OTA over serial failure| sdk 15.2
Hello Everyone,
I am using nrf52832 and sdk 15.2 for ota over serial. I have made bootloader for OTA over UART and tested same with nrfutil using my dfu package file. firmware is upgraded successfully and  working fine.
Now I need to upgrade firmware using host MCU. I tried sending dfu package file( .zip ) to nrf52832 over UART using slip librairy to upgrade firmware but it is not working.
Is there any compulsion to send Ping packet, PNR, MTU Packet, init packet, application and bootloader separately over UART?
Can we send directly dfu package created through nrfutil to nrf52832 from other MCU over UART?
Kindly suggest me right approach.
    I have generated init packet.
    I tried sending init packet and app file. that time init packet executes successfully but app file not due to some reason.now want to send again init packet and app file but init packet does not executes because it was done before. I need to execute this init packet from crash now again. is there any command to set bootloader to recieve init packet from crash again.
  • One way to reset the device is to call a systemreset from the sourcecode if the second init (application image) fails. Depending on whether you have a valid application or not you may have to set the correct reset register (the way that you set it to get it to run DFU mode instead of the application) in the first place.
    The way this is typically done is to write to the NRF_POWER->GPREGRET register.
    Please see how this register is checked in dfu_enter_check() in nrf_bootloader.c:
        if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
            NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
            return true;
    So this register has to be written before the reset (you can use bootloader_reset() to reset the bootloader).
    But perhaps it would be more interresting to know why the execute command doesn't work? Do you use HWFC? At what rate are you sending the packets?
  • Let me explain in briefly.
    I first sent two files( Baud:115200, HWFC Disabled )
    Init packet -> executes successfully
    application file -> does not executes( I am downloading file from server then sending file to nrf through serially so if network failor occurs it fails)
    then I send two files again( Baud:115200, HWFC Disabled )
    Init packet -> does not executes
  • If you do not use HWFC then the issue may be that it doesn't have time to write the packets to flash with the speed you are sending them. Try to add some delay between each packet, and see if the issue remains. Alternatively, try to enable HWFC and see whether that may be the issue. If the nRF Has no way of holding back the UART packets, and they are received too fast, I am not sure how the bootloader would react.
    BR,
    Edvin
  • I think that is not the issue.
    I have used 10ms of delay when sending packet.
    As per my observation, nrf is not executing second init packet if first one is executed successfully and stored in flash. so that I was asking to erase flash in boot mode.
    Is it correct?
