081F4, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C0F4, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C1E8, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C2DC, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C2DC, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C3D0, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C4C4, src=0x20008100, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C3D0, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C4C4, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C5B8, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C5B8, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C6AC, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C7A0, src=0x200081F4, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C6AC, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C7A0, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C894, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C894, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002C988, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CA7C, src=0x20008100, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002C988, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CA7C, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CB70, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CB70, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CC64, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CC64, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CD58, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CD58, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CE4C, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002CF40, src=0x200081F4, len=192 bytes), queue usage: 2
    <debug> nrf_dfu_req_handler: Offset:28672, CRC:0xCB9A65E3
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CE4C, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002CF40, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0002D000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 3484. Offset: 0x00007000, CRC: 0xCB9A65E3
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0002D000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D000, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D000, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D0F4, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D1E8, src=0x20008100, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D0F4, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D1E8, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D2DC, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D2DC, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D3D0, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D4C4, src=0x200081F4, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D3D0, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D4C4, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D5B8, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D5B8, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D6AC, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D7A0, src=0x20008100, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D6AC, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D7A0, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D894, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D894, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002D988, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002D988, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DA7C, src=0x20008100, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DB70, src=0x200081F4, len=244 bytes), queue usage: 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DA7C, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DB70, pending 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DC64, src=0x200081F4, len=244 bytes), queue usage: 1
    <debug> nrf_dfu_ble: Buffer 0x20008100 acquired, len 68 (244)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0002DD58, src=0x20008100, len=68 bytes), queue usage: 2
    <debug> nrf_dfu_req_handler: Offset:32156, CRC:0xB422D443
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DC64, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0002DD58, pending 1
    <debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
    <debug> nrf_dfu_validation: Hash verification. Firmware start address: 0x26000, size: 0x7D9C
    <debug> nrf_dfu_validation: Invalidating old application in bank 0.
    <info> nrf_dfu_settings: nrf_dfu_settings_write_and_backup.
    <debug> nrf_dfu_settings: Writing settings...
    <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x2000919C, len=440 bytes), queue usage: 2
    <debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 3
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20009354, len=440 bytes), queue usage: 4
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 4
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 3
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 2
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 1
    <debug> nrf_dfu_req_handler: All flash operations have completed. DFU completed.
    <debug> nrf_dfu_ble: Shutting down BLE transport.
    <debug> nrf_dfu_ble: Disconnecting.
    <debug> nrf_dfu_ble: BLE transport shut down.
    <info> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: memcpy setttings.
    <debug> app: Valid App
    <debug> app: Enter nrf_dfu_app_continue
    <debug> app: No copy needed src_addr: 0x26000, dst_addr: 0x26000
    <debug> app: Setting app as valid
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x2000919C, len=440 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x20009354, len=440 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0
    <debug> app: Return true. App was valid
    <debug> nrf_dfu_settings_svci: Erasing settings page additional data.
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 0
    <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
    <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
    <debug> app: running irq table set
    <debug> app: After running irq table set
    12:21 19-11-2019
    Debug logs for DFU_BOOTLOADER with Application code and 24 V supply given from SMPS:
    <debug> app: DFU mode requested via GPREGRET.
    <info> nrf_bootloader_wdt: WDT enabled CRV:163840 ticks
    <info> nrf_bootloader_wdt: Starting a timer (160640 ticks) for feeding watchdog.
    <debug> app: timer_activate (0x200057E4)
    <debug> app: timer_stop (0x200057E4)
    <debug> app: timer_fire (0x200057E4)
    <info> nrf_bootloader_wdt: Internal feed
    Yes
    Yes that is including external components. Overall PCB load corrent taken from supply.
  • Does this mean that it works on the DK, but not on the custom PCB? Did you have a log from the custom PCB with Voltage = 5v, when it was working? Or is it not working when you have 5v on the custom PCB either?
    Also, I didn't understand the DK log. Does the log start in the middle of the DFU process?
