Receiving data from UART via a peripheral device
Hi
I am working with a Nordic nrf52840dk using segge and sdk 16.
I am using the nordic UART example in examples/peripheral/uart.
The issue I am having is that my data being sent to this device can not be read from the nordic board.
Below is an example of the code going into my Putty terminal from my UART peripheral device.
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
This device has 4 wire connections RX,TX,CTS and RTS. My connections are listed below:
Note this is the default.
#define RX_PIN_NUMBER  8
#define TX_PIN_NUMBER  6
#define CTS_PIN_NUMBER 7
#define RTS_PIN_NUMBER 5
The first thing i tried was running the code with no change to see if app_uart_get(&cr) would pull this data. Unfortunately it did not. It does however, pull data that i type into the terminal.
What I want to do is to take this data from the UART(Sensor data) and store it as a variable for handling later on.
I which to know how I can pull this data from the serial connection.
Side note when the device (UART) is plugged in printing from putty does not run. If I unplug the device then printing works fine.  Below is my main code (from example).
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
#if defined (UARTE_PRESENT)
          NRF_UARTE_BAUDRATE_115200
#else
#if defined (UART_PRESENT)
          NRF_UART_BAUDRATE_115200
#else
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_HIGH,
                         //APP_IRQ_PRIORITY_LOWEST,
                         err_code);
#ifndef ENABLE_LOOPBACK_TEST
    printf("\r\nUART example started.\r\n");
    while (true)
        uint8_t cr;
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            while (true)
                // Do nothing.
#else
    // This part of the example is just for testing the loopback .
    while (true)
        uart_loopback_test();
  • It is the same here as well, and probably will be for some more cases. For undefined reference, this means it has not been compiled. And there are typically two reasons for that:
    • Missing sdk_config.h macro (check in the source file where the missing function is implemented to see which config macro is missing. - for app_fifo_put you cna see that it is only included by the preprocessor if APP_FIFO_ENABLED is set to 1 in sdk_config.h.
    • Make sure that the file (app_fifo.c in this caes) is actually added to the project and is compiled.
    You need to do this for all missing stuff, until you don't get any more errors when building.
  • Ok it built. But when I combine my code i get an error unknown function at 0X00024C92
  • This is my main function.
    If i remove the RTT code I can see an advert and the counter increase once per second.
    If I include it the RTT viewer does not have any data on it nor does the advert run.
        T1_data_1 = 0;T1_data_2 = 0;T2_data_1 = 0;T2_data_2 = 0;T3_data_1 = 0;
        T3_data_2 = 0;P1_data_1 = 0;P1_data_2 = 0;P2_data_1 = 0;P2_data_2 = 0;
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        power_management_init();
        ble_stack_init();
        advertising_init();
        uint32_t err_code;
        char string[MAX_TEST_DATA_BYTES];
        char c;
        int pos;
        hfxo_enable();
        log_init();
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
    #else
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             err_code);
        pos = 0;
        // Start execution.
        NRF_LOG_INFO("Beacon example started.");
        advertising_start();
        advertising_mod(counter,00,00,00,00,00,00,70,80,70,80);//Only have two temperature sensors
        // Enter main loop.
        for (;;)
            nrf_delay_ms(1000);
            counter ++;
            idle_state_handle();
            while (app_uart_get(&c) != NRF_SUCCESS);//Comes once persond
            counter ++;
            data_changed = true;
            string[pos] = c;
            // Assume that all strings end with \n. If end, print and start over.
            if (string[pos] == '\n')
                string[pos+1] = '\0';
                NRF_LOG_INFO("Received string: \"%s\"", string);
                pos = 0;
                pos++;
            if(data_changed==true)
              printf("data changed value is: %d\r\n",data_changed);
              advertising_mod(counter,T1_data_1,T1_data_2,T2_data_1,T2_data_2,00,00,70,80,70,80);//Only have two temperature sensors
              data_changed = false;
    And it goes to NRF_BREAKPOINT_COND in the code. (when debugging)
  • Would it help if i shared my entire code with you?
  • The error i think comes from hfxo_enable.
    One issue is though if I use your RTT RX code, it crashes when I debug and try stepping through. So I presume when I merge the projects I won't be able to debug it via the debugger.
