I can't add more than 4 characteristics
Hi everyone !
I have 3 services and 13 characteristics in my project. Until today, 3 characteristics were working fine. But i added rest of the characteristics and my project stop working. (There is no build error). I tried to set breakpoint on sd_ble_gatts_characteristic_add function but i couldn't take any return value. I used nRF52810. When i add other characteristics, the relays in my circuit and my sensors are not working properly. I searched  about this problem and tried most of the solutions but nothing change.
SoftDevice s112 6.0.0
Here is my Section Placement Macros :
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x30000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x6000
FLASH_START=0x19000
FLASH_SIZE=0xda000
RAM_START=0x20001c18
RAM_SIZE=0x3dd50
I have three questions:
  1. Why i couldn't take any return value from this function ? (I can see other function's return value in debug mode)
  2. Do i need to add 16 bit ram size per UUID ? How to calculate it ?
I made "#define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408" and "#define NRF_SDH_BLE_VS_UUID_COUNT 13"
Here is our_service.h :
#ifndef OUR_SERVICE_H__
#define OUR_SERVICE_H__
#include <stdint.h>
#include "ble.h"
#include "ble_srv_common.h"
// FROM_SERVICE_TUTORIAL: Defining 16-bit service and 128-bit base UUIDs
//#define BLE_UUID_OUR_BASE_UUID              {{0x33, 0xD1, 0x13, 0xEF, 0x5F, 0x78, 0x63, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}}
#define BLE_UUID_OUR_BASE_UUID              {{0x64, 0x4F, 0x76, 0xF7, 0xA6, 0x52, 0x42, 0xBC, 0xE9, 0x11, 0xD2, 0x91, 0xDA, 0x10, 0xE4, 0xAE}} // 128-bit base UUID
#define BLE_UUID_OUR_SERVICE_UUID                  0xF00D // Maintenance Service
#define BLE_UUID_OUR_SERVICE_UUID_2                0xF00E // Setting Service
#define BLE_UUID_OUR_SERVICE_UUID_3                0xF00F // Custom Setting Service
// ALREADY_DONE_FOR_YOU: Defining 16-bit characteristic UUID
#define BLE_UUID_OUR_CHARACTERISTC_UUID          0xBEEA // Sensor Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_2        0xBEEB // Transmitter Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_3        0xBEEC // Motor Delay Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_4        0xBEED // Custom Setting Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_5        0xBEAA // Device Configuration Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_6        0xBEAB // Light 1 Configuration Register Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_7        0xBEAC // Light 2 Configuration Register Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_8        0xBEAD // Motor 1 Configuration Register Characteristic
#define BLE_UUID_OUR_CHARACTERISTC_UUID_9        0xBEAE // Motor 2 Configuration Register Characteristic
// This structure contains various status information for our service.
// The name is based on the naming convention used in Nordics SDKs.
// 'ble? indicates that it is a Bluetooth Low Energy relevant structure and
// ?os? is short for Our Service).
typedef struct
    uint16_t                    conn_handle;    /**< Handle of the current connection (as provided by the BLE stack, is BLE_CONN_HANDLE_INVALID if not in a connection).*/
    uint16_t                    service_handle; /**< Handle of Our Service (as provided by the BLE stack). */
    uint16_t                    service_handle_2;
    uint16_t                    service_handle_3;
    // OUR_JOB: Step 2.D, Add handles for the characteristic attributes to our struct
    ble_gatts_char_handles_t    char_handles;
    ble_gatts_char_handles_t    char_handles_2;
    ble_gatts_char_handles_t    char_handles_3; //Motor Delay Char. Handle
    ble_gatts_char_handles_t    char_handles_4; //Custom Setting Char. Handle
    ble_gatts_char_handles_t    char_handles_5; // DCR Char.Handle
    ble_gatts_char_handles_t    char_handles_6; // L1CON Char. Handle
    ble_gatts_char_handles_t    char_handles_7; // L2CON Char. Handle
    ble_gatts_char_handles_t    char_handles_8; // M1CON Char. Handle
    ble_gatts_char_handles_t    char_handles_9; // M2CON Char. Handle
}ble_os_t;
/**@brief Function for handling BLE Stack events related to our service and characteristic.
 * @details Handles all events from the BLE stack of interest to Our Service.
 * @param[in]   p_our_service       Our Service structure.
 * @param[in]   p_ble_evt  Event received from the BLE stack.
void ble_our_service_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context);
/**@brief Function for initializing our new service.
 * @param[in]   p_our_service       Pointer to Our Service structure.
void our_service_init(ble_os_t * p_our_service);
/**@brief Function for updating and sending new characteristic values
 * @details The application calls this function whenever our timer_timeout_handler triggers
 * @param[in]   characteristic_value     New characteristic value.
void our_sensor_characteristic_update(ble_os_t *p_our_service, int32_t *voltage);
void our_trm_error_characteristic_update_2(ble_os_t *p_our_service, int32_t *TRM_Signal);
#endif  /* _ OUR_SERVICE_H__ */
Here is our_service.c :
#include <stdint.h>
#include <string.h>
#include "nrf_gpio.h"
#include "our_service.h"
#include "app_error.h"
extern uint8_t setup_register[4];
extern int motor_delay;
extern bool ble_motor_stop_flag;
extern uint8_t MCON,L2CON,L1CON,M2CON;
int16_t data;
// Declaration of a function that will take care of some housekeeping of ble connections related to our service and characteristic
        ble_gatts_evt_write_t * p_evt_write;
  	ble_os_t * p_our_service =(ble_os_t *) p_context;
		//Implement switch case handling BLE events related to our service.
                    case BLE_GAP_EVT_CONNECTED:
                        p_our_service->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
                        p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID;
                    case  BLE_GATTS_EVT_WRITE:
                        p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
                        nrf_gpio_pin_clear(28);
                        //setup_register[4]=NULL;
                        if(p_evt_write->handle == p_our_service->char_handles_3.value_handle) //If the write event come from characteristic 3 // write i?lemi ger?ekle?en characteristic 3. ise
                          if(*p_evt_write->data == 0x10)
                              motor_delay = 10;
                          else if(*p_evt_write->data == 0x15)
                              motor_delay = 50;
                          else if (*p_evt_write->data == 0x20)
                              motor_delay = 100;
                          else if (*p_evt_write->data == 0x00)
                              motor_delay = 0;
                        }else if (p_evt_write->handle == p_our_service->char_handles_4.value_handle)
//                          setup_register[0] = (int*)p_evt_write->data[0];
//                          setup_register[1] = (int*)p_evt_write->data[1];
//                          setup_register[2] = (int*)p_evt_write->data[2];
//                          setup_register[3] = (int*)p_evt_write->data[3];
                          M2CON = p_evt_write->data[0];
                          L1CON = p_evt_write->data[1];
                          L2CON = p_evt_write->data[2];
                          MCON = p_evt_write->data[3];
                        // No implementation needed.
/**@brief Function for adding our new characterstic to "Our service" that we initiated in the previous tutorial.
static uint32_t sensor_char_add(ble_os_t * p_our_service)
    //Add a custom characteristic UUID
    uint32_t      err_code;
    ble_uuid_t    char_uuid;
    ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID;
    char_uuid.uuid          = BLE_UUID_OUR_CHARACTERISTC_UUID;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
    //Add read/write properties to our characteristic
    ble_gatts_char_md_t char_md;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.read = 1;
    char_md.char_props.write = 0;
    //Configuring Client Characteristic Configuration Descriptor metadata and add to char_md structure
    ble_gatts_attr_md_t cccd_md;
    memset(&cccd_md, 0, sizeof(cccd_md));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    cccd_md.vloc                = BLE_GATTS_VLOC_STACK;
    char_md.p_cccd_md           = &cccd_md;
    char_md.char_props.notify   = 1;
    //Configure the attribute metadata
    ble_gatts_attr_md_t attr_md;
    memset(&attr_md, 0, sizeof(attr_md));
    attr_md.vloc = BLE_GATTS_VLOC_STACK; //Store the attributes in stack(softdevice)
    //Set read/write security levels to our characteristic
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
    //Configure the characteristic value attribute
    ble_gatts_attr_t    attr_char_value;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid  = &char_uuid;
    attr_char_value.p_attr_md = &attr_md;
    //Set characteristic length in number of bytes
    attr_char_value.max_len     = 2;
    attr_char_value.init_len    = 2;
    uint8_t value[2]            = {0xFF,0xFF};
    attr_char_value.p_value     = value;
    // Add our new characteristic to the service
    err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle,
                                   &char_md,
                                   &attr_char_value,
                                   &p_our_service->char_handles);
    return NRF_SUCCESS;
static uint32_t transmitter_char_add(ble_os_t * p_our_service)
    uint32_t      err_code;
    ble_uuid_t    char_uuid_2;
    char_uuid_2.uuid          = BLE_UUID_OUR_CHARACTERISTC_UUID_2;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid_2.type);
    ble_gatts_char_md_t char_md_2;
    memset(&char_md_2, 0, sizeof(char_md_2));
    char_md_2.char_props.read = 1;
    char_md_2.char_props.write = 0;
    ble_gatts_attr_md_t cccd_md_2;
    memset(&cccd_md_2, 0, sizeof(cccd_md_2));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_2.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_2.write_perm);
    cccd_md_2.vloc                = BLE_GATTS_VLOC_STACK;
    char_md_2.p_cccd_md           = &cccd_md_2;
    char_md_2.char_props.notify   = 1;
    ble_gatts_attr_md_t attr_md_2;
    memset(&attr_md_2, 0, sizeof(attr_md_2));
    attr_md_2.vloc = BLE_GATTS_VLOC_STACK; //Store the attributes in stack(softdevice)
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_2.read_perm);
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_2.write_perm);
    ble_gatts_attr_t    attr_char_value_2;
    memset(&attr_char_value_2, 0, sizeof(attr_char_value_2));
    attr_char_value_2.p_uuid  = &char_uuid_2;
    attr_char_value_2.p_attr_md = &attr_md_2;
    attr_char_value_2.max_len     = 2;
    attr_char_value_2.init_len    = 2;
    attr_char_value_2.p_value     = value;
    //Add our new characteristic to the service
                                   &char_md_2,
                                   &attr_char_value_2,
                                   &p_our_service->char_handles_2);
    return NRF_SUCCESS;
static uint32_t motor_delay_char_add(ble_os_t * p_our_service)
    // Add a custom characteristic UUID
    uint32_t      err_code;
    ble_uuid_t    char_uuid_3;
    char_uuid_3.uuid          = BLE_UUID_OUR_CHARACTERISTC_UUID_3;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid_3.type);
    ble_gatts_char_md_t char_md_3;
    memset(&char_md_3, 0, sizeof(char_md_3));
    char_md_3.char_props.read = 1;
    char_md_3.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_3;
    memset(&cccd_md_3, 0, sizeof(cccd_md_3));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_3.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_3.write_perm);
    cccd_md_3.vloc                = BLE_GATTS_VLOC_STACK;
    char_md_3.p_cccd_md           = &cccd_md_3;
    char_md_3.char_props.notify   = 1;
    char_md_3.char_props.write_wo_resp = 1;
    ble_gatts_attr_md_t attr_md_3;
    memset(&attr_md_3, 0, sizeof(attr_md_3));
    attr_md_3.vloc = BLE_GATTS_VLOC_STACK; //Store the attributes in stack(softdevice)
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_3.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_3.write_perm);
    ble_gatts_attr_t    attr_char_value_3;
    memset(&attr_char_value_3, 0, sizeof(attr_char_value_3));
    attr_char_value_3.p_uuid  = &char_uuid_3;
    attr_char_value_3.p_attr_md = &attr_md_3;
    attr_char_value_3.max_len     = 4;
    attr_char_value_3.init_len    = 1;
    uint8_t value[1]              = {0x00};
    attr_char_value_3.p_value     = value;
    err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle_2,
                                   &char_md_3,
                                   &attr_char_value_3,
                                   &p_our_service->char_handles_3);
    return NRF_SUCCESS;
static uint32_t custom_setting_char_add (ble_os_t * p_our_service)
    uint32_t err_code;
    ble_uuid_t char_uuid_4; //char characteristic uuid handle
    ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID; //base uuid
    char_uuid_4.uuid = BLE_UUID_OUR_CHARACTERISTC_UUID_4; //Assign our char uuid to char handle
    err_code = sd_ble_uuid_vs_add(&base_uuid,&char_uuid_4.type);// add our uuid to softdevice
    ble_gatts_char_md_t char_md_4;
    memset(&char_md_4,0,sizeof(char_md_4));
    char_md_4.char_props.read = 1;
    char_md_4.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_4;
    memset(&cccd_md_4,0,sizeof(cccd_md_4));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_4.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_4.write_perm);
    cccd_md_4.vloc = BLE_GATTS_VLOC_STACK;
    char_md_4.p_cccd_md = &cccd_md_4;
    char_md_4.char_props.notify         = 1;
    char_md_4.char_props.write_wo_resp  = 1;
    //Configure attribute metadata
    ble_gatts_attr_md_t attr_md_4;
    memset(&attr_md_4,0,sizeof(attr_md_4));
    attr_md_4.vloc = BLE_GATTS_VLOC_STACK;
    //Set read/write security level of our characteristics
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_4.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_4.write_perm);
    ble_gatts_attr_t  attr_char_value_4;
    memset(&attr_char_value_4,0,sizeof(attr_char_value_4));
    attr_char_value_4.p_uuid = &char_uuid_4;
    attr_char_value_4.p_attr_md = &attr_md_4;
    attr_char_value_4.max_len     = 4;
    attr_char_value_4.init_len    = 1;
    attr_char_value_4.p_value     = value;
    //Add our new characteristic to service
    err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle_3,
                                                &char_md_4,
                                                &attr_char_value_4,
                                                &p_our_service->char_handles_4);
    return  NRF_SUCCESS;
static uint32_t device_configuration_char_add(ble_os_t * p_our_service)
    uint32_t err_code;
    ble_uuid_t char_uuid_5; //char characteristic uuid handle
    char_uuid_5.uuid = BLE_UUID_OUR_CHARACTERISTC_UUID_5; //Assign our char uuid to char handle
    err_code = sd_ble_uuid_vs_add(&base_uuid,&char_uuid_5.type);// add our uuid to softdevice
    ble_gatts_char_md_t char_md_5;
    memset(&char_md_5,0,sizeof(char_md_5));
    char_md_5.char_props.read = 1;
    char_md_5.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_5;
    memset(&cccd_md_5,0,sizeof(cccd_md_5));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_5.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_5.write_perm);
    cccd_md_5.vloc = BLE_GATTS_VLOC_STACK;
    char_md_5.p_cccd_md = &cccd_md_5;
    char_md_5.char_props.notify         = 1;
    char_md_5.char_props.write_wo_resp  = 1;
    ble_gatts_attr_md_t attr_md_5;
    memset(&attr_md_5,0,sizeof(attr_md_5));
    attr_md_5.vloc = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_5.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_5.write_perm);
    ble_gatts_attr_t  attr_char_value_5;
    memset(&attr_char_value_5,0,sizeof(attr_char_value_5));
    attr_char_value_5.p_uuid = &char_uuid_5;
    attr_char_value_5.p_attr_md = &attr_md_5;
    attr_char_value_5.max_len     = 4;
    attr_char_value_5.init_len    = 1;
    attr_char_value_5.p_value     = value;
    ret_code_t ret_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle_3,
                                                &char_md_5,
                                                &attr_char_value_5,
                                                &p_our_service->char_handles_5);
    APP_ERROR_CHECK(ret_code);
    return  NRF_SUCCESS;
static uint32_t ligth1_control_register_char_add(ble_os_t * p_our_service)
    uint32_t err_code;
    ble_uuid_t char_uuid_6;
    char_uuid_6.uuid        = BLE_UUID_OUR_CHARACTERISTC_UUID_6;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid_6.type);
    ble_gatts_char_md_t char_md_6;
    memset(&char_md_6, 0, sizeof(char_md_6));
    char_md_6.char_props.read = 1;
    char_md_6.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_6;
    memset(&cccd_md_6, 0, sizeof(cccd_md_6));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_6.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_6.write_perm);
    cccd_md_6.vloc = BLE_GATTS_VLOC_STACK;
    char_md_6.p_cccd_md = &cccd_md_6;
    char_md_6.char_props.notify = 0;
    char_md_6.char_props.write_wo_resp = 1;
    ble_gatts_attr_md_t attr_md_6;
    memset(&attr_md_6, 0, sizeof(attr_md_6));
    attr_md_6.vloc = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_6.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_6.write_perm);
    ble_gatts_attr_t attr_char_value_6;
    memset(&attr_char_value_6, 0, sizeof(attr_char_value_6));
    attr_char_value_6.p_uuid = &char_uuid_6;
    attr_char_value_6.p_attr_md = &attr_md_6;
    attr_char_value_6.max_len = 2;
    attr_char_value_6.init_len = 2;
    uint8_t value[2] = {0x00,0x00};
    attr_char_value_6.p_value = value;
                                    &char_md_6, &attr_char_value_6,
                                    &p_our_service->char_handles_6);
    return NRF_SUCCESS;
static uint32_t ligth2_control_register_char_add(ble_os_t * p_our_service)
    uint32_t err_code;
    ble_uuid_t char_uuid_7;
    char_uuid_7.uuid        = BLE_UUID_OUR_CHARACTERISTC_UUID_7;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid_7.type);
    ble_gatts_char_md_t char_md_7;
    memset(&char_md_7, 0, sizeof(char_md_7));
    char_md_7.char_props.read = 1;
    char_md_7.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_7;
    memset(&cccd_md_7, 0, sizeof(cccd_md_7));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_7.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_7.write_perm);
    char_md_7.p_cccd_md = &cccd_md_7;
    char_md_7.char_props.notify = 1;
    char_md_7.char_props.write_wo_resp = 1;
    ble_gatts_attr_md_t attr_md_7;
    memset(&attr_md_7, 0, sizeof(attr_md_7));
    attr_md_7.vloc = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_7.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_7.write_perm);
    ble_gatts_attr_t attr_char_value_7;
    memset(&attr_char_value_7, 0, sizeof(attr_char_value_7));
    attr_char_value_7.p_uuid = &char_uuid_7;
    attr_char_value_7.p_attr_md = &attr_md_7;
    attr_char_value_7.max_len = 2;
    attr_char_value_7.init_len = 1;
    attr_char_value_7.p_value = value;
                                    &char_md_7, &attr_char_value_7,
                                    &p_our_service->char_handles_7);
    return NRF_SUCCESS;
static uint32_t motor1_control_register_char_add(ble_os_t * p_our_service)
    uint32_t err_code;
    ble_uuid_t char_uuid_8;
    char_uuid_8.uuid        = BLE_UUID_OUR_CHARACTERISTC_UUID_8;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid_8.type);
    ble_gatts_char_md_t char_md_8;
    memset(&char_md_8, 0, sizeof(char_md_8));
    char_md_8.char_props.read = 1;
    char_md_8.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_8;
    memset(&cccd_md_8, 0, sizeof(cccd_md_8));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_8.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_8.write_perm);
    char_md_8.p_cccd_md = &cccd_md_8;
    char_md_8.char_props.notify = 1;
    char_md_8.char_props.write_wo_resp = 1;
    ble_gatts_attr_md_t attr_md_8;
    memset(&attr_md_8, 0, sizeof(attr_md_8));
    attr_md_8.vloc = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_8.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_8.write_perm);
    ble_gatts_attr_t attr_char_value_8;
    memset(&attr_char_value_8, 0, sizeof(attr_char_value_8));
    attr_char_value_8.p_uuid = &char_uuid_8;
    attr_char_value_8.p_attr_md = &attr_md_8;
    attr_char_value_8.max_len = 1;
    attr_char_value_8.init_len = 1;
    attr_char_value_8.p_value = value;
                                    &char_md_8, &attr_char_value_8,
                                    &p_our_service->char_handles_8);
    return NRF_SUCCESS;
static uint32_t motor2_control_register_char_add(ble_os_t * p_our_service)
    uint32_t err_code;
    ble_uuid_t char_uuid_9;
    char_uuid_9.uuid        = BLE_UUID_OUR_CHARACTERISTC_UUID_9;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid_9.type);
    ble_gatts_char_md_t char_md_9;
    memset(&char_md_9, 0, sizeof(char_md_9));
    char_md_9.char_props.read = 1;
    char_md_9.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md_9;
    memset(&cccd_md_9, 0, sizeof(cccd_md_9));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_9.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md_9.write_perm);
    char_md_9.p_cccd_md = &cccd_md_9;
    char_md_9.char_props.notify = 1;
    char_md_9.char_props.write_wo_resp = 1;
    ble_gatts_attr_md_t attr_md_9;
    memset(&attr_md_9, 0, sizeof(attr_md_9));
    attr_md_9.vloc = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_9.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md_9.write_perm);
    ble_gatts_attr_t attr_char_value_9;
    memset(&attr_char_value_9, 0, sizeof(attr_char_value_9));
    attr_char_value_9.p_uuid = &char_uuid_9;
    attr_char_value_9.p_attr_md = &attr_md_9;
    attr_char_value_9.max_len = 2;
    attr_char_value_9.init_len = 2;
    attr_char_value_9.p_value = value;
                                    &char_md_9, &attr_char_value_9,
                                    &p_our_service->char_handles_9);
    return NRF_SUCCESS;
/**@brief Function for initiating our new service.
 * @param[in]   p_our_service        Our Service structure.c
    uint32_t   err_code; // Variable to hold return codes from library and softdevice functions
    //Declare 16-bit service and 128-bit base UUIDs and add them to the BLE stack
    ble_uuid_t        service_uuid;
    ble_uuid_t        service_uuid_2;
    ble_uuid_t        service_uuid_3;
    service_uuid.uuid = BLE_UUID_OUR_SERVICE_UUID;      //Sensor Service
    service_uuid_2.uuid = BLE_UUID_OUR_SERVICE_UUID_2;  //Transmitter Service
    service_uuid_3.uuid = BLE_UUID_OUR_SERVICE_UUID_3;  //Custom Setting Register
    err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
    err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid_2.type);
    err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid_3.type);
    // Set our service connection handle to default value. I.e. an invalid handle since we are not yet in a connection.
    // Add our service
		err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &service_uuid,
                                        &p_our_service->service_handle);
    //Call the function our_char_add() to add our new characteristic to the service.
    sensor_char_add(p_our_service);
    transmitter_char_add(p_our_service);
    //custom_setting_char_add(p_our_service);
    //Add our service
                                        &service_uuid_2,
                                        &p_our_service->service_handle_2);
    motor_delay_char_add(p_our_service);
    //Add our service
                                        &service_uuid_3,
                                        &p_our_service->service_handle_3);
 //   device_configuration_char_add(p_our_service);  //when i remove comment my app stop working.
 //   ligth1_control_register_char_add(p_our_service);
//    ligth2_control_register_char_add(p_our_service);
//    motor1_control_register_char_add(p_our_service);
//    motor2_control_register_char_add(p_our_service);
//Function to be called when updating characteristic value
    // Update characteristic value
    if (p_our_service->conn_handle != BLE_CONN_HANDLE_INVALID)//ba?lant? varm? diye kontorl ediyor. ba?lant? yoksa soft device hata verir
      uint16_t               len = 2;
      ble_gatts_hvx_params_t hvx_params;
      memset(&hvx_params, 0, sizeof(hvx_params));
      hvx_params.handle = p_our_service->char_handles.value_handle;
      hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
      hvx_params.offset = 0;
      hvx_params.p_len  = &len;
      hvx_params.p_data = (uint8_t*)voltage;
      sd_ble_gatts_hvx(p_our_service->conn_handle, &hvx_params);
// Function to be called when updating characteristic value
    if (p_our_service->conn_handle != BLE_CONN_HANDLE_INVALID)//Checking the connection status, SoftDevice occurs error if there is no connection
      uint16_t               len = 2;
      hvx_params.handle = p_our_service->char_handles_2.value_handle; //char_handles_2 oldu?u i?in 2.karakteristi?i g?ncelliyor
      hvx_params.p_data = (uint8_t*)TRM_Signal;
