Questions about spi read and write function mapping
I'm having trouble driving the BMI088 with the official driver of Bosch BMI088 (link to this driver) in the ble_app_uart routine. I never get the chip ID. Bosch BMI088 official driver link address: https://github.com/BoschSensortec/BMI08x-Sensor-API . The spi read and write functions are encapsulated into the following two APIs:
int8_t user_spi_write(uint8_t cs_pin, uint8_t reg_addr, uint8_t *data, uint16_t len);
int8_t user_spi_read(uint8_t cs_pin, uint8_t reg_addr, uint8_t *data, uint16_t len);
So How can I map these two APIs into Nordic operation functions?
And The automatic selection between [CPOL = '0' and CPHA = '0'] and [CPOL = '1' and CPHA = '1'] is controlled based on the value of SCK after a falling edge of CSB (1 or 2). What SPI mode should I configure?
  • Sorry for the long wait.
    The read function should look like this:
        nrfx_err_t ret_code = NRFX_SUCCESS;
        nrfx_spim_xfer_desc_t my_xfer_desc = NRFX_SPIM_XFER_RX(&data, (len + 1));
        uint8_t m_tx_buf[MAX_LENGTH];   // create buffer
        memset(&m_tx_buf, 0, sizeof(m_tx_buf)); //clear buffer
        m_tx_buf[0] = (1 << 0) | (reg_addr << 1);
        /* Configure the Chip Select pin, SPIM3 supports HW controlled CS pin*/
        NRF_SPIM3->PSEL.CSN = cs_pin;
        ret_code = nrfx_spim_xfer(&my_spim_instance, my_xfer_desc, flags);
        APP_ERROR_CHECK(ret_code);
        return;
  • Although I have solved the problem myself, thank you for replying to me!
  • Hi june6,
    i got the same issue , i am trying to interface spi nor flash with nRF52840 but not able to read the device ID?
    I use Bosch driver, there is no problem at all. Here is my SPI configuration:
    #define NRF_DRV_SPI_BMI088_DEFAULT_CONFIG                    \
        .sck_pin      = NRF_DRV_SPI_PIN_NOT_USED,                \
        .mosi_pin     = NRF_DRV_SPI_PIN_NOT_USED,                \
        .miso_pin     = NRF_DRV_SPI_PIN_NOT_USED,                \
        .ss_pin       = NRF_DRV_SPI_PIN_NOT_USED,                \
        .irq_priority = SPI_DEFAULT_CONFIG_IRQ_PRIORITY,         \
        .orc          = 0xFF,                                    \
        .frequency    = NRF_DRV_SPI_FREQ_8M,                     \
        .mode         = NRF_DRV_SPI_MODE_0,                      \
        .bit_order    = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST,         \
    #define SPI_INSTANCE_0                  0                                           /**< SPI instance index. */
    static const nrf_drv_spi_t spi_0_bmi088 = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE_0);     /**< SPI instance. */
    nrf_drv_spi_config_t spi_bmi088_config = NRF_DRV_SPI_BMI088_DEFAULT_CONFIG;
    nrf_gpio_cfg_output(MCU_GPIO_BMI088_CSB1);
    nrf_gpio_cfg_output(MCU_GPIO_BMI088_CSB2);
    nrf_gpio_pin_set(MCU_GPIO_BMI088_CSB1);
    nrf_gpio_pin_set(MCU_GPIO_BMI088_CSB2);
    spi_bmi088_config.ss_pin   = NRF_DRV_SPI_PIN_NOT_USED;
    spi_bmi088_config.miso_pin = SPI_BMI088_MISO_PIN;
    spi_bmi088_config.mosi_pin = SPI_BMI088_MOSI_PIN;
    spi_bmi088_config.sck_pin  = SPI_BMI088_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi_0_bmi088, &spi_bmi088_config, spi_bmi088_event_handler, NULL));
  • I am facing the exact same issues with the exact same sensor. including 0xFF chip ID.
    Could you share the solution you found in the end (spi read and write functions)? or a perhaps a link to a repository with a working example?
