OTA over serial failure| sdk 15.2
Hello Everyone,
I am using nrf52832 and sdk 15.2 for ota over serial. I have made bootloader for OTA over UART and tested same with nrfutil using my dfu package file. firmware is upgraded successfully and  working fine.
Now I need to upgrade firmware using host MCU. I tried sending dfu package file( .zip ) to nrf52832 over UART using slip librairy to upgrade firmware but it is not working.
Is there any compulsion to send Ping packet, PNR, MTU Packet, init packet, application and bootloader separately over UART?
Can we send directly dfu package created through nrfutil to nrf52832 from other MCU over UART?
Kindly suggest me right approach.
  • Ok. I am using flow control and sending ping packet, still not receiving any data. I tried sending ping packet using slip also but not working. I am using secure dfu example pca10040_uart for bootloader. Please check 5265.sdk_config.h for configurations.
    here is my test code.
        char init_data[4]={0x09,0x01};
    	uint8_t  RespData[500];
    	uint32_t length= 2;
    	uint32_t rec_len=0, ret;
    	char *rec = "";
    //	SLIP_send(init_data,length);
    	uart_write_bytes(UART_NUM_1, init_data, length);
    	uart_wait_tx_done(UART_NUM_1, 5);
    	vTaskDelay(10);
    //	ret = SLIP_recv(rec,rec_len);
    //	printf("%u bytes sent.",ret);
    	uart_get_buffered_data_len(UART_NUM_1,&length);
    	int readBytes = uart_read_bytes(UART_NUM_1, RespData,length, 0);
    	printf("readBytes: %d",readBytes);
  • Where does this code belong? The other MCU? Have you tried to analyze the lines? Are there any data going from the other MCU?
    Do you get any interrupts in the bootloader application? Can you test with the pca10040_uart_debug bootloader project. There you can turn off optimization, and perform debugging properly.
    BR,
    Edvin
  • Yes, other MCU. data is going over Tx line.
    I'll test with debug bootloader project and get back to you.
    I had written a code  for ping packet in python and connected nrf52 DK BOARD with my desktop using COM port. flashed softdevice and bootloader into it.
    getting response( `\t\x01\x01\xc0 ) from DK board. is it correct response?
    how can I communicate with DK board using Tx, Rx pins?
    I tried connecting P.06 and P.08 of nrf52 with usb to ttl converter using same code. not getting any response. please help me regarding same.
  • Perhaps you should start with the UART example on the SDK, e.g. the SDK\examples\peripheral\uart, so that you can test that the echoing is working properly. This example will only echo back everything you write to the UART.
    On the nRF52832 DK pin P0.06 = UART TX, and pin P0.08 is the UART RX. This means that you have to connect your other MCU's UART TX to P0.08 and the other MCU's UART RX to P0.06. Is that what you did?
    NB, when you are testing this example, turn off the Flow control. It is set in:
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                          RX_PIN_NUMBER, TX_PIN_NUMBER,
                          RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                          NRF_UART_HWFC_ENABLED, NRF_UART_PARITY_EXCLUDED,
                          NRF_UART_BAUDRATE_115200,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY);
    Change NRF_UART_HWFC_ENABLED to NRF_UART_HWFC_DISABLED.
    Does your other MCU require flow control by the way?
