I'd like to start developing automated tests for my custom NRF52840 board.
Currently I use the CLI library (with RTT backend) for communicating with the board.
Any ideas for how I could communicate with my board via a python script?
Thanks
Tim
Thanks
Tim
I have not experienced this. I did a test with a modified peripheral example, and a custom pynrfjprog sample. This seems to work as expected.
from __future__ import print_function
# Import pynrfjprog API module
from pynrfjprog import LowLevel
from time import sleep
def run(snr=None):
Run example script.
@param (optional) int snr: Specify serial number of DK to run example on.
print('# RTT read example using pynrfjprog started...')
# Detect the device family of your device. Initialize an API object with UNKNOWN family and read the device's family. This step is performed so this example can be run in all devices without customer input.
print('# Opening API with device family UNKNOWN, reading the device family.')
with LowLevel.API(LowLevel.DeviceFamily.UNKNOWN) as api: # Using with construction so there is no need to open or close the API class.
if snr is not None:
api.connect_to_emu_with_snr(snr)
else:
api.connect_to_emu_without_snr()
device_family = api.read_device_family()
# Initialize an API object with the target family. This will load nrfjprog.dll with the proper target family.
api = LowLevel.API(device_family)
# Open the loaded DLL and connect to an emulator probe. If several are connected a pop up will appear.
api.open()
try:
if snr is not None:
else:
# Erase all the flash of the device.
print('Starting RTT.')
api.rtt_start()
# rtt_start() API is non-blocking, need to wait for the control block to be found
while(api.rtt_is_control_block_found() != True):
print("waiting for control block")
sleep(0.1)
channel_count_down, channel_count_up = api.rtt_read_channel_count()
print("Found {} down channels and {} up channels".format(channel_count_down, channel_count_up))
rtt_string = {}
for i in range(channel_count_down):
rtt_string[str(i)] = b''
while(True):
r = api.rtt_read(i, 1)
if(len(r) != 0):
if(r == b'\n'):
print(rtt_string[str(i)])
else:
rtt_string[str(i)] = rtt_string[str(i)] + r
api.close()
print('# Example done...')
except LowLevel.APIError:
api.close()
raise
if __name__ == '__main__':
run()
Did you SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS/SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS in your sdk_config.h file?
Thanks, I'll give this a try.
In the meantime I noticed that the script you sent primarily does RTT reading, and the firmware does RTT write. Is the reverse possible (writing using the script, and reading using the firmware)?
Yes, that should work similarly. I updated the examples with read in application and write in Python script:
rtt_reader_writer_sdk_16.0.0.zip
TEST_STRING = b'RTT Channel 1 write test #'
def run(snr=None):
Run example script.
if snr is not None:
else:
api.open()
try:
if snr is not None:
else:
api.rtt_start()
sleep(0.1)
cnt = 0
while(True):
api.rtt_write(1, TEST_STRING + str(cnt) + '\0')
cnt = cnt + 1
sleep(2);
api.close()
api.close()
raise
run()
Thanks Jørgen, and apologies for the late response. I've been sidetracked by other tasks. Now I finally have time for this.
I currently use SDK 15.2.0. What peripheral example did you start with? (I'd like to have as close to your setup as possible to avoid nasty surprises).
I started out with the UART peripheral example. However, I do not think that any part of that example is used in the project I uploaded, so it should not really matter.
