nRF Master Control Panel on LG G2 with Android 4.4.2 can't connect to S130 v0.9 with example that goes with SoftDevice. But it can connect to S110 example that goes with SoftDevice.
Could you specify when LG phone support will be added to S130?
Thank you for experiments! Did you tested project I attached yesterday or another?
I think it was that one. I was just given a HEX file, didn't compile it myself. It advertises only with manufacturer data 0x5599. I've also tested it using LG F60 (4.4.4) and also connection was successful. Maybe you just need to restart the phone or remove the bond information if you have paired a device that was previously flashed on the same board? EDIT: I forgot to specify on which LG model I tested it.
It is your project Yaro.
If it advertises 0x5599 than it's my sources. Could you tell me, please, what model of LG did you used?
I've altered my previous comment. It was the LG F60. Also at the beginning of my testing I had some problems with Samsung S3 (4.3), it didn't send any Connect Request. After several minutes of struggling it suddenly started to work and now it connects 100% of times.
