I am using SDK 15.3 and wanted to ask that if there is a while loop where I can check flags and increment tickers. The program at the moment gets stuck inside
for (;;) { idle_state_handle(); }
Suggestions would be greatly appreciated.
No, the idle_state_handle() will put the IC into a low-power state until an event occurs. Any functions placed after the idle_state_handle() will be called after the IC has "woken up" from the low power state to handle the event generated.
regards
Jared
So in short the placing the flag after idle_state_handle() of perform_blink() or in my case change_advert_type() is ok to do? As I want to perform change_advert_type() right after an event is performed by checking a flag in the for loop.
I can't see any problems with it.
regards
Jared
Great, Thank you Jared
