SDK:V15
chip:52832
development kit:window+keil
In stm32,inder to use uart rx with DMA, we could easily use:uart Idle interrupt+dma.but how in 52832 while how many byte of a frame to recevie is uncertainty?
in order to test,i designed a master mcu to transmit circulaly,each frame 11byte,period is 1s,baud 1M.
How to config 52832 uarte rx?
my try:set RXD.MAXCNT 255(a big buf). A time hanlder function(detect_a_frame) which call back each 1ms.in this funtion,read RXD.AMOUNT ,judge wheather recevie amount of buf had changed.if its amount unequal to 0,also stop change,regard a frame recevie finish.call function to change rx dma fifo manually.
unfortunately, it don't work.because i found that RXD.AMOUNT will not update until fill up rxbuf.like below:(the mosaic is the data had recevied, here maybe had run few second)
How could i make it work in case of 1M baud???I really holp for your help or offer a successful demo.Appreciate!!!
